手机端提示认证成功但无法上网
dhcp server ip-pool vlan30
gateway-list 10.100.30.254
network 10.100.30.0 mask 255.255.255.0
dns-list 114.114.114.114
interface Vlan-interface10
ip address 10.100.10.253 255.255.255.0
interface Vlan-interface30
description 无线
ip address 10.100.30.253 255.255.255.0
portal enable method direct
portal apply web-server secportal
interface Vlan-interface40
ip address 10.100.40.253 255.255.255.0
ip route-static 0.0.0.0 0 10.100.10.254
time-range alltime 00:00 to 23:59 daily
ntp-service unicast-server 120.25.115.20
radius session-control enable
radius scheme imc
primary authentication 10.100.40.12
primary accounting 10.100.40.12
key authentication cipher $c$3$e5ZxBEJVwXJ+8KaHPUvc3rEu3WQzX7AjzQ==
key accounting cipher $c$3$fqNo4gmUT2sBuvKHt8V0ct42B8o4SrjLQA==
user-name-format without-domain
radius scheme system
domain ***.***
authorization-attribute idle-cut 20 1024
authentication portal radius-scheme imc
authorization portal radius-scheme imc
accounting portal radius-scheme imc
domain default enable ***.***
# portal free-rule 0 source ip any destination ip 10.100.30.253 255.255.255.255
portal free-rule 1 source ip 10.100.30.253 255.255.255.255 destination ip any
portal free-rule 2 source ip any destination ip 61.177.7.1 255.255.255.255
portal free-rule 3 source ip 61.177.7.1 255.255.255.255 destination ip any
portal free-rule 4 source ip any destination ip 114.114.114.114 255.255.255.255
portal free-rule 5 source ip 114.114.114.114 255.255.255.255 destination ip any
portal free-rule 6 source ip any destination ip 172.17.1.0 255.255.255.0
portal free-rule 7 source ip 172.17.1.0 255.255.255.0 destination ip any
portal free-rule 8 source ip any destination ip 10.100.40.12 255.255.255.255
portal free-rule 9 source ip 10.100.40.12 255.255.255.255 destination ip any
portal free-rule 10 source ip any destination ip 10.100.30.254 255.255.255.255
portal free-rule 11 source ip 10.100.30.254 255.255.255.255 destination ip any
portal web-server secportal
url http://10.100.30.253:8080/portal
server-detect interval 50 log
portal local-web-server http
default-logon-page portal.zip
tcp-port 8080
日志:
%Aug 29 23:21:57:416 2019 SW-01 SOCKET/6/TCP_SYNFLOOD: atckType(1016)=(05)SYN-flood;srcIPAddr(1017)=10.100.40.3;destIPAddr(1019)=10.100.30.253;atckSpeed(1047)=300;atckTime_cn(1048)=20190829232157
%Aug 29 23:21:59:394 2019 SW-01 SOCKET/6/TCP_SYNFLOOD: atckType(1016)=(05)SYN-flood;srcIPAddr(1017)=10.100.40.3;destIPAddr(1019)=10.100.30.253;atckSpeed(1047)=300;atckTime_cn(1048)=20190829232159
%Aug 29 23:22:00:200 2019 SW-01 SOCKET/6/TCP_SYNFLOOD: atckType(1016)=(05)SYN-flood;srcIPAddr(1017)=10.100.40.3;destIPAddr(1019)=10.100.30.253;atckSpeed(1047)=300;atckTime_cn(1048)=20190829232200
%Aug 29 23:22:53:747 2019 SW-01 PORTAL/6/PORTAL_USER_LOGOFF: -UserName=[test]-IPAddr=[10.100.30.1]-IfName=[Vlan-interface30]-VlanID=[30]-MACAddr=[342e-b6e8-d68d]-Reason=User Request-InputOctets=0-Output Octets=0-Input Gigawords=0-Output Gigawords=0;User logged off.
%Aug 29 23:22:56:977 2019 SW-01 PORTAL/6/PORTAL_USER_LOGON_SUCCESS: -UserName=[test]-IPAddr=[10.100.30.1]-IfName=[Vlan-interface30]-VlanID=[30]-MACAddr=[342e-b6e8-d68d]:User got online successfully.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
您好,在erg2中没有找到nat模式选择项,nat是默认开启的吗?
默认都是开的,除非人为关闭,配置参考:https://www.h3c.com/cn/d_201905/1189918_30005_0.htm#_Toc9931847
