S5000-16X-EI 在出厂模式下,怎么设置管理口可以登录web
2019-08-14提问
  • 1收藏,1385浏览
如下文描述,我已经 设置了管理口的ip 172.16.255.9/16,并且可以telnet 172.16.255.9登录,请问我需要怎么配置,才能使用https://172.16.255.9登录网页
[H3C]display ip https
HTTPS port: 443
SSL server policy : Not configured
Certificate access-control-policy : Not configured
Basic ACL: 0 Operation status : Enabled
[H3C]display interface M-GigabitEthernet0/0/0
Current state: UP
Line protocol state: UP Description:
Interface Bandwidth: 1000000 kbps
Internet address: 172.16.255.9/16 (primary)
IP packet frame type: Ethernet II,
hardware address: 7485-c4bd-a35e IPv6 packet frame type: Ethernet II, hardware address: 7485-c4bd-a35e Last link flapping: 0 hours 8 minutes 28 seconds Last clearing of counters: Never Media type is twisted pair, loopback not set Port hardware type is 1000_BASE_T 1000Mbps-speed mode , full-duplex mode Input: 94315 packets, 9657385 bytes 40536 broadcasts,53594 multicasts Input: - 0 input errors,- 0 runts,- 0 giants,- throttles,0 CRC - frame,- overruns,- aborts,- ignored,- parity errors Output: 182 packets, 12256 bytes 2 broadcasts,0 multicasts Output: - output errors,- underruns,- buffer failures - aborts,- deferred,0 collisions,0 late collisions - lost carrier,- no carrier
jerry 七段
粉丝:8人 关注:2人
#进入系统视图
<H3C>system-view
#创建本地用户admin,并设置登录密码为admin,服务类型为httphttps,用户级别为network-admin管理员级别
[H3C] local-user admin
[H3C-luser-manage-admin] password simple admin
[H3C-luser-manage-admin] service-type http https
[H3C-luser-manage-admin] authorization-attribute user-role network-admin
[H3C-luser-manage-admin] quit
#配置交换机的管理地址:
[H3C] interface vlan-interface 1
[H3C-VLAN-interface1] ip address 192.168.1.58 255.255.255.0
[H3C-VLAN-interface1] quit
#开启httphttps服务
[H3C]ip http enable
[H3C]ip https enable
#保存配置
[H3C]save force
此时打开浏览器,地址栏输入交换机的管理地址即可登录WEB界面。也可以使用https://192.168.1.58 这样的https的方式登录WEB进行管理。
“WEB用户登录对话框中输入用户名、密码及验证码,点击<登录>按钮后即可登录,显示WEB初始页面。成功登录后,用户可以在配置区对设备进行相关配置。
AVAYA 九段
粉丝:32人 关注:0人
V5交换机WEB登录设备方法
V7交换机WEB登录设备方法
V7交换机WEB登录设备方法
V7交换机WEB登录设备方法 1
1 配置需求或说明 1
1.1 适用产品系列 1
1.2 需要的工具环境 1
2 组网图 1
3 配置步骤 2
1 配置需求或说明
1.1 适用产品系列
本案例适用于如S5130-28F-WiNetS5500V2-24P-WiNetS5500V2-48P-WiNet等的V7交换机,V5V7交换机具体分类及型号可以参考1.1 Comware V5V7平台交换机分类说明”。
1.2 需要的工具环境
Console线接入登陆设备使用命令配置WEB登录设备
2 组网
3 配置步骤
#进入系统视图
<H3C>system-view
#配置交换机的管理地址:
#开启httphttps服务
[H3C]ip http enable
#保存配置
[H3C]save force
zhiliao_dSbks 知了小白
谢谢两位。两位答案都是对的,我只是采纳了前一位,感谢两位
