SecPath U200-M无法登录HTTP,HTTPS服务已开启同样无法使用
2019-09-03提问
  • 1收藏,1915浏览
 version 5.20, Feature 5123P36
 sysname BGW_security
 clock timezone BJ add 08:00:00
 password-control enable
 password-control length 8
 password-control composition type-number 3 type-length 4
 password-control login-attempt 5 exceed lock-time 60
 password-control complexity user-name check
 super password level 3 cipher OX2X55^%:H*^US3K"<C2<1!!
 undo voice vlan mac-address 00e0-bb00-0000
 domain default enable system
 ip http acl 2000
 undo alg dns
 undo alg rtsp
 undo alg h323
 undo alg sip
 undo alg sqlnet
 undo alg pptp
 undo alg ils
 undo alg nbt
 undo alg msn
 undo alg qq
 undo alg tftp
 undo alg sccp
 undo alg xdmcp
 undo alg rsh
acl number 2000
 rule 1 permit source 192.168.0.0 0.0.255.255
vlan 1
vlan 130
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
pki domain default
  crl check disable
user-group system
local-user admin
 authorization-attribute acl 2000
 service-type ssh terminal
local-user audit
 authorization-attribute level 3
 service-type portal
ssl server-policy default
 pki-domain default
interface NULL0
interface Vlan-interface130
 ip address 192.168.130.252 255.255.255.0
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/1
 port link-mode bridge
 port access vlan 130
interface GigabitEthernet0/2
 ip route-static 0.0.0.0 0.0.0.0 192.168.130.254
 info-center logbuffer size 1024
 info-center trapbuffer size 1024
 ntp-service authentication enable
 ntp-service authentication-keyid 99 authentication-mode md5 +L%+/Q"U&'QF5"6K6S_ZPQ!!
 ntp-service reliable authentication-keyid 99
 ntp-service unicast-server 192.168.130.253 authentication-keyid 99
 ssh server enable
 ssh user admin service-type stelnet authentication-type password
 ssh user audit service-type stelnet authentication-type password
 ip https acl 2000
 ip https ssl-server-policy default
 ip https enable
 load xml-configuration
user-interface con 0
 authentication-mode scheme
 set authentication password cipher OX2X55^%:H*^US3K"<C2<1!!
 idle-timeout 5 0
user-interface vty 0 4
 acl 2000 inbound
 idle-timeout 5 0
 protocol inbound ssh
return
 ip http acl 2000
 undo alg dns
 undo alg rtsp
 undo alg h323
 undo alg sip
 undo alg sqlnet
 undo alg pptp
 undo alg ils
 undo alg nbt
 undo alg msn
 undo alg qq
 undo alg tftp
 undo alg sccp
 undo alg xdmcp
 undo alg rsh
acl number 2000
vlan 1
vlan 130
domain system
 state active
 idle-cut disable
pki domain default
  crl check disable
user-group system
local-user admin
local-user audit
 service-type portal
 pki-domain default
interface NULL0
 ssh server enable
 ip https acl 2000
 ip https enable
 idle-timeout 5 0
 acl 2000 inbound
 idle-timeout 5 0
return
问题:
1.    ip http 服务开启 但用管理员账户无法登录,提示登录失败,用户权限3级,用户类型无http或https
2.    ip https服务请问可以使用设备自己生成ssl证书吗?也就是说设备本身可以做ca服务端自己生成ssl证书吗?请问如何配置,如何设置。。。我就来被它搞哭了
3.我这边要做等保2级,Http要关闭,https要开启,但本人对http和https的使用方法不是很清楚,请大牛求教
粉丝:8人 关注:0人
可以百度下有证书申请流程的
http如何救活?
牛叉neinei 发表时间:2019-09-03
寂东 九段
粉丝:225人 关注:3人
有没有将接口接入到trust域?然后做域间策略 ?如果从内网访问,trust--local permit any的策略,
我还不懂如何配置UTM,请问大牛我该如何配置
牛叉neinei 发表时间:2019-09-04
