无线不稳定,速度慢,客户端反复上下线
  • 1收藏,2498浏览
无线非常不稳定,速度很慢,从日志里面看,客户端会反复上下线。相同设备下,有线就很稳定,速度也快。另外,AC 上面空间不足,无法升级系统,插入的 U 盘(FAT)也无法识别。日志如下:
报告
Detected client IP change: Client MAC: c498-8052-05c1, IP: 192.168.88.13, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 1, Channel number: 52, SSID: YC, BSSID: 782c-2900-8130.
2019-09-20 11:12:03
报告
Client c498-8052-05c1 went offline from BSS 782c-2900-8140 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:12:03
报告
Client c498-8052-05c1 roamed from BSSID 782c-2900-8140 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8130 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:12:03
报告
Client c498-8052-05c1 went online from BSS 782c-2900-8130 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:12:03
报告
Detected client IP change: Client MAC: c498-8052-05c1, IP: 192.168.88.13, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 2, Channel number: 149, SSID: YC, BSSID: 782c-2900-8140.
2019-09-20 11:11:51
报告
Client c498-8052-05c1 went offline from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:11:51
报告
Client c498-8052-05c1 roamed from BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8140 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:11:51
报告
Client c498-8052-05c1 went online from BSS 782c-2900-8140 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:11:51
报告
Detected client IP change: Client MAC: 488a-d29e-95f4, IP: 192.168.88.73, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 3, Channel number: 3, SSID: YC, BSSID: 782c-2900-8150.
2019-09-20 11:11:10
报告
Client 488a-d29e-95f4 went online from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:11:10
报告
Client 488a-d29e-95f4 went offline from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=6
2019-09-20 11:11:09
报告
Detected client IP change: Client MAC: c498-8052-05c1, IP: 192.168.88.13, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 3, Channel number: 3, SSID: YC, BSSID: 782c-2900-8150.
2019-09-20 11:10:33
报告
Client c498-8052-05c1 went offline from BSS 782c-2900-8130 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:10:33
报告
Client c498-8052-05c1 roamed from BSSID 782c-2900-8130 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:10:33
报告
Client c498-8052-05c1 went online from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:10:33
报告
Client f838-8036-38d1 went offline from BSS 782c-2900-8140 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:10:06
报告
Client f838-8036-38d1 roamed from BSSID 782c-2900-8140 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:10:06
报告
Client f838-8036-38d1 went online from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:10:06
报告
Detected client IP change: Client MAC: f838-8036-38d1, IP: 192.168.88.221, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 3, Channel number: 3, SSID: YC, BSSID: 782c-2900-8150.
2019-09-20 11:10:06
报告
Client f838-8036-38d1 went offline from BSS 782c-2900-8130 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:10:01
报告
Client f838-8036-38d1 roamed from BSSID 782c-2900-8130 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8140 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:10:01
报告
Client f838-8036-38d1 went online from BSS 782c-2900-8140 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:10:01
报告
Detected client IP change: Client MAC: f838-8036-38d1, IP: 192.168.88.221, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 2, Channel number: 149, SSID: YC, BSSID: 782c-2900-8140.
2019-09-20 11:10:01
报告
Detected client IP change: Client MAC: f838-8036-38d1, IP: 192.168.88.221, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 1, Channel number: 52, SSID: YC, BSSID: 782c-2900-8130.
2019-09-20 11:09:58
报告
Client f838-8036-38d1 went offline from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:09:58
报告
Client f838-8036-38d1 roamed from BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8130 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:09:58
报告
Client f838-8036-38d1 went online from BSS 782c-2900-8130 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:09:58
报告
2019-09-20 11:09:54
报告
2019-09-20 11:09:52
报告
Client f00f-ec42-6c58 went offline from BSS 782c-2900-8141 with SSID YC-GUEST on AP ap-01. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=3
2019-09-20 11:09:19
报告
Detected client IP change: Client MAC: c498-8036-ba80, IP: 192.168.88.37, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 3, Channel number: 3, SSID: YC, BSSID: 782c-2900-8150.
2019-09-20 11:09:09
报告
Client c498-8036-ba80 went offline from BSS 782c-2900-8140 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:09:09
报告
Client c498-8036-ba80 roamed from BSSID 782c-2900-8140 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:09:09
报告
Client c498-8036-ba80 went online from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:09:09
报告
Client f00f-ec42-6c58 went online from BSS 782c-2900-8141 with SSID YC-GUEST on AP ap-01. State changed to Run.
2019-09-20 11:08:43
报告
Detected client IP change: Client MAC: 7c94-2a21-4c8c, IP: 192.168.88.238, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 2, Channel number: 149, SSID: YC, BSSID: 782c-2900-8140.
