汇聚上开了stp,查看日志,怎么总是显示重新计算拓扑,网络不停震荡
2019-08-21提问
  • 1收藏,1117浏览
%Aug 17 07:52:25:621 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:01:01:757 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:01:04:638 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:01:04:721 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:01:07:638 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:03:45:866 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:03:48:644 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:05:22:691 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 08:07:52:602 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:07:54:653 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:10:15:235 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:10:17:670 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:28:52:069 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGIN: admin logged in from 192.168.3.172.%Aug 17 08:28:55:049 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is sys%Aug 17 08:28:56:414 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis cur%Aug 17 08:39:09:050 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGOUT: admin logged out from 192.168.3.172.%Aug 17 08:39:32:789 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:39:35:722 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:39:35:779 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:39:38:723 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:44:39:928 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGIN: admin logged in from 192.168.3.172.%Aug 17 08:44:41:905 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is sys%Aug 17 08:44:44:063 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis cur%Aug 17 08:45:47:803 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:45:50:736 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:45:50:783 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:45:53:736 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:52:44:023 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 08:52:46:139 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 08:53:25:883 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:53:28:752 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:53:28:882 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:53:31:755 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:54:58:159 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGOUT: admin logged out from 192.168.3.172.%Aug 17 08:57:47:784 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:57:50:762 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:57:50:945 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 08:57:53:762 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 09:06:04:158 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGIN: admin logged in from 192.168.3.172.%Aug 17 09:06:05:924 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is sys%Aug 17 09:06:11:480 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis logbuffer%Aug 17 09:07:32:396 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis clock%Aug 17 09:14:32:572 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/25 changed to down.%Aug 17 09:14:32:573 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/25 changed to down.%Aug 17 09:14:32:573 2019 ÐÐÕþÂ¥»ã¾Û LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port XGE1/0/25 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.%Aug 17 09:14:32:706 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation1 changed to down.%Aug 17 09:14:32:722 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation1 changed to down.%Aug 17 09:16:22:905 2019 ÐÐÕþÂ¥»ã¾Û LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port Ten-GigabitEthernet1/0/25 (IfIndex 25), neighbor's chassis ID is 5098-b808-e600, port ID is Ten-GigabitEthernet1/3/0/35.%Aug 17 09:16:32:479 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGOUT: admin logged out from 192.168.3.172.%Aug 17 09:17:36:883 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/25 changed to up.%Aug 17 09:17:36:894 2019 ÐÐÕþÂ¥»ã¾Û LAGG/6/LAGG_ACTIVE: Member port XGE1/0/25 of aggregation group BAGG1 changed to the active state.%Aug 17 09:17:37:006 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/25 changed to up.%Aug 17 09:17:37:007 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation1 changed to up.%Aug 17 09:17:37:011 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation1 changed to up.%Aug 17 09:17:37:023 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_DETECTED_TC: Instance 0's port Bridge-Aggregation1 detected a topology change.%Aug 17 09:17:37:039 2019 ÐÐÕþÂ¥»ã¾Û LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/25 (IfIndex 25), neighbor's chassis ID is 5098-b808-e600, port ID is Ten-GigabitEthernet1/3/0/35.%Aug 17 09:17:37:097 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 09:17:39:806 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 09:17:54:868 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/25 changed to down.%Aug 17 09:17:54:873 2019 ÐÐÕþÂ¥»ã¾Û LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port XGE1/0/25 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.%Aug 17 09:17:54:879 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/25 changed to down.%Aug 17 09:17:55:021 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation1 changed to down.%Aug 17 09:17:55:092 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation1 changed to down.%Aug 17 09:19:41:905 2019 ÐÐÕþÂ¥»ã¾Û LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port Ten-GigabitEthernet1/0/25 (IfIndex 25), neighbor's chassis ID is 5098-b808-e600, port ID is Ten-GigabitEthernet1/3/0/35.%Aug 17 09:20:51:021 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 09:21:31:168 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 09:25:53:197 2019 ÐÐÕþÂ¥»ã¾Û LAGG/6/LAGG_ACTIVE: Member port XGE1/0/25 of aggregation group BAGG1 changed to the active state.%Aug 17 09:25:53:202 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/25 changed to up.%Aug 17 09:25:53:294 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/25 changed to up.%Aug 17 09:25:53:295 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation1 changed to up.%Aug 17 09:25:53:295 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation1 changed to up.%Aug 17 09:25:53:317 2019 ÐÐÕþÂ¥»ã¾Û LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/25 (IfIndex 25), neighbor's chassis ID is 5098-b808-e600, port ID is Ten-GigabitEthernet1/3/0/35.%Aug 17 09:25:53:332 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_DETECTED_TC: Instance 0's port Bridge-Aggregation1 detected a topology change.%Aug 17 09:25:53:352 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 09:25:55:824 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 09:27:21:584 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 09:28:26:946 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGIN: admin logged in from 192.168.3.172.%Aug 17 09:28:28:313 2019 ÐÐÕþÂ¥»ã¾Û SHELL/4/SHELL_CMD_MATCHFAIL: -User=admin-IPAddr=192.168.3.172; Command sys\ in view shell failed to be matched.%Aug 17 09:28:30:861 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis cur%Aug 17 09:28:38:560 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is sys%Aug 17 09:28:43:309 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis logbuffer%Aug 17 09:28:51:886 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis logbuffer%Aug 17 09:30:47:853 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 09:31:48:367 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis buffer%Aug 17 09:31:56:073 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis logbuffer%Aug 17 09:41:59:011 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGOUT: admin logged out from 192.168.3.172.%Aug 17 09:54:01:563 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGIN: admin logged in from 192.168.3.172.%Aug 17 09:54:03:312 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is sys%Aug 17 09:54:05:758 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis cur%Aug 17 09:54:12:525 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis logbuffer%Aug 17 09:54:15:757 2019 ÐÐÕþÂ¥»ã¾Û SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=192.168.3.172-User=admin; Command is dis logbuffer%Aug 17 10:03:35:084 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 10:04:19:615 2019 ÐÐÕþÂ¥»ã¾Û SHELL/5/SHELL_LOGOUT: admin logged out from 192.168.3.172.