云计算
2019-10-10提问
  • 1收藏,1133浏览
CAS、CloudOS和VCFC上怎么去设置禁止http的方式登录web界面,只能用https的方式登录。
仁风 四段
CAS E0306H02版本可以直接在界面设置成https方式访问。在【系统参数】中设置【保密模式】为启动,保存配置,提示重启Tomcat服务,保存后会自动重启tomcat服务。启动成功后,访问http+8080端口会强制跳转到https+8443.,效果即为8080不能用来访问cas系统。
SDN VCFC可以禁止HTTP访问只允许HTTPS访问,在控制器/系统管理/配置管理/控制器管理中修改http.enable为false,控制器需重启生效。
CloudOS需要编辑nginx.conf文件 :
#    server {
#        listen       80;
#        server_name  localhost;
#        #charset koi8-r;
#        #access_log  logs/host.access.log  main;
#        location / {
#            proxy_pass http://192.168.113.147:801;
#            proxy_redirect http://192.168.113.147:801/ /;
#            #proxy_redirect off;
#            proxy_set_header X-Real-IP $remote_addr;
#            proxy_set_header X-Scheme $scheme;
#            proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
#            proxy_set_header Host $http_host;
#            proxy_http_version 1.1;
#            proxy_set_header Upgrade $http_upgrade;
#            proxy_set_header Connection "upgrade";
#            proxy_connect_timeout 60;
#            proxy_send_timeout 3600;
#            proxy_read_timeout 3600;
#        #error_page  404              /404.html;
#        # redirect server error pages to the static page /50x.html
#        error_page   500 502 503 504  /50x.html;
#        location = /50x.html {
#            root   html;
#        # proxy the PHP scripts to Apache listening on 127.0.0.1:80
#        #location ~ \.php$ {
#        #    proxy_pass   http://127.0.0.1;
#        # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
#        #    root           html;
#        #    fastcgi_pass   127.0.0.1:9000;
#        #    fastcgi_index  index.php;
#        #    fastcgi_param  SCRIPT_FILENAME  /scripts$fastcgi_script_name;
#        #    include        fastcgi_params;
#        # deny access to .htaccess files, if Apache's document root
#        # concurs with nginx's one
#        #location ~ /\.ht {
#        #    deny  all;
