WA4320H刷云AP
2019-09-11提问
  • 1收藏,1637浏览
照官网教程 刷引导  导入固件 然后切换云AP  reboot 以后 就  一直  starting...     然后重启就变 成
下图
 Ctrl+B 这样   怎么搞?
粉丝:2人 关注:0人
在使用绿洲云升级云AP时,需要提前将设备版本放到绿洲服务器上,并手动填写设备版本号,注意版本号的正确性。
在bootware下进行升级(可以参考下) 1、 在设备重启过程中按ctrl+B键,进入bootware 2、 依次按照如下步骤进行升级 首先选3,进入以太菜单 接着,选5进入ftp或者tftp,配置ftp或者tftp服务器,拷贝版本 下一步,选2,更新主版本文件 接下来,版本解压完成后,退回到主菜单,并重启设备,即可完成版本更新 BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Password recovery capability is enabled. Note: The current operating device is flash Enter < Storage Device Operation > to select device. ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): 3 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 5 ==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :ftp -------------------------------选择通过ftp或者tftp拷贝版本,本例选择ftp Load File Name :wa5300-fat.ipe------------------要拷贝的版本名字 : Target File Name :wa5300-fat.ipe -------------------拷贝到设备上后的文件命名,可根据需要修改 : Server IP Address :5.0.0.157 5.0.0.184 --------ftp server的地址 Local IP Address :105.1.108.152 5.0.0.157 ------------设备ip地址 Subnet Mask :0 Gateway IP Address :0 FTP User Name :123 123 ---------------------ftp 用户名 FTP User Password :****** ****** --------------------ftp密码 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading..................................................................... ............................................................................ ............................................................................ .............................................................Done. 40704000 bytes downloaded! The file is exist,will you overwrite it? [Y/N]Y Image file wa5300-fat-boot.bin is self-decompressing... Saving file flash:/wa5300-fat-boot.bin ..............................Done. Image file wa5300-fat-system.bin is self-decompressing... Saving file flash:/wa5300-fat-system.bin ................................... ............................................................................ ....................................................Done. ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 0 ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): 0 System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extended BootWare
zhiliaoqiang 发表时间:2019-09-11
原来 BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... starting... 这样就启动可以使用了。。。。。。
zhiliao_qkcLg 发表时间:2019-09-12
zhiliao_w71vUQ 知了小白
为啥不刷胖模式啊
