WX3010E重置之后找不到AP
2019-09-12提问
  • 1收藏,1069浏览
公司有一台用过的WX3010E,重置之后打算重新设置,参照官网PSK配置举例来进行配置,配置好之后发现手动配置的AP无法注册,自动发现也看不到AP上线,不知道什么原因,望解答
(顺便想问一下重置后会不会清除入license?好像说是出厂默认12个,这12个是不是要导入license才能用还是不用导入都能用基本的12个AP?重置之前AP能正常注册,AP型号是WA2620 FIT,现在一直在绿灯和红灯之间切换)
刚哥 九段
粉丝:21人 关注:13人
该设备默认支持AP数量为12,指的是不安装任何License时设备支持的AP数。
AP无法上线先检查链路是否存在故障,若没有,最好发一下配置,以及抓包看一下,AP注册在哪一步失败。
AC的配置是 version 5.20, Release 3308P18 # sysname AC # domain default enable system # telnet server enable # port-security enable # oap management-ip 192.168.0.101 slot 0 # password-recovery enable # vlan 1 # vlan 100 # domain system access-limit disable state active idle-cut disable self-service-url disable # dhcp server ip-pool 1 network 172.16.8.0 mask 255.255.255.0 gateway-list 172.16.8.1 # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$nmBMe/uKDpkC4Xtv6LT2J3/1dyLYc5D+ authorization-attribute level 3 service-type telnet # wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54 # wlan service-template 1 crypto ssid office bind WLAN-ESS 1 cipher-suite tkip security-ie wpa # interface Bridge-Aggregation1 # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.100 255.255.255.0 # interface Vlan-interface100 ip address 172.16.8.1 255.255.255.0 # interface GigabitEthernet1/0/1 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 port trunk pvid vlan 100 port link-aggregation group 1 # interface GigabitEthernet1/0/2 port link-aggregation group 1 # interface WLAN-ESS1 port link-type hybrid undo port hybrid vlan 1 port hybrid vlan 100 untagged port hybrid pvid vlan 100 mac-vlan enable port-security port-mode psk port-security preshared-key pass-phrase cipher $c$3$o1jrlBnKIVhr5s6BS5Ck3pQsBWo5Ifz/2Gsp # wlan ap office-ap1 model WA2620 id 1 serial-id 219801A0D1C123007748 radio 1 service-template 1 radio enable radio 2 # dhcp enable # load xml-configuration # user-interface con 0 user-interface vty 0 4 authentication-mode scheme user privilege level 3 switch的配置是 # version 5.20, Release 3308P17 # sysname switch # domain default enable system # telnet server enable # oap management-ip 192.168.0.100 slot 1 # password-recovery enable # vlan 1 # vlan 100 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system # local-user admin password cipher $c$3$iRdnkOvKPfWazqH+htD/goGNnvihCGB3 authorization-attribute level 3 service-type telnet # interface Bridge-Aggregation1 # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.101 255.255.255.0 # interface GigabitEthernet1/0/1 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 port trunk pvid vlan 100 poe enable # interface GigabitEthernet1/0/2 port access vlan 100 poe enable # interface GigabitEthernet1/0/3 poe enable # interface GigabitEthernet1/0/4 poe enable # interface GigabitEthernet1/0/5 poe enable # interface GigabitEthernet1/0/6 poe enable # interface GigabitEthernet1/0/7 poe enable # interface GigabitEthernet1/0/8 poe enable # interface GigabitEthernet1/0/9 # interface GigabitEthernet1/0/10 # interface GigabitEthernet1/0/11 port link-aggregation group 1 # interface GigabitEthernet1/0/12 port link-aggregation group 1 # user-interface aux 0 user-interface vty 0 4 authentication-mode scheme user-interface vty 5 15 #
cleanestelm2790 发表时间:2019-09-12
才发现评论不会自动换行.... 不好意思....
寂东 九段
粉丝:225人 关注:3人
1,ap注册问题,这个问题纯粹是配置问题,检查下ap到ac的二层或三层网络连通性,连接ap的网口插在终端上是否能获取到ip地址?ap注册需要一个单独的vlan且开启dhcp,互联端口的链路上放通该vlan
2,license问题,这款ac默认带12个授权,重置只是重置设备,不会影响到授权,没关系
粉丝:1人 关注:2人
1 ap管理地址从哪里获取
2 ac地址要与ap在一个地址段
ac与交换机连接配置truck口方通所以vlan
隧道加密改下
