F100-A-G2防火墙如何配置ipsec?
2019-10-31提问
  • 1收藏,996浏览
閙忒 一段
对端是Er3200G2路由器,且已参考官方文档配好ipsec。本端是F100-A-G2防火墙,配好了ipsec,但是无法连通对端。
对端ER3200G2上查看隧道,如下图:
本端防火墙上查看隧道,如下图:
求大神帮忙看下配置和路由哪里有问题,感激不尽。
组网:F100-A-G2--s5500三层--s3100--PC
网关在三层的5500上,防火墙Nat出口。
防火墙配置如下:  (底下还有5500的配置)
 version 7.1.064, Ess 9310P12
 sysname 防火墙
 clock timezone Beijing add 08:00:00
 clock protocol none
context Admin id 1
ip vpn-instance management
 route-distinguisher 1000000000:1
 vpn-target 1000000000:1 import-extcommunity
 vpn-target 1000000000:1 export-extcommunity
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 password-recovery enable
vlan 1
object-group ip address 192.168.1.0
 0 network subnet 192.168.1.0 255.255.255.0
object-group ip address 192.168.180.0
 description Internet-lab
 0 network subnet 192.168.180.0 255.255.255.0
object-group ip address 192.168.200.0
 description 709 Internet-Zone
 0 network subnet 192.168.200.0 255.255.255.0
object-group ip address 192.168.208.0
 description 708-PC
 0 network subnet 192.168.208.0 255.255.255.0
object-group ip address 192.168.209.0
 description 709-PC
 0 network subnet 192.168.209.0 255.255.255.0
object-group ip address 192.168.210.0
 description 710-PC
 0 network subnet 192.168.210.0 255.255.255.0
object-group ip address 192.168.212.0
 description 712-PC
 0 network subnet 192.168.212.0 255.255.255.0
object-group ip address 192.168.255.240
 description Switch manager
 0 network subnet 192.168.255.240 255.255.255.240
object-group ip address 192.168.36.0
 description Intranet-Server-No Isolation
 0 network subnet 192.168.36.0 255.255.255.0
object-group ip address 192.168.36.6
 description 内部主DNS
 0 network host address 192.168.36.6
object-group ip address 192.168.36.66
 description 辅DNS
 0 network host address 192.168.36.66
object-group ip address 192.168.60.0
 description Intranet-Server-Isolation
 0 network subnet 192.168.60.0 255.255.255.0
object-group ip address 192.168.66.0
 description Internet-Server-No Isolation
 0 network subnet 192.168.66.0 255.255.255.0
object-group ip address 192.168.88.0
 description Internet-PC
 0 network subnet 192.168.88.0 255.255.255.0
object-group ip address 211.140.13.188
 description 外部DNS
 0 network host address 211.140.13.188
interface NULL0
interface GigabitEthernet1/0/0
 port link-mode route
 ip binding vpn-instance management
 description To移动(WAN)
 duplex full
 ip address 112.16.72.152 255.255.255.128
 nat outbound 3000
 nat server protocol udp global current-interface 5060 inside 192.168.180.33 5060 disable
 ipsec apply policy GE1/0/1
 description Management
 ip address 10.80.0.1 255.255.255.252
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
 description LAN
 duplex full
 speed 1000
 ip address 192.168.255.242 255.255.255.240
 nat hairpin enable
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
object-policy ip Local-Untrust
 rule 0 pass
object-policy ip Trust-Untrust
 rule 0 pass source-ip 192.168.66.0
 rule 0 comment Internet-Server-No Isolation
 rule 1 pass source-ip 192.168.88.0
 rule 1 comment Internet-PC
 rule 2 pass source-ip 192.168.180.0
 rule 2 comment Internet-lab
 rule 3 pass source-ip 192.168.36.6 destination-ip 211.140.13.188
 rule 3 comment 主DNS转发
 rule 4 pass source-ip 192.168.36.66 destination-ip 211.140.13.188
 rule 4 comment 辅DNS
object-policy ip Untrust-Local
 rule 0 pass
object-policy ip Untrust-Trust
 rule 0 pass source-ip 192.168.1.0 destination-ip 192.168.180.0
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/15
security-zone name DMZ
security-zone name Untrust
security-zone name Management
 import interface GigabitEthernet1/0/3
zone-pair security source Local destination Untrust
 object-policy apply ip Local-Untrust
zone-pair security source Trust destination Untrust
 object-policy apply ip Trust-Untrust
zone-pair security source Untrust destination Local
 object-policy apply ip Untrust-Local
zone-pair security source Untrust destination Trust
 object-policy apply ip Untrust-Trust
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line con 0
 authentication-mode scheme
line vty 0 63
