6520为核心 47-48口万兆接5560的27-28万兆口。6520的万兆45-46口接一台5130的27-28千兆口。5560下面接8个5130。要求做链路聚合。可以给一个配置例子吗?
2019-10-12提问
  • 1收藏,933浏览
粉丝:1人 关注:5人
6520为核心 47-48口万兆接5560的27-28万兆口。起两个C类地址VLan。6520的万兆45-46口接一台5130的27-28千兆口。5560下面接8个5130。要求做链路聚合。可以给一个配置例子吗?
z6Kl9 九段
粉丝:67人 关注:2人
int Bridge-Aggregation 11
link-aggregation mode dynamic
int r te1/0/47 t te 1/0/48
port link-aggregation group 11
sa f
粉丝:125人 关注:6人
以下是配置举例:
[H3C]vlan 10
 [H3C-vlan10]quit
 [H3C]vlan 20
 [H3C-vlan20]quit
[H3C]int Bridge-Aggregation 1
 [H3C-Bridge-Aggregation1]po li tr
[H3C-Bridge-Aggregation1]undo po tr pe vlan 1
 [H3C-Bridge-Aggregation1]po tr pe vlan 10 20
[H3C-Bridge-Aggregation1]quit
[H3C]int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50
 [H3C-if-range]po li tr
[H3C-if-range]undo po tr pe vlan 1
 [H3C-if-range]po tr pe vlan 10 20
 [H3C-if-range]port link-aggregation group 1
 [H3C-if-range]quit
47-48链路聚合接5560 45-56端口聚合接一台5130给虚拟服务器用
zhiliao_niuzai 发表时间:2019-10-13
您的需求是6520要两个聚合组,一个聚合组到5560,一个聚合组到5130?
得闲饮茶013 发表时间:2019-10-13
是这样 然后5560下面接8台5130依然是每台5130两个端口和5560两个端口聚合
感谢指导老师
[H3C]vlan 10 [H3C-vlan10]quit [H3C]vlan 20 [H3C-vlan20]quit [H3C]vlan 30 [H3C-vlan30]quit [H3C]vlan 40 [H3C-vlan40]quit [H3C] [H3C]int Bridge-Aggregation 1 [H3C-Bridge-Aggregation1]description <connect to 5560_27-28> [H3C-Bridge-Aggregation1]po li tr [H3C-Bridge-Aggregation1]undo po tr pe vlan 1 [H3C-Bridge-Aggregation1]po tr pe vlan 10 20 [H3C-Bridge-Aggregation1]quit [H3C] [H3C]int Bridge-Aggregation 2 [H3C-Bridge-Aggregation2]description <connect to 5130_27-28> [H3C-Bridge-Aggregation2]po li tr [H3C-Bridge-Aggregation2]undo po tr pe vlan 1 [H3C-Bridge-Aggregation2]po tr pe vlan 30 40 [H3C-Bridge-Aggregation2]quit [H3C] [H3C]int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 [H3C-if-range]po li tr [H3C-if-range]undo po tr pe vlan 1 [H3C-if-range]po tr pe vlan 10 20 [H3C-if-range]port link-aggregation group 1 [H3C-if-range]quit [H3C] [H3C]int range Ten-GigabitEthernet 1/0/51 to Ten-GigabitEthernet 1/0/52 [H3C-if-range]po li tr [H3C-if-range]undo po tr pe vlan 1 [H3C-if-range]po tr pe vlan 30 40 [H3C-if-range]port link-aggregation group 2 [H3C-if-range]quit [H3C]
以上是配置举例。如解决,望采纳和关注哈
