路由器无法ping通192.168.60.2
2019-09-05提问
  • 1收藏,2816浏览
 version 7.1.064, Release 0615P13
 sysname ZWW_route
 clock timezone BJ add 08:00:00
 dhcp enable
 dhcp server always-broadcast
 dns proxy enable
 password-recovery enable
vlan 1
controller Cellular0/0
interface Aux0
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.1.30 255.255.255.0
 tcp mss 1280
 nat outbound
interface GigabitEthernet0/1
 ip address 192.168.110.253 255.255.255.0
 scheduler logfile size 16
line class aux
 authentication-mode scheme
 user-role network-admin
 set authentication password hash $h$6$beqGXgD2mcMcjp9+$Bax9zRCOOL33cvRyyj4lkU8lLk8YGn900Ok9JOy5JOnFuYqtiD4RzfRLCEhslqZ1or10O3GOcB2AdWuqCIGw2Q==
 idle-timeout 5 0
line class tty
 user-role network-operator
 set authentication password hash $h$6$UFowPiTdu/mXBWML$D0deqFlGLYhiYrdEqE4wPdeSS2fM3LpNB4DhgCtS15D7RjPJYW7cvTicksf/ExccHVC5W1btHQDaJ7NZt/9ZAA==
 idle-timeout 5 0
line class usb
 set authentication password hash $h$6$mUd4KEUK1MO2mJ8/$n179k0PcnrB0knXqjhr+5XnWZCpdOqJDPq4on6XyCc/9jte/G51jAHf5eXhi6ygqtth7rR6/WjF6/uoiDSFucA==
 idle-timeout 5 0
line class vty
 set authentication password hash $h$6$Nh32Q61mkl1nT3sB$alY7JRIpq+8M4Mjc63m5Ullhnzlnh1zx0wvmNwU4m9NFOVXgNvlT4sq1140MRfYDNFbA6u1tThf/EacKw2VEbA==
 protocol inbound ssh
 idle-timeout 5 0
line aux 0
 set authentication password hash $h$6$NxyS3+vCDnH6pN/O$Ihm0ofmimmKcStFBHFz8qgFw5q/AahikKEvsbL8QBdijwNJ3YqprlvHFCXdLlyY0zx3wKkt6j/jHaMn2dRw1UQ==
 idle-timeout 5 0
line vty 0 4
 set authentication password hash $h$6$PC8r+11bOvzajRMN$aY10527msd2Qg6NorXTbXaQ/zE6y7aY9A8hDkgY/Tr9Hv9jGIBbuLX/trr7KHTkYyR0jz6pcFS02TT56IAykLw==
 idle-timeout 5 0
line vty 5 63
 set authentication password hash $h$6$cHZE86Ln/oJNJqDb$HCXoYdMvm/IB1eT4SB8oT12L0aKcaoytYo+dVqGRI+C79F2isgXgPsh4yqLT2Iw5EVLb+1/xxldAcXBPr4iG5g==
 idle-timeout 5 0
 ip route-static 0.0.0.0 0 GigabitEthernet0/0 192.168.1.1
 ip route-static 192.168.60.0 24 GigabitEthernet0/1 192.168.110.254
 info-center logbuffer size 1024
 info-center security-logfile enable
 ssh server enable
 ssh server acl 2000
 ftp client source ip 192.168.60.5
 ntp-service enable
 ntp-service unicast-server 10.1.1.1
acl basic 2000
 rule 1 permit source 192.168.0.0 0.0.255.255
 password-control enable
 password-control length 8
 password-control composition type-number 3 type-length 4
 password-control login-attempt 5 exceed lock-time 60
 password-control update-interval 0
 password-control login idle-time 0
 password-control complexity user-name check
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 service-type ssh terminal
 authorization-attribute user-role level-0
local-user audit class manage
wlan global-configuration
wlan ap-group default-group
return
寂东 九段
粉丝:225人 关注:3人
 根据这条静态路由,ip route-static 192.168.60.0 24 GigabitEthernet0/1 192.168.110.254
如果你windown系统已经关闭防火墙,那么您ping下 192.168.110.254  这个地址通不通,估计可能没有做回程路由,设置下回程路由:
ip route-static  192.168.110.0 24 x.x.x.x
192.168.110.254 这个可以ping通的···就是ping不同192.168.110.253路由器
牛叉neinei 发表时间:2019-09-08
粉丝:10人 关注:1人
带源PING一下
电脑防火墙关闭测试
防火墙已经关闭····带源ping都不可以
牛叉neinei 发表时间:2019-09-05
牛叉neinei 知了小白
