MSR830 NAT不能上网
2019-08-30提问
  • 1收藏,1128浏览
我做了一个一对一地址转换,设置后不能上网,去掉装换或换其它IP就可以,请问是缺少什么设置吗
[orphic_5633-GigabitEthernet0/0]dis nat all
NAT outbound information: Totally 1 NAT outbound rules.
 Interface: GigabitEthernet0/0
 ACL: ---
 Address group ID: ---
 Port-preserved: N
 NO-PAT: N
 Reversible: N
 Config status: Active
 Static NAT mappings: Totally 1 inbound static NAT mappings.
 IP-to-IP:
 Global IP : 211.103.223.163
 Local IP : 192.168.80.242
 Totally 1 outbound static NAT mappings.
 IP-to-IP:
 Interfaces enabled with static NAT:
 Totally 1 interfaces enabled with static NAT.
 NAT logging:
 Log enable : Disabled
 Flow-begin : Disabled
 Flow-end : Disabled
 Flow-active : Disabled
 Port-block-assign : Disabled
 Port-block-withdraw : Disabled
 Alarm : Disabled
 NAT mapping behavior:
 Mapping mode : Address and Port-Dependent
 ACL : ---
 NAT ALG: DNS : Enabled
 FTP : Enabled H323 : Disabled
 ICMP-ERROR : Enabled
 ILS : Disabled
 MGCP : Disabled
 NBT : Disabled
 PPTP : Enabled
 RTSP : Enabled
 RSH : Disabled
 SCCP : Disabled
 SIP : Disabled
 SQLNET : Disabled
 TFTP : Disabled
 XDMCP : Disabled
 Static NAT load balancing: Disabled
呵呵 九段
粉丝:27人 关注:0人
用其他地址,如果就一个公网地址,静态一对一,会影响其他内网地址
zhiliao_45347 知了小白
是我表述的不太清楚,设置静态一对一后,IP设成242就不能上网,设成其它的就没问题,其它内网主机上网也不受影响。很奇怪。
