策略路由
2019-08-13提问
  • 1收藏,1105浏览
专线 IP 123.149.207.94 服务器IP 192.168.10.224
专线已经插到MS830 的GigabitEthernet0/4 GET4那个口上了
需要让原先MS830 分配的内网主机能访问 192.168.10.224的服务器 但是上网走原来的拨号不走专线的网 只让服务器外网走专线
希望大神能针对以上IP 写下命令
寂东 九段
粉丝:225人 关注:3人
内网终端访问内网地址 192.168.10.224,走二层单播,不经过路由器,出外网选路问题,得配置pbr,实现哪些源地址走哪个出口上互联网,例如:
policy-based-route p1 permit node 1
 if-match acl 2001
apply default-output-interface dialer 1
 policy-based-route p1 permit node 2
 if-match acl 2002
 apply default-next-hop 2.1.1.1     /专线的下一跳/
acl number 2001
 rule 1 permit source 192.168.1.0 0.0.0.255
acl number 2002
 rule 1 permit source 192.168.2.0.0 0.0.0.255
acl number 2000  (将ACL 2000 应用到3wan口做acl转发,nat out 2000
rule 2 permit source 192.168.2.0 0.0.0.255
interface GigabitEthernet0/0
description link-lan
ip policy-based-route p1
然后配置两条外线的缺省路由
ip route-static 0.0.0.0 0 1.1.1.1
ip route-static 0.0.0.0 0 2.1.1.1
配置后192.16810.224 能通外网 但是其他的192.168.10.XX上不了外网 专线的ip内网也能ping通 acl number 3010 rule 5 permit ip source 192.168.1.0 0.0.0.255 rule 10 permit ip source 192.168.2.0 0.0.0.255 rule 15 permit ip source 192.168.10.0 0.0.0.255 acl number 3011 rule 20 permit ip source 192.168.10.244 255.255.255.255 [H3C-acl-adv-3011]acl number 3012 [H3C-acl-adv-3012]rule 5 permit ip source 192.168.1.0 0.0.0.255 [H3C-acl-adv-3012]rule 10 permit ip source 192.168.2.0 0.0.0.255 [H3C-acl-adv-3012]rule 15 permit ip source 192.168.10.0 0.0.0.255 [H3C]policy-based-route aaa permit node 5 % New sequence of this list. [H3C-pbr-aaa-5]if-match acl 3012 [H3C-pbr-aaa-5]policy-based-route aaa permit node 10 % New sequence of this list. [H3C-pbr-aaa-10]if-match acl 3011 [H3C-pbr-aaa-10]apply ip-address next-hop 192.168.10.224 [H3C-pbr-aaa-10]quit [H3C]interface GigabitEthernet0/4 [H3C-GigabitEthernet0/4]ip address 123.149.207.94 255.255.255.0 [H3C-GigabitEthernet0/4]dhcp select relay [H3C-GigabitEthernet0/4]dhcp relay server-select 1 [H3C-GigabitEthernet0/4]ip policy-based-route aaa [H3C-GigabitEthernet0/4]quit
zhiliao_A9LSa 发表时间:2019-08-13
回复zhiliao_A9LSa:
把配置文件内容复制到word里,在复制到问题对话框中看看
寂东 发表时间:2019-08-13
回复寂东:
回复寂东:
把空格都去掉了
我发答案上了
呵呵 九段
粉丝:27人 关注:0人
基本功能,哪里有问题吗?做配置的话,建议看看配置手册。
专线插上去了 看着手册配置了几次不成功
zhiliao_A9LSa 知了小白
acl number 3010
acl number 3011
