WA4320X的模式问题
2019-09-02提问
  • 1收藏,1216浏览
粉丝:1人 关注:1人
WA4320X现在是胖的需要变成瘦的,官网上没有瘦版本的包,是不是命令就可以转换?
粉丝:95人 关注:1人
1.2  现网有AC的场景(命令行)
操作风险提示:AP胖切瘦有风险,操作不当或者意外断电会导致设备故障,操作需谨慎。当AC存在的场景下,我们推荐使用Ap-mode命令完成APFatFit的切换,在AP上执行该命令前,必须确认AC上的bin文件版本配套一致以及AC侧配置并使能了Dhcp server。当执行完命令后,APflash会被格式化,然后重启获得ip地址后在AC上下载对应版本。可以Telnet或者Console登入到命令行进行操作,具体操作过程如下所示,
//查看当前的bin文件,以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动输入。
<H3C>dir
Directory of flash:/
   0     -rw-   9124864  Apr 26 2000 18:14:29   wa2600a_fat.bin
15057 KB total (6144 KB free)
//配置模式切换命令
<H3C>ap-mode fit
 Change working mode will reboot system, do you want to continue? [Y/N]:y
 Change working mode to FIT now? [Y/N]:y
//从无线控制器上查看信息:APAC上获取ip地址
%Apr 26 18:21:20:262 2000 WX3024-AC DHCPS/5/DHCPS_ALLOCATE_IP: DHCP server information: Server IP = 192.168.0.1, DHCP client IP = 192.168.0.2, DHCP client hardware address = 7425-8a33-8170, DHCP client lease = 86400.
//AP开始从AC上下载bin文件
%Apr 26 18:21:24:788 2000 WX3024-AC LWPS/6/LWPS_IMG_DOWNLOAD_START:
Image download in progress for AP ap2.
#Apr 26 18:21:33:642 2000 WX3024-AC LWPS/4/Download Image Successfully:  Download Image Successfully:1.3.6.1.4.1.2011.10.2.75.2.3.0.14<h3cDot11APImgDwldSuccess> Serial Id:219801A0FH9136Q00287 AP Name:ap2 IP:192.168.0.2 Version:V100R001B01D001
%Apr 26 18:21:33:672 2000 WX3024-AC LWPS/6/LWPS_IMG_DOWNLOAD_COMPLETE:
 Image download process completed for AP ap2.
//这时AP已经下载完bin文件,重启中
%Apr 26 18:22:03:101 2000 WX3024-AC DHCPS/5/DHCPS_RECLAIM_IP: DHCP server information: Server IP = 192.168.0.1, DHCP client IP = 192.168.0.2, DHCP client hardware address = 7425-8a33-8170, DHCP client lease = 86400.
%Apr 26 18:23:23:841 2000 WX3024-AC DHCPS/5/DHCPS_ALLOCATE_IP: DHCP server information: Server IP = 192.168.0.1, DHCP client IP = 192.168.0.2, DHCP client hardware address = 7425-8a33-8170, DHCP client lease = 86400.
//AP切换为Fit模式后注册到AC
#Apr 26 18:23:28:381 2000 WX3024-AC LWPS/4/Tunnel Up:  Tunnel Up:1.3.6.1.4.1.2011.10.2.75.1.3.0.1<h3cDot11ACMtTunnelSetupTrap> Serial Id:219801A0FH9136Q00287 UpInfo:1 AP Name:ap2 IPv4:192.168.0.2 IPv6:-NA- FirstTrapTime:2291326 AP MAC:74:25:8A:33:81:70
#Apr 26 18:23:28:412 2000 WX3024-AC IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 12976129 is Up, ifAdminStatus is 1, ifOperStatus is 1
%Apr 26 18:23:28:432 2000 WX3024-AC LWPS/6/LWPS_AP_UP:
 Connection with AP ap2 goes operational.
%Apr 26 18:23:28:443 2000 WX3024-AC IFNET/3/LINK_UPDOWN: WLAN-DBSS10:3 link status is UP.
%Apr 26 18:23:28:453 2000 WX3024-AC IFNET/3/LINK_UPDOWN: WLAN-ESS10 link status is UP.
