WAP712C-LI-G-FIT 怎么刷成胖的啊
2019-10-22提问
  • 1收藏,1673浏览
yuren 九段
粉丝:16人 关注:3人
1.1.1  方法一:使用bootloader方式进行升级
1、 通过ftp或者TFTP将版本拷入设备
<H3C>ftp 5.0.0.184
Press CTRL+C to abort.
Connected to 5.0.0.184 (5.0.0.184).
220 3Com 3CDaemon FTP 服务器版本 2.0
User (5.0.0.184:(none)): 123    -------------------------------ftp 用户名
331 用户名正确, 需要口令
Password:   ******        ----------------------------------------ftp 用户密码
230 用户已登录
Remote system type is UNIX.
ftp> get wa5300-fat.ipe
227 正在进入被动模式 (5,0,0,184,216,206)
125 正在使用现存的数据连接
226 正在关闭数据连接; 文件传输成功完成.
73387008 bytes received in 43.756 seconds (1.60 Mbytes/s)
ftp> quit
<H3C>
2、 在控制台通过boot-loader的方式升级,升级完成后重启设备,升级版本才最终成功
<H3C>boot-loader file flash:/wa5300-fat.ipe main
Verifying the file flash:/wa5300-fat.ipe on the device.....Done.
H3C WA5320X-SI images in IPE:
  wa5300-fat-boot.bin
  wa5300-fat-system.bin
This command will set the main startup software images. Please do not reboot the device during the upgrade. Continue? [Y/N]:y
Add images to the device.
File flash:/wa5300-fat-boot.bin already exists on the device.
File flash:/wa5300-fat-system.bin already exists on the device.
Overwrite the existing files? [Y/N]:y
Decompressing file wa5300-fat-boot.bin to flash:/wa5300-fat-boot.bin......Done.
Decompressing file wa5300-fat-system.bin to flash:/wa5300-fat-system.bin.........................Done.
Verifying the file flash:/wa5300-fat-boot.bin on the device...Done.
Verifying the file flash:/wa5300-fat-system.bin on the device.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on the device.
Decompression completed.
You are recommended to delete the .ipe file after you set startup software images for all slots.
Do you want to delete flash:/wa5300-fat.ipe now? [Y/N]:y
<H3C>
<H3C>reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to device successfully.
Now rebooting, please wait...
%May 10 16:27:42:333 2019 H3C DEV/5/SYSTEM_REBOOT: System is rebooting now.
System is starting...
1.1.2  方法二:在bootware下进行升级
1、 在设备重启过程中按ctrl+B键,进入bootware
2、 依次按照如下步骤进行升级
首先选3,进入以太菜单
接着,选5进入ftp或者tftp,配置ftp或者tftp服务器,拷贝版本
下一步,选2,更新主版本文件
接下来,版本解压完成后,退回到主菜单,并重启设备,即可完成版本更新
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :ftp    -------------------------------选择通过ftp或者tftp拷贝版本,本例选择ftp
Load File Name         :wa5300-fat.ipe------------------要拷贝的版本名字
Target File Name       :wa5300-fat.ipe  -------------------拷贝到设备上后的文件命名,可根据需要修改
Server IP Address      :5.0.0.157 5.0.0.184    --------ftp server的地址
Local IP Address       :105.1.108.152 5.0.0.157 ------------设备ip地址
Subnet Mask            :0
Gateway IP Address     :0
FTP User Name          :123 123           ---------------------ftp 用户名
FTP User Password      :****** ******    --------------------ftp密码
Enter your choice(0-5): 2
Loading.....................................................................
.............................................................Done.
40704000 bytes downloaded!
The file is exist,will you overwrite it? [Y/N]Y
Image file wa5300-fat-boot.bin is self-decompressing...
Saving file flash:/wa5300-fat-boot.bin ..............................Done.
Image file wa5300-fat-system.bin is self-decompressing...
Saving file flash:/wa5300-fat-system.bin ...................................
Enter your choice(0-5):       0
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extended BootWare
不是这样的,这ap的型号不是这么刷的
罗朝武 发表时间:2019-10-22
你这款AP是云AP,刷胖版本就是上面的两种方法。是没问题的
yuren 发表时间:2019-10-22
戏暖 一段
粉丝:2人 关注:1人
http://www.http://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/AP/H3C_WA4300S/
去官网载 WAP712C的fat版本,然后ftp或tftp上传到WAP712C上面,设置启动文件为fat就行
这个型号跟别的型号不一样的,也不是你给的这个版本
罗朝武 发表时间:2019-10-22
回复罗朝武:
http://www.h3c.com/cn/d_201507/884492_30005_40.htm 一样的,这个系列就用这个版本的
戏暖 发表时间:2019-10-22
回复戏暖:
你确定吗
罗朝武 发表时间:2019-10-22
