MSR3620 与锐捷设备对接ipsec vpn debug 信息
2019-09-16提问
  • 1收藏,1352浏览
Ping 10.10.10.10 (10.10.10.10) from 10.255.245.254: 56 data bytes, press CTRL_C to break
 *Sep 16 14:32:42:889 2019 UNSTABLE_7164 IPSEC/7/EVENT: Found block-flow node.
*Sep 16 14:32:42:889 2019 UNSTABLE_7164 IPSEC/7/PACKET:
Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536.
*Sep 16 14:32:42:889 2019 UNSTABLE_7164 IPSEC/7/ERROR:
 The reason of dropping packet is no available IPsec tunnel.
*Sep 16 14:32:45:090 2019 UNSTABLE_7164 IPSEC/7/EVENT:
*Sep 16 14:32:45:090 2019 UNSTABLE_7164 IPSEC/7/PACKET:
*Sep 16 14:32:45:090 2019 UNSTABLE_7164 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel.
 *Sep 16 14:32:45:910 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Retransmit phase 1 packet.
*Sep 16 14:32:45:910 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/500
Sending packet to 119.51.91.90 remote port 500, local port 500.
 I-COOKIE: ee348a891cbb92ab
 R-COOKIE: 7b38fffb056475f0
 next payload: ID
 version: ISAKMP Version 1.0
 exchange mode: Main
 flags: ENCRYPT
 message ID: 0 l
ength: 92
*Sep 16 14:32:45:910 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/500 Sending an IPv4 packet. *Sep 16 14:32:45:911 2019 UNSTABLE_7164 IKE/7/EVENT: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/500 Sent data to socket successfully.
*Sep 16 14:32:45:939 2019 UNSTABLE_7164 IKE/7/EVENT: Received packet successfully.
*Sep 16 14:32:45:939 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/500
Received packet from 119.51.91.90 source port 500 destination port 500.
 next payload: NOTIFY
 exchange mode: Info
 flags:
 message ID: 0
 length: 44
*Sep 16 14:32:45:939 2019 UNSTABLE_7164 IKE/7/EVENT: IKE thread 1099247506096 processes a job.
*Sep 16 14:32:45:939 2019 UNSTABLE_7164 IKE/7/EVENT: Info packet process started.
 *Sep 16 14:32:45:939 2019 UNSTABLE_7164 IKE/7/EVENT: Received informational exchange packet, but IKE SA is inexistent or incomplete.
 *Sep 16 14:32:47:291 2019 UNSTABLE_7164 IPSEC/7/EVENT: Found block-flow node.
*Sep 16 14:32:47:291 2019 UNSTABLE_7164 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536.
*Sep 16 14:32:47:291 2019 UNSTABLE_7164 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel.
 *Sep 16 14:32:48:429 2019 UNSTABLE_7164 IKE/7/EVENT: Received Nat travel packet.
*Sep 16 14:32:48:429 2019 UNSTABLE_7164 IKE/7/EVENT: Received packet successfully.
*Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Received packet from 119.51.91.90 source port 4500 destination port 4500.
 I-COOKIE: a0d7b1cba26bc066
 R-COOKIE: 121525478a0d85e1
 next payload: HASH
 exchange mode: Info
 flags: ENCRYPT
 message ID: fde3692
 length: 84
*Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/EVENT: IKE thread 1099247506096 processes a job.
*Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/EVENT: Info packet process started.
*Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Decrypt the packet.
 *Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Received ISAKMP Hash Payload.
*Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Received ISAKMP Notification Payload.
*Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Parse informational exchange packet successfully.
*Sep 16 14:32:48:430 2019 UNSTABLE_7164 IKE/7/EVENT: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Notification R_U_THERE is received.
*Sep 16 14:32:48:431 2019 UNSTABLE_7164 IKE/7/DPD: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 DPD packet with sequence number 21006 is received, COOKIEs(i/r) a0d7b1cba26bc066/121525478a0d85e1.
*Sep 16 14:32:48:431 2019 UNSTABLE_7164 IKE/7/EVENT: Sending DPD packet of type R_U_THERE_ACK with sequence number 21006.
 *Sep 16 14:32:48:431 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Encrypt the packet.
*Sep 16 14:32:48:431 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Construct notification packet: R_U_THERE_ACK.
*Sep 16 14:32:48:431 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Sending packet to 119.51.91.90 remote port 4500, local port 4500.
 next payload: HASH
exchange mode: Info
 flags: ENCRYPT
 message ID: 5843da64
 length: 84
*Sep 16 14:32:48:431 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Sending an IPv4 packet.
*Sep 16 14:32:48:431 2019 UNSTABLE_7164 IKE/7/EVENT: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/4500 Sent data to socket successfully. Request time out
*Sep 16 14:32:49:492 2019 UNSTABLE_7164 IPSEC/7/EVENT: Found block-flow node.
*Sep 16 14:32:49:492 2019 UNSTABLE_7164 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536.
*Sep 16 14:32:49:492 2019 UNSTABLE_7164 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. Request time out
*Sep 16 14:32:51:579 2019 UNSTABLE_7164 IKE/7/EVENT: Received packet successfully.
*Sep 16 14:32:51:579 2019 UNSTABLE_7164 IKE/7/EVENT: Ignore NAT keepalive packet.
*Sep 16 14:32:51:580 2019 UNSTABLE_7164 IKE/7/EVENT: Received packet successfully.
*Sep 16 14:32:51:580 2019 UNSTABLE_7164 IKE/7/EVENT: Ignore NAT keepalive packet.
*Sep 16 14:32:51:693 2019 UNSTABLE_7164 IPSEC/7/EVENT: Found block-flow node.
*Sep 16 14:32:51:693 2019 UNSTABLE_7164 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536.
*Sep 16 14:32:51:693 2019 UNSTABLE_7164 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel.
Sep 16 14:32:53:895 2019 UNSTABLE_7164 PING/6/PING_STATISTICS: Ping statistics for 10.10.10.10: 5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss.
*Sep 16 14:32:55:400 2019 UNSTABLE_7164 IKE/7/EVENT: Received packet successfully.
*Sep 16 14:32:55:400 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/500 Received packet from 119.51.91.90 source port 500 destination port 500.
 next payload: KE
 version: ISAKMP
Version 1.0 exchange
mode: Main
 flags: message
 length: 220 *
Sep 16 14:32:55:400 2019 UNSTABLE_7164 IKE/7/EVENT: IKE thread 1099247506096 processes a job.
*Sep 16 14:32:55:400 2019 UNSTABLE_7164 IKE/7/EVENT: Phase1 process started. *Sep 16 14:32:55:400 2019 UNSTABLE_7164 IKE/7/PACKET: vrf = 0, local = 111.26.220.26, remote = 119.51.91.90/500
粉丝:24人 关注:1人
这个不是刚刚答过了?