 ip route-static 0.0.0.0 0 112.16.72.254
 ip route-static 192.168.1.0 24 192.168.255.241
 ip route-static 192.168.36.0 24 192.168.255.241
 ip route-static 192.168.66.0 24 192.168.255.241 description Internet-Server-No Isolation
 ip route-static 192.168.88.0 24 192.168.255.241 description Internet-PC
 ip route-static 192.168.180.0 24 192.168.255.241 description Internet-lab
 snmp-agent
 snmp-agent local-engineid 800063A28084D9318BEA1700000001
 snmp-agent sys-info contact 15021202522
 snmp-agent sys-info location 711
 snmp-agent sys-info version v3
 ntp-service source GigabitEthernet1/0/1
acl advanced 3000
 rule 0 permit ip source 192.168.66.0 0.0.0.255
 rule 5 permit ip source 192.168.88.0 0.0.0.255
 rule 5 comment Internet-PC
 rule 10 permit ip source 192.168.180.0 0.0.0.255
 rule 10 comment Internet-lab
 rule 15 permit ip source 192.168.36.6 0 destination 211.140.13.188 0
 rule 15 comment 主DNS
 rule 20 permit ip source 192.168.36.66 0 destination 211.140.13.188 0
 rule 20 comment 辅DNS
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$jXnlWbUZ8j8e02ID$9KvJSKTVq+TapX57Cyk7qOn0PkBd8YAygQmxnTmh3CGBavNuEPArDwQAgVw37HIEC8rIiiauJClaCRmRANlQzA==
 service-type ssh terminal https
 authorization-attribute user-role level-3
local-user quadmin class manage
 password hash $h$6$AArDSL9yvOm7/wr8$Aj/X2aLFCbww2PpFl3eHoRjnh3ULytu3BiCJCDBubiHmae6b3quXUzhq6gFBibT4p9abptgYw7ihrijopjBbUQ==
 service-type ssh terminal http https
 authorization-attribute work-directory slot1#flash:
ipsec transform-set GE1/0/1_IPv4_1
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm sha1
ipsec policy GE1/0/1 1 isakmp
 security acl 3000
 remote-address 221.181.219.55
 description vpn
 ike-profile GE1/0/1_IPv4_1
 nat alg h323
 nat alg ils
 nat alg mgcp
 nat alg nbt
 nat alg rsh
 nat alg sccp
 nat alg sip
 nat alg sqlnet
 nat alg tftp
 nat alg xdmcp
ike profile GE1/0/1_IPv4_1
 keychain GE1/0/1_IPv4_1
 local-identity address 112.16.72.152
 match remote identity address 221.181.219.55 255.255.255.240
 match local address GigabitEthernet1/0/1
 proposal 65535
ike proposal 65535
 dh group2
 description GE1/0/1_IPv4_1
ike keychain GE1/0/1_IPv4_1
 pre-shared-key address 221.181.219.55 255.255.255.240 key cipher $c$3$/bFpoItYRgE9fGXqtAQb/57nUi6cK/WfSw==
 ip https enable
inspect block-source parameter-profile ips_block_default_parameter
inspect capture parameter-profile ips_capture_default_parameter
inspect logging parameter-profile ips_logging_default_parameter
inspect redirect parameter-profile av_redirect_default_parameter
inspect redirect parameter-profile ips_redirect_default_parameter
inspect redirect parameter-profile url_redirect_default_parameter
loadbalance action ##defaultactionforllbipv4##%%autocreatedbyweb%% type link-generic
 forward all
loadbalance policy ##defaultpolicyforllbipv4##%%autocreatedbyweb%% type link-generic
 default-class action ##defaultactionforllbipv4##%%autocreatedbyweb%%
virtual-server ##defaultvsforllbipv4##%%autocreatedbyweb%% type link-ip
 virtual ip address 0.0.0.0 0
 lb-policy ##defaultpolicyforllbipv4##%%autocreatedbyweb%%
 bandwidth interface statistics enable
traffic-policy
ips policy default
anti-virus policy default
return
以下为5500配置
 version 5.20, Release 2220P02
 sysname S5500-709
 dhcp relay server-group 1 ip 192.168.36.6
 undo irf link-delay
acl number 3100
 rule 0 permit ip source 192.168.180.0 0.0.0.255 destination 192.168.36.0 0.0.0.255
 rule 5 permit ip source 192.168.180.0 0.0.0.255 destination 192.168.66.0 0.0.0.255
 rule 10 permit ip source 192.168.180.0 0.0.0.255 destination 192.168.111.0 0.0.0.255
 rule 15 permit ip source 192.168.180.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
 rule 50 deny ip source 192.168.180.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
acl number 3101
 rule 0 permit ip source 192.168.200.0 0.0.0.255 destination 192.168.36.0 0.0.0.255
 rule 5 permit ip source 192.168.200.0 0.0.0.255 destination 192.168.66.0 0.0.0.255
 rule 10 permit ip source 192.168.200.0 0.0.0.255 destination 192.168.88.0 0.0.0.255
 rule 50 deny ip source 192.168.200.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