1.3  现网有AC的场景(Web
AC存在的场景下,也可以登入胖AP的浏览器界面进行形态切换,切换前,必须确认AC上的bin文件版本配套一致以及AC侧配置并使能了Dhcp server。当点击切换后,APflash会被格式化,然后重启获得Ip地址后在AC上下载对应版本。具体操作过程如下所示:
使用设备的默认ip192.168.0.50/24,账号和密码:admin/h3capadmin,登入WEB页面后,将设备从Fat AP模式切换为Fit AP模式。在导航栏中选择“高级设置〉 形态切换”,进入形态切换页面,如下图所示。单击<切换>按钮完成操作。
1.4  现网无AC同时AP本身有串口的场景(命令行)
当没有AC存在的场景下,如果AP本身有串口,我们根据不同的场景推荐可以使用以下方式完成胖瘦模式切换:
APflash足够大时,我们可以通过FTP或者TFTP方式将Fitbin文件上传到flash里,同时在命令行下通过boot-loader命令指定启动文件,然后Reboot完成切换。Fit的版本可以从官网上找到,找到无线控制器(wac360/361)的版本,下载压缩包,里面会包含相关APfit的版本
AP型号
文件名
H3C WAP621
wa2600a_fit.bin
H3C WAP722
wa4300_fit.bin
H3C WAP722E
H3C WAP722S
wa4300s_fit.bin
H3C WAP712C
H3C WAP712H
APflash只能容纳一个bin文件时,可以手工删除掉当前的版本文件,其余的操作参考:现网有AC的场景(命令行)。下面以Fat转为Fit例,通过配置boot-loader指定启动文件完成模式切换。先通过telnet或者console登入到胖ap命令行。
//查看当前的bin文件,,以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动输入。
<H3C>dir
   0     -rw-   6638592  Apr 26 2000 12:04:05   wa2600a_fat.bin
15057 KB total (8572 KB free)
电脑网卡设置为:192.168.0.1/ 255.255.255.0,设置和胖AP同一网段的Ip,如下例子打开TFTP服务器,把软件版本WA2600a_fit.bin放到电脑桌面上,TFTP服务器目录指向电脑桌面,如下例子然后点击确定
//采用TFTP上传bin文件,以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动输入。
<H3C>tftp 192.168.0.1 get wa2600a_fit.bin
  File will be transferred in binary mode
  Downloading file from remote TFTP server, please wait....................................................................................................................................................................................................................
//提示flash空间不足
  Failed to write data into storage device, maybe no enough space on device
<H3C>dir
//删除当前的Fit版本bin文件
< H3C>delete /unreserved ?
  STRING  [drive][path][file name]
  flash:  Device name
<ap2>delete /unreserved flash:/wa2600a_fat.bin
The contents cannot be restored!!! Delete flash:/wa2600a_fat.bin?[Y/N]:y
Deleting a file permanently will take a long time. Please wait...
%Delete file flash:/wa2600a_fat.bin...Done.
< H3C>dir
% Device can't be found or file can't be found in the directory
15057 KB total (15055 KB free)
//再次使用TFTP上传bin文件
< H3C>tftp 192.168.0.3 get wa2600a_fit.bin
  TFTP: 9124864 bytes received in 70 second(s)
  File downloaded successfully.
< H3C>dir
//指定boot-loader启动文件
< H3C>boot-loader file flash:/wa2600a_fit.bin
  This command will set the boot file. Continue? [Y/N]:y
  The specified file will be used as the boot file at the next reboot on slot 1!
//查看当前的boot-loader启动文件
< H3C>dis boot-loader
  The current boot app is: flash:/wa2600a_fat.bin
  The app that will boot upon reboot is: flash:/wa2600a_fit.bin
//执行reboot重启命令
< H3C>reboot
//这里提示是否保存配置时一定选择N
This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]: N
1.5  现网无AC同时AP本身有串口的场景(Bootrom
先通过console线进入bootrom菜单,具体的操作,参考《AP瘦切胖配置案例(Bootrom)》,需要把胖AP( fat)版本换成瘦APfit)版本通过tftp服务器上传加载。
1.6  现网无AC同时AP本身没有串口的场景
WAP722EWAP722没有console口,针对这种情况,不能使用ap-mode命令切换,一旦切换就无法现场恢复。建议此场景下,telnet到胖ap上后,删除flash里的app文件后上传新的bin文件,然后通过boot-loader指定启动文件后重启。如果dir发现flash里有startup.cfg的文件,建议删除后再执行reboot命令。因此在实际开局和维护时一定要格外注意。参考《现网无AC同时AP本身有串口的场景(命令行)》。
粉丝:17人 关注:18人
ap 用户视图下通过命令ap-mode fit将瘦ap切到fit模式,然后将ap插在ac上自动下版本,或者将ac上对应的该ap版本down下来,手动刷进去