2019-09-20 11:08:16
报告
Client 7c94-2a21-4c8c went offline from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:08:16
报告
Client 7c94-2a21-4c8c roamed from BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8140 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:08:16
报告
Client 7c94-2a21-4c8c went online from BSS 782c-2900-8140 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:08:16
报告
Client fc2a-9cf3-fef4 went offline from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:08:06
报告
Client fc2a-9cf3-fef4 roamed from BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8130 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:08:06
报告
Client fc2a-9cf3-fef4 went online from BSS 782c-2900-8130 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:08:06
报告
Detected client IP change: Client MAC: fc2a-9cf3-fef4, IP: 192.168.88.28, -NA-, -NA-, -NA-, Username: -NA-, AP name: ap-01, Radio ID: 1, Channel number: 52, SSID: YC, BSSID: 782c-2900-8130.
2019-09-20 11:08:06
报告
2019-09-20 11:07:58
报告
2019-09-20 11:07:21
报告
Client a45e-60c0-e42f went offline from BSS 441a-fa2d-e090 with SSID YC on AP ap-02. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=8
2019-09-20 11:07:16
报告
2019-09-20 11:06:28
报告
2019-09-20 11:06:28
报告
Client c498-8052-05c1 roamed from BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8130 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:06:28
报告
2019-09-20 11:06:28
报告
2019-09-20 11:02:47
报告
2019-09-20 11:02:47
报告
2019-09-20 11:02:47
报告
2019-09-20 11:02:47
报告
Client 5433-cbd6-74d0 went offline from BSS 782c-2900-8150 with SSID YC on AP ap-01. State changed to Unauth. Reason:Successfully roamed to another BSS.
2019-09-20 11:02:23
报告
Client 5433-cbd6-74d0 roamed from BSSID 782c-2900-8150 on AP ap-01 of AC IP 127.0.0.1 to BSSID 782c-2900-8140 on AP ap-01 of AC IP 127.0.0.1 successfully.
2019-09-20 11:02:23
报告
Client 5433-cbd6-74d0 went online from BSS 782c-2900-8140 with SSID YC on AP ap-01. State changed to Run.
2019-09-20 11:02:23
从警告日志中看,似乎有无线攻击,不确定是否是因为攻击导致的问题
通知
-VSD=level-global-441a-fa2d-e080; RTS flood detected.
2019-09-20 11:12:01
通知
-VSD=level-global-441a-fa2d-e080; BlockAck flood detected.
2019-09-20 11:10:01
通知
-VSD=level-global-782c-2900-8130; Probe request flood detected.
2019-09-20 11:09:21
通知
-VSD=level-global-782c-2900-8130; CTS flood detected.
2019-09-20 11:08:58
通知
-VSD=level-global-441a-fa2d-e080; Probe request flood detected.
2019-09-20 11:05:15
通知
-VSD=level-global-782c-2900-8130; BlockAck flood detected.
2019-09-20 11:04:17
通知
-VSD=level-global-782c-2900-8130; Null data flood detected.
2019-09-20 11:04:06
通知
-VSD=level-global-782c-2900-8130; RTS flood detected.
2019-09-20 11:03:15
通知
-VSD=level-global-782c-2900-8130-SrcMAC=645a-ed1a-06f1; Unauthorized client detected by radio 3 of sensor ap-01 on channel 11(RSSI: 38).
2019-09-20 11:03:09
通知
-VSD=level-global-441a-fa2d-e080; CTS flood detected.
2019-09-20 11:02:39
通知
2019-09-20 11:01:53
通知
-VSD=level-global-441a-fa2d-e080; Beacon flood detected.
2019-09-20 11:01:47
通知
System stratum changed from 4 to 3 after clock update.
2019-09-20 11:01:45
通知
2019-09-20 10:59:37
通知
2019-09-20 10:59:20
通知
2019-09-20 10:58:29
通知
-VSD=level-global-782c-2900-8130-SrcMAC=40b8-9af6-df4d; Unauthorized client detected by radio 3 of sensor ap-01 on channel 11(RSSI: 38).
2019-09-20 10:56:23
通知
-VSD=level-global-441a-fa2d-e080; Null data flood detected.
2019-09-20 10:56:02
通知
-VSD=level-global-441a-fa2d-e080-SrcMAC=9c2e-a133-a64f; Unauthorized client detected by radio 2 of sensor ap-02 on channel 11(RSSI: 29).
2019-09-20 10:55:54
通知
2019-09-20 10:55:14
通知
System stratum changed from 3 to 4 after clock update.
2019-09-20 10:54:08
通知
2019-09-20 10:54:04
通知
2019-09-20 10:54:03
通知
2019-09-20 10:53:06
通知
-VSD=level-global-782c-2900-8130-SrcMAC=e447-90c2-a517; AP spoofing client detected.
2019-09-20 10:52:35
通知
2019-09-20 10:52:26
通知
2019-09-20 10:51:44
AC : MSG360-4-PWR  旁挂模式
AP : WAP723-W2,WAP712C  瘦AP
粉丝:10人 关注:1人
MSG升级最新版本看下,空间不足,可以先删除之前的版本文件(注:此时一定不要重启设备或者设备意外断电!!!),上传最新版本后再加载就行
请问哪些是版本文件?
Jeff-谢言付 发表时间:2019-09-20
Jeff-谢言付 知了小白
多谢!请问哪些文件可以删除?
zhiliao_gTEYB8 知了小白
apimage里头的