acl number 3102
 rule 0 permit ip source 192.168.208.0 0.0.0.255 destination 192.168.36.0 0.0.0.255
 rule 5 permit ip source 192.168.208.0 0.0.0.255 destination 192.168.66.0 0.0.0.255
 rule 50 deny ip source 192.168.208.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
acl number 3103
rule 0 permit ip source 192.168.209.0 0.0.0.255 destination 192.168.36.0 0.0.0.255
 rule 5 permit ip source 192.168.209.0 0.0.0.255 destination 192.168.66.0 0.0.0.255
 rule 50 deny ip source 192.168.209.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
acl number 3104
 rule 0 permit ip source 192.168.210.0 0.0.0.255 destination 192.168.36.0 0.0.0.255
 rule 5 permit ip source 192.168.210.0 0.0.0.255 destination 192.168.66.0 0.0.0.255
 rule 10 permit ip source 192.168.210.0 0.0.0.255 destination 192.168.255.240 0.0.0.15
 rule 15 permit ip source 192.168.210.0 0.0.0.255 destination 192.168.111.0 0.0.0.255
 rule 50 deny ip source 192.168.210.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
acl number 3105
 rule 0 permit ip source 192.168.212.0 0.0.0.255 destination 192.168.36.0 0.0.0.255
 rule 5 permit ip source 192.168.212.0 0.0.0.255 destination 192.168.66.0 0.0.0.255
 rule 10 permit ip source 192.168.212.0 0.0.0.255 destination 192.168.88.199 0
 rule 50 deny ip source 192.168.212.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
vlan 1
vlan 100
 description 36 Intranet-Server-No isolation
vlan 101
 description 60 Intranet-Server-Isolation
vlan 102
 description 66 Internet-Server-No isolation
vlan 103
 description 88 Internet-PC
vlan 104
 description 180 711-Internet-lab
vlan 106
 description 200 709-Internet Zone
vlan 107
 description 208 708-PC
vlan 108
 description 209 709-PC
vlan 109
 description 210 710-PC
vlan 110
 description 212 712-PC
vlan 111
 description printf
vlan 900
 description 225.240 Switch
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user quadmin
 password cipher $c$3$tzs5O4zlXaYRD+4a2VEcg4wJPTDlGB1rphgl5WSqOKc=
 authorization-attribute level 3
 service-type telnet
 service-type ftp
 service-type web
interface NULL0
interface Vlan-interface100
 ip address 192.168.36.1 255.255.255.0
 dhcp select relay
 dhcp relay server-select 1
interface Vlan-interface101
 ip address 192.168.60.1 255.255.255.0
 dhcp select relay
interface Vlan-interface102
 ip address 192.168.66.1 255.255.255.0
 dhcp select relay
interface Vlan-interface103
 ip address 192.168.88.1 255.255.255.0
 dhcp select relay
interface Vlan-interface104
 ip address 192.168.180.1 255.255.255.0
 dhcp select relay
 packet-filter 3100 inbound
interface Vlan-interface106
 ip address 192.168.200.1 255.255.255.0
 dhcp select relay
 packet-filter 3101 inbound
interface Vlan-interface107
 ip address 192.168.208.1 255.255.255.0
 dhcp select relay
 packet-filter 3102 inbound
interface Vlan-interface108
 ip address 192.168.209.1 255.255.255.0
 dhcp select relay
interface Vlan-interface109
 ip address 192.168.210.1 255.255.255.0
 dhcp select relay
 packet-filter 3104 inbound
interface Vlan-interface110
 ip address 192.168.212.1 255.255.255.0
 dhcp select relay
 packet-filter 3105 inbound
interface Vlan-interface111
 ip address 192.168.111.1 255.255.255.0
interface Vlan-interface900
 ip address 192.168.255.241 255.255.255.240
 undo dhcp select server global-pool
 port link-type trunk
 port trunk permit vlan 1 900
 port trunk pvid vlan 900
 port access vlan 102
 port access vlan 101
 port trunk permit vlan all
 port access vlan 100
interface GigabitEthernet1/0/24
 port access vlan 900
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
 ip route-static 0.0.0.0 0.0.0.0 192.168.255.242
 snmp-agent
 snmp-agent local-engineid 800063A2033897D6FC1FF0
 snmp-agent sys-info version all
 dhcp enable
 ip https enable
 load xml-configuration
user-interface aux 0
user-interface vty 0 4
user-interface vty 5 15
return
外网口nat outbound要把VPN感兴趣流DENY
粉丝:37人 关注:10人
如果两端sa都起来了,那么就是内网互通的问题,写一条acl ,放通内网的地址,然后debug ip packet看下是不是被策略丢了或者是路由有问题。
求指点,我都找了两天的问题了,愣是没找到怎么破解这个问题。
閙忒 发表时间:2019-10-31
我也怀疑是路由的问题,能麻烦你有空的时候帮我看看上面的配置吗,应该如何设置路由?
閙忒 发表时间:2019-10-31