%Aug 17 10:18:48:895 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 10:42:30:004 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 10:42:32:997 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 11:03:13:397 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 11:03:15:449 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 11:39:21:014 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 11:39:23:115 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 11:39:24:014 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 11:39:26:115 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 11:54:59:857 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 11:55:02:150 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 12:31:20:380 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 12:31:23:233 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 12:32:04:390 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 12:32:07:232 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 14:32:22:129 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 14:32:24:492 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 14:36:38:345 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 14:36:40:523 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 14:52:46:984 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 14:59:41:528 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 15:48:14:640 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 15:48:16:657 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 16:18:56:308 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 16:18:58:723 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 16:18:59:471 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 16:19:01:725 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 17:45:51:425 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 17:45:53:925 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 17:45:54:392 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 17:45:56:915 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 18:45:30:566 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 18:45:32:652 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 17 19:39:38:804 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/10 changed to down.%Aug 17 19:39:38:806 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/10 changed to down.%Aug 17 19:39:41:135 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/10 changed to up.%Aug 17 19:39:41:135 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/10 changed to up.%Aug 17 19:42:20:598 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/11 changed to down.%Aug 17 19:42:20:599 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/11 changed to down.%Aug 17 19:51:01:467 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 17 19:51:04:185 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 06:49:59:381 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 06:50:01:623 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 06:50:02:314 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 06:50:04:623 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:04:00:372 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:04:02:654 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:04:03:337 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:04:05:654 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:33:31:381 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:33:33:720 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:33:34:495 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:33:36:718 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:38:59:876 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/10 changed to down.%Aug 18 07:38:59:876 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/10 changed to down.%Aug 18 07:39:06:977 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/10 changed to up.%Aug 18 07:39:06:977 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/10 changed to up.%Aug 18 07:41:24:438 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:41:26:735 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:41:27:382 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:41:29:735 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:41:30:755 2019 ÐÐÕþÂ¥»ã¾Û IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/11 changed to up.%Aug 18 07:41:30:759 2019 ÐÐÕþÂ¥»ã¾Û IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/11 changed to up.%Aug 18 07:49:34:426 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:49:36:753 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:49:37:397 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 07:49:39:760 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:00:59:423 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:01:01:778 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:01:02:408 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:01:04:780 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:09:09:138 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:09:11:797 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:12:17:672 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:12:19:803 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:14:52:996 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:14:55:815 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:37:23:029 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:37:25:858 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:53:29:057 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 08:53:31:894 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:04:47:089 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:04:49:933 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:27:26:576 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:27:28:967 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:27:29:549 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:27:31:970 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:40:31:601 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:40:34:003 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:40:34:548 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:40:36:997 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:56:40:584 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:56:43:031 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:56:43:562 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:56:46:038 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 09:58:45:557 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 18 10:08:00:741 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 10:08:03:083 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 12:15:09:446 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 12:15:12:334 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 15:30:56:991 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 15:30:59:758 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 15:30:59:935 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 15:31:02:770 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 15:56:06:998 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 18 15:56:08:993 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/6 was notified a topology change.%Aug 18 16:23:24:029 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 16:23:26:874 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 16:23:27:161 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 16:23:29:874 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:07:49:114 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:07:51:972 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:07:52:161 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:07:54:971 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:23:58:087 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:24:01:004 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:24:01:086 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:24:04:004 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:31:52:100 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:31:55:021 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:31:55:067 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 17:31:58:022 2019 ÐÐÕþÂ¥»ã¾Û STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.%Aug 18 19:39:42:504 2019 ÐÐÕþÂ
粉丝:50人 关注:5人
对应日志表示从聚合1收到stp tc报文,现场查找下聚合1互联的设备,然后登陆对应设备,多次执行display stp tc,看received增加的都是哪些接口,然后再到received递增的接口互联的设备查,如此反复,直到最终无received增加的设备,此时查对应设备是否有非stp边缘接口存在UP/down情况即可。解决请采纳
这个只是汇聚上的,核心上的也是这种情况,而且不只是聚合组1,显示很多聚合组都是这种情况
zhiliao_Ih6Vk 发表时间:2019-08-21
那说明应该有多个非边缘接口在UP/down,按我上述发的方式,逐个查,解决请采纳
24号扣子 发表时间:2019-08-21
那直接把所有接入上的端口都加入边缘端口行吗
可以。
这个跟汇聚上的端口有没有关系,汇聚上的端口肯定不能加入边缘端口啊
没关系。
