请教S5130-28S-EI 密码恢复问题
2019-09-15提问
  • 1收藏,1143浏览
请教S5130-28S-EI 密码恢复问题,按ctrl b进入恢复模式只有如下功能。请教有什么方法可以恢复密码?
Enter your choice(0-1):
 BASIC BOOT MENU
1. Update full BootRom
2. Update extended BootRom
3. Update basic BootRom
4. Boot extended BootRom
0. Reboot Ctrl+U: Access BASIC ASSISTANT MENU
粉丝:10人 关注:1人
ctrl+b进去不止这些吧?应该有个跳过当前配置选项啊
通过conlse线crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl+B”时候快速按住“Ctrl+B” 进入botroom菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl+B”进入如下菜单。选择<6> Skip Current System Configuration跳过当前配置启动,不同设备可能不是数字6
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6
Flag Set Success.
然后输入0重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press ENTER to get started.
3.2 如果不需要之前的配置信息的话
操作步骤:跳过启动文件后直接保存当前配置,再重启。
<H3C>save
The current configuration will be written to the device. Are you sure? [Y/N]:y
Please input the file name(*.cfg)[flash:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):(输入回车)
flash:/startup.cfg exists, overwrite? [Y/N]:y
Validating file. Please wait...
Configuration is saved to device successfully.
<H3C>reboot
Start to check configuration with next startup configuration file, please wait.........DONE!
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
This command will reboot the device. Continue? [Y/N]:y
刚刚发的就是ctrl b的结果。确实就这么多,不清楚是不是这个型号就这样。
zhiliao_QldbB 发表时间:2019-09-15
回复zhiliao_QldbB:
升级个最新版本试试呢?
zhiliao_N5PuY 发表时间:2019-09-15
寂东 九段
粉丝:225人 关注:3人
你这是进入了基础bootrom菜单,不是bootrom主菜单,在bootrom主菜单,应该有选项:
Skip Current System Configuration   选择这项,进入系统后,将配置文件(默认是startup.cfg)down下来,改掉密码部分,再上传,密码就改掉了,配置不变
