S5560 下联二层 出现一个下联的二层无法获取到IP,
2019-09-20提问
  • 1收藏,1140浏览
Royann 零段
S5560 每个端口都做了vlan,前1-6个端口分别下联二层交换,其他端口作1个VLAN 供服务器组使用。
前一周突然出现部分断网,查找发现有一台二层交换下的设备无法获取到IP,测试二层无法ping通,无法登录,当时认为是二层问题,重置后 导入配置,显示成功,重启后 查看配置是没有的,折腾多次都没用,后续直接当傻瓜交换机,不要任何配置,接在其他二层上 却能正常使用。
后续华三工程师让我测试下 三层是否能获取到地址, 结果不管是下联二层接口 还是服务器组端口 都无法获取到ip, 我连接到服务器vlan  手动ip也无法上网,然后 华三工程师怀疑是三层故障问题,当时也把三层配置给他看过 没发现问题。刚刚打完华三电话 准备提个单子, 结果刚过保 不支持电话。。。。。 大佬们给看看是啥原因,
配置如下:
sysname 核心交换机
clock timezone Lisbon add 00:00:00
clock protocol ntp
telnet server enable
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
dhcp enable
dhcp server forbidden-ip 192.168.29.240 192.168.29.250
lldp global enable
password-recovery enable
vlan 1
description luyouqihulian
vlan 2
description guanliwangluo
vlan 11
description neibufuwuqi
vlan 18
description xiangmutuozhan
vlan 19
description shangguanzhongxin
vlan 20
description zhanluezhaoshang
vlan 21
description touzizhongxin
vlan 22
description fawuzhongxin
vlan 23
description caiwuzhongxin
vlan 24
description renshixingzhen
vlan 25
description shuzihuakejizhongxin
vlan 26
description pinpaizhongxin
vlan 27
description yingxiaozhongxin
vlan 28
description huiyishi
vlan 29
description wuxian1
vlan 30
description wuxian2
vlan 31
description yuliu1
vlan 32
description yuliu2
vlan 33
description yuliu3
vlan 34
description yuliu4
vlan 35
description yuliu5
vlan 36
description dayinji
vlan 66
description zhongxinzongfuzeren
stp global enable
dhcp server ip-pool caiwuzhongxin
gateway-list 172.16.23.1
network 172.16.23.0 mask 255.255.255.0
dns-list 202.96.209.133 202.96.209.5
dhcp server ip-pool dayinji
gateway-list 172.16.36.1
network 172.16.36.0 mask 255.255.255.0
dhcp server ip-pool fawuzhongxin
gateway-list 172.16.22.1
network 172.16.22.0 mask 255.255.255.0
dhcp server ip-pool huiyishi
gateway-list 172.16.28.1
network 172.16.28.0 mask 255.255.255.0
dhcp server ip-pool pinpaizhongxin
gateway-list 172.16.26.1
network 172.16.26.0 mask 255.255.255.0
dhcp server ip-pool renshixinzhengzhongxin
gateway-list 172.16.24.1
network 172.16.24.0 mask 255.255.255.0
dhcp server ip-pool shangguanzhongxin
gateway-list 172.16.19.1
network 172.16.19.0 mask 255.255.255.0
dhcp server ip-pool shuzihuakeji
gateway-list 172.16.25.1
network 172.16.25.0 mask 255.255.255.0
dhcp server ip-pool touzizhongxin
gateway-list 172.16.21.1
network 172.16.21.0 mask 255.255.255.0
dhcp server ip-pool wuxian1
gateway-list 172.16.29.1
network 172.16.29.0 mask 255.255.255.0
expired day 0 hour 1
static-bind ip-address 172.16.29.126 mask 255.255.255.0 hardware-address b46d-8398-1f70
static-bind ip-address 172.16.29.198 mask 255.255.255.0 hardware-address 0180-5e4f-1cd7-ca
static-bind ip-address 172.16.29.245 mask 255.255.255.0 hardware-address 9ce8-9594-9a51
dhcp server ip-pool wuxian2
gateway-list 172.16.30.1
network 172.16.30.0 mask 255.255.255.0
dhcp server ip-pool xiangmutuozhanzhongxin
gateway-list 172.16.18.1
network 172.16.18.0 mask 255.255.255.0
dhcp server ip-pool yingxiaozhongxin
gateway-list 172.16.27.1
network 172.16.27.0 mask 255.255.255.0
dhcp server ip-pool yuliu1
gateway-list 172.16.31.1
network 172.16.31.0 mask 255.255.255.0
dhcp server ip-pool yuliu2
gateway-list 172.16.32.1
network 172.16.32.0 mask 255.255.255.0
dhcp server ip-pool yuliu3
gateway-list 172.16.33.1
network 172.16.33.0 mask 255.255.255.0
dhcp server ip-pool yuliu4
gateway-list 172.16.34.1
network 172.16.34.0 mask 255.255.255.0
dhcp server ip-pool yuliu5
gateway-list 172.16.35.1
network 172.16.35.0 mask 255.255.255.0
dhcp server ip-pool zhanluezhaoshang
gateway-list 172.16.20.1
network 172.16.20.0 mask 255.255.255.0
dhcp server ip-pool zhongxinzongfuzeren
gateway-list 172.16.66.1
network 172.16.66.0 mask 255.255.255.0
