H3C MSR 830 ge1接PC可以DHCP上网,接H3C S5500的24口上 不了网
2019-10-19提问
  • 1收藏,931浏览
不了网,本换机有4个VLAN都可以获取相应的地址,就是不能上网。
还有个问题,这样配置4个VLAN里的PC可以相互访问吗??不知道
是不是配置有问题,求解
下面是两台设备的配置
H3C 5500 的配置
[H3C]dis cu
 version 5.20, Release 2222P12
 sysname H3C
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 undo ip http enable
 password-recovery enable
vlan 1
vlan 10
vlan 20
vlan 30
vlan 40
vlan 100
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool 10
 network 192.168.10.0 mask 255.255.255.0
 gateway-list 192.168.10.254
 dns-list 58.22.96.66 218.104.128.106
dhcp server ip-pool 20
 network 192.168.20.0 mask 255.255.255.0
 gateway-list 192.168.20.254
dhcp server ip-pool 30
 network 192.168.30.0 mask 255.255.255.0
 gateway-list 192.168.30.254
dhcp server ip-pool 40
 network 192.168.40.0 mask 255.255.255.0
 gateway-list 192.168.40.254
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$cPgkbebUcqfnpwmaK53Vudt92zDk6i5R
interface NULL0
interface Vlan-interface1
 ip address dhcp-alloc client-identifier mac Vlan-interface1
interface Vlan-interface10
 ip address 192.168.10.254 255.255.255.0
interface Vlan-interface20
 ip address 192.168.20.254 255.255.255.0
interface Vlan-interface30
 ip address 192.168.30.254 255.255.255.0
interface Vlan-interface40
 ip address 192.168.40.254 255.255.255.0
interface Vlan-interface100
 ip address 192.168.2.50 255.255.255.0
 port link-mode bridge
 port access vlan 10
 port access vlan 10
 port access vlan 10
interface GigabitEthernet1/0/4
 port access vlan 10
interface GigabitEthernet1/0/5
 port access vlan 10
interface GigabitEthernet1/0/6
 port access vlan 10
interface GigabitEthernet1/0/7
 port access vlan 20
interface GigabitEthernet1/0/8
 port access vlan 20
interface GigabitEthernet1/0/9
 port access vlan 20
interface GigabitEthernet1/0/10
 port access vlan 20
interface GigabitEthernet1/0/11
 port access vlan 20
interface GigabitEthernet1/0/12
 port access vlan 20
interface GigabitEthernet1/0/13
 port access vlan 30
interface GigabitEthernet1/0/14
 port access vlan 30
interface GigabitEthernet1/0/15
 port access vlan 30
interface GigabitEthernet1/0/16
 port access vlan 30
interface GigabitEthernet1/0/17
 port access vlan 30
interface GigabitEthernet1/0/18
 port access vlan 30
interface GigabitEthernet1/0/19
 port access vlan 40
interface GigabitEthernet1/0/20
 port access vlan 40
interface GigabitEthernet1/0/21
 port access vlan 40
interface GigabitEthernet1/0/22
 port access vlan 40
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
 ip route-static 0.0.0.0 0.0.0.0 192.168.2.1
 dhcp enable
 load xml-configuration
 load tr069-configuration
user-interface aux 0
user-interface vty 0 4
 user privilege level 3
user-interface vty 5 15
return
MSR830的配置
[H3C]dis cu
 version 5.20, Release 2514P04
 sysname H3C
acl number 3000
 rule 1 permit ip source 192.0.0.0 0.255.255.255
 rule 10 deny ip
vlan 1
domain system
 state active
 idle-cut disable
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.1
 expired unlimited
user-group system
interface Cellular0/0
 async mode protocol
 link-protocol ppp
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 description TO_waiwang-WAN
 nat outbound 3000
 ip address 192.168.199.16 255.255.255.0
interface GigabitEthernet0/1
 ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/4
interface GigabitEthernet0/2
interface GigabitEthernet0/3
 ip route-static 0.0.0.0 0.0.0.0 192.168.199.1
 dhcp server forbidden-ip 192.168.2.1
 dhcp enable
user-interface con 0
user-interface tty 13
return
粉丝:125人 关注:6人
看配置有以下几个问题:
1、路由器830与交换机5500的互联接口没有配置
建议将5500交换机的24口划分到VLAN100,配置如下:
int gi 1/0/24
port link-type access
port access vlan 100
2、路由器没有路由指向到5500交换机的业务网段,需添加如下路由:
ip route-static 192.168.10.0 255.255.255.0 192.168.2.50
ip route-static 192.168.20.0 255.255.255.0 192.168.2.50
ip route-static 192.168.30.0 255.255.255.0 192.168.2.50
ip route-static 192.168.40.0 255.255.255.0 192.168.2.50
3、在路由器830的地址转换的ACL中,没有将5500交换机上的业务地址段加入进去,不然交换机上业务地址无法访问外网,整改如下:
acl number 3000
 rule 2 permit ip source 192.168.10.0 0.0.0.255
rule 3 permit ip source 192.168.20.0 0.0.0.255
rule 4 permit ip source 192.168.30.0 0.0.0.255
rule 5 permit ip source 192.168.40.0 0.0.0.255
非常感谢 可以了
zhiliao_zQ2Xa 发表时间:2019-10-19
回复zhiliao_zQ2Xa:
好的,望关注,感谢支持哈!
得闲饮茶013 发表时间:2019-10-19
Cookie 七段
粉丝:6人 关注:3人
s5500缺少如下配置
zhiliao_zQ2Xa 知了小白
你好 我加我这条命令了。还是不能上网
问题还没解决吗?
zhiliao_2wYIi 发表时间:2019-10-19
