S5500配了4个VLAN 怎么才能互通
2019-10-25提问
  • 1收藏,1131浏览
目前有两台电脑 一台获取到192.168.10.2
另一台获取到192.128.30.3,为什么192.168.10.2可以PING192.168.30.3,
而反过来在192.168.30.3电脑上PING不通192.168.10.2
换成其它电脑也一样的问题。。只有一台电脑可以跟网内的其它设备通
信,其它的就是不行,太奇怪了。
以下是交换机和路由器配置文件
 version 5.20, Release 2222P12
 sysname H3C
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 undo ip http enable
 password-recovery enable
vlan 1
vlan 10
vlan 20
vlan 30
vlan 40
vlan 100
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool 10
 network 192.168.10.0 mask 255.255.255.0
 gateway-list 192.168.10.254
 dns-list 58.22.96.66 218.104.128.106
dhcp server ip-pool 20
 network 192.168.20.0 mask 255.255.255.0
 gateway-list 192.168.20.254
dhcp server ip-pool 30
 network 192.168.30.0 mask 255.255.255.0
 gateway-list 192.168.30.254
dhcp server ip-pool 40
 network 192.168.40.0 mask 255.255.255.0
 gateway-list 192.168.40.254
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$cPgkbebUcqfnpwmaK53Vudt92zDk6i5R
interface NULL0
interface Vlan-interface1
 ip address dhcp-alloc client-identifier mac Vlan-interface1
interface Vlan-interface10
 ip address 192.168.10.254 255.255.255.0
interface Vlan-interface20
 ip address 192.168.20.254 255.255.255.0
interface Vlan-interface30
 ip address 192.168.30.254 255.255.255.0
interface Vlan-interface40
 ip address 192.168.40.254 255.255.255.0
interface Vlan-interface100
 ip address 192.168.2.50 255.255.255.0
 port link-mode bridge
 port access vlan 10
 port access vlan 10
 port access vlan 10
interface GigabitEthernet1/0/4
 port access vlan 10
interface GigabitEthernet1/0/5
 port access vlan 10
interface GigabitEthernet1/0/6
 port access vlan 10
interface GigabitEthernet1/0/7
 port access vlan 20
interface GigabitEthernet1/0/8
 port access vlan 20
interface GigabitEthernet1/0/9
 port access vlan 20
interface GigabitEthernet1/0/10
 port access vlan 20
interface GigabitEthernet1/0/11
 port access vlan 20
interface GigabitEthernet1/0/12
 port access vlan 20
interface GigabitEthernet1/0/13
 port access vlan 30
interface GigabitEthernet1/0/14
 port access vlan 30
interface GigabitEthernet1/0/15
 port access vlan 30
interface GigabitEthernet1/0/16
 port access vlan 30
interface GigabitEthernet1/0/17
 port access vlan 30
interface GigabitEthernet1/0/18
 port access vlan 30
interface GigabitEthernet1/0/19
 port access vlan 40
interface GigabitEthernet1/0/20
 port access vlan 40
interface GigabitEthernet1/0/21
 port access vlan 40
interface GigabitEthernet1/0/22
 port access vlan 40
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 port access vlan 100
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
 ip route-static 0.0.0.0 0.0.0.0 192.168.2.1
 dhcp enable
 load xml-configuration
 load tr069-configuration
user-interface aux 0
user-interface vty 0 4
 user privilege level 3
user-interface vty 5 15
return
路由器配置:
 version 5.20, Release 2514P04
 sysname H3C
acl number 3000
 rule 1 permit ip source 192.0.0.0 0.255.255.255
 rule 2 permit ip source 192.168.10.0 0.0.0.255
 rule 3 permit ip source 192.168.20.0 0.0.0.255
 rule 4 permit ip source 192.168.30.0 0.0.0.255
 rule 5 permit ip source 192.168.40.0 0.0.0.255
 rule 10 deny ip
vlan 1
domain system
 state active
 idle-cut disable
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.1
 expired unlimited
user-group system
interface Cellular0/0
 async mode protocol
 link-protocol ppp
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 description TO_waiwang-WAN
 nat outbound 3000
 ip address 192.168.199.16 255.255.255.0
interface GigabitEthernet0/1
 ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/4
interface GigabitEthernet0/2
interface GigabitEthernet0/3
 ip route-static 0.0.0.0 0.0.0.0 192.168.199.1
 ip route-static 192.168.10.0 255.255.255.0 192.168.199.1
 ip route-static 192.168.10.0 255.255.255.0 192.168.2.50
 ip route-static 192.168.20.0 255.255.255.0 192.168.2.50
 ip route-static 192.168.30.0 255.255.255.0 192.168.2.50
 ip route-static 192.168.40.0 255.255.255.0 192.168.2.50
 dhcp server forbidden-ip 192.168.2.1
 dhcp enable
user-interface con 0
user-interface tty 13
return
粉丝:50人 关注:5人
ping是双向的,如果A能ping的通B,但是B回ping不了,很大程度是A设备的问题,比如终端自身的防火墙/杀毒软件等。
4 个回答
15900 四段
电脑防火墙关了么
zhiliao_zQ2Xa 知了小白
防火墙关了
粉丝:10人 关注:7人
跨网段不通时,先ping网关是否通
粉丝:14人 关注:0人
路由器写错了一句静态路由,不知道是不是这个引起的,但是按理说不应该用到这条路由,先删除试试吧:ip route-static 192.168.10.0 255.255.255.0 192.168.199.1