interface NULL0
interface Vlan-interface2
ip address 172.16.2.1 255.255.255.0
interface Vlan-interface11
ip address 172.16.11.1 255.255.255.0
interface Vlan-interface18
ip address 172.16.18.1 255.255.255.0
interface Vlan-interface19
ip address 172.16.19.1 255.255.255.0
interface Vlan-interface20
ip address 172.16.20.1 255.255.255.0
interface Vlan-interface21
ip address 172.16.21.1 255.255.255.0
interface Vlan-interface22
ip address 172.16.22.1 255.255.255.0
interface Vlan-interface23
ip address 172.16.23.1 255.255.255.0
interface Vlan-interface24
ip address 172.16.24.1 255.255.255.0
interface Vlan-interface25
ip address 172.16.25.1 255.255.255.0
interface Vlan-interface26
ip address 172.16.26.1 255.255.255.0
interface Vlan-interface27
ip address 172.16.27.1 255.255.255.0
interface Vlan-interface28
ip address 172.16.28.1 255.255.255.0
interface Vlan-interface29
ip address 172.16.29.1 255.255.255.0
interface Vlan-interface30
ip address 172.16.30.1 255.255.255.0
interface Vlan-interface31
ip address 172.16.31.1 255.255.255.0
interface Vlan-interface32
ip address 172.16.32.1 255.255.255.0
interface Vlan-interface33
ip address 172.16.33.1 255.255.255.0
interface Vlan-interface34
ip address 172.16.34.1 255.255.255.0
interface Vlan-interface35
ip address 172.16.35.1 255.255.255.0
interface Vlan-interface36
ip address 172.16.36.1 255.255.255.0
interface Vlan-interface66
ip address 172.16.66.1 255.255.255.0
interface FortyGigE1/0/29
port link-mode bridge
interface FortyGigE1/0/30
interface GigabitEthernet1/0/24
port link-mode route
description shanglianluyouqi
ip address 172.16.1.2 255.255.255.0
port link-type trunk
port trunk permit vlan all
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
port access vlan 11
interface GigabitEthernet1/0/8
port access vlan 11
interface GigabitEthernet1/0/9
port access vlan 11
interface GigabitEthernet1/0/10
port access vlan 11
interface GigabitEthernet1/0/11
port access vlan 11
interface GigabitEthernet1/0/12
port access vlan 11
interface GigabitEthernet1/0/13
port access vlan 11
interface GigabitEthernet1/0/14
port access vlan 11
interface GigabitEthernet1/0/15
port access vlan 11
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
port access vlan 29
interface GigabitEthernet1/0/23
mac-address static 9ce8-9594-9a51 vlan 29
interface M-GigabitEthernet0/0/0
interface M-GigabitEthernet0/0/1
interface Ten-GigabitEthernet1/0/25
interface Ten-GigabitEthernet1/0/26
interface Ten-GigabitEthernet1/0/27
interface Ten-GigabitEthernet1/0/28
scheduler logfile size 16
line class aux
user-role network-admin
line class vty
user-role network-operator
line aux 0
line vty 0 4
authentication-mode scheme
line vty 5 63
ip route-static 0.0.0.0 0 172.16.1.1
snmp-agent
snmp-agent local-engineid 800063A280307BAC3F7E4B00000001
snmp-agent community read public
snmp-agent sys-info version all
ssh server enable
radius scheme system
user-name-format without-domain
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$OTGXWV/IwAMFlWH+$DzsJaEDn8HS0+AAz5CWBAZ5cgQYigYEg8qunVUT15T9MiEL+XxtrOmgU2JsIuvQtHGK5xiJJHIg/C4u3Hl2btw==
service-type ssh telnet http https
authorization-attribute user-role level-15
ip http enable
return
Kylin 九段
粉丝:22人 关注:8人
没太看懂具体故障,是交换机获取不到地址?还是配置丢失了?
我也是没发现故障, 二层接入三层端口1, 然后电脑连接二层 无法获取ip
Royann 发表时间:2019-09-20
回复Royann:
DHCP server在这个设备上是吧,运行过程中突然出现的问题?现在故障不在估计不好看了。
Kylin 发表时间:2019-09-20
对 DHCP在三层上,是上周一早上一来发现 断网,后续发现整个交换的pc都无法获取IP, 现在找不到原因
粉丝:14人 关注:0人
我认真看了一下,配置没有问题,工程师说的意思应该是你设备硬件坏了
嗯嗯 也是让我报个单子 然后让产品专家查看分析了,但是现在过保, 我有点郁闷, 不知咋整
閙忒 一段
你好,问题解决了吗??哪里的问题?如果有答案这里告知下,共同学习
暂时没有。 好了我回复你
Royann 发表时间:2019-09-22
Royann 知了小白
最后更换了设备,但是导入配置不行,也是同样不能上网,无法解决,关键后面发现导入配置 都没有导入进去,最后按照之前的配置重新敲一遍就好了。!
