ipsec1对多,只有一个能ping通.竞争占用隧道.如何解决
2019-11-04提问
  • 1收藏,816浏览
总部使用MSR3610,建立ipsec模板. 野蛮模式.
分支单位有多个使用msr810,4G路由器.除了Vlan-interface1的ip地址不同外,其他ipsec的配置数据都相同.
每个分支单位都可以单独成功建立ipsec,并能ping通总部的内部网络.
所有分支单位全部接入ipsec后,dis ike sa 能发现所有对等体.dis ipsec tunnel 可以看到全部隧道.
问题来了. 这些分支单位只有一个能ping通.谁优先接入隧道谁就能ping通.其他后接入隧道的就无法ping通.
在总部使用reset ipsec sa后, 原先不能ping的,就能ping了.也仅仅是一个. 本来可以ping的,就不能ping了.
就像是竞争的方式独占隧道.
这种问题如何解决.
//////////////////////总部配置////////////////////////////////////
#互联网接口
interface GigabitEthernet0/0
 port link-mode route
 ip address 123.123.123.123 255.255.255.0
 tcp mss 1280
 ipsec apply policy ipsec1
#内部网络接口
interface GigabitEthernet0/3
 combo enable copper
ip address 172.168.1.1 255.255.255.0
 ip route-static 0.0.0.0 0 123.123.123.121
acl advanced 3000
 rule 0 permit ip destination 172.169.0.0 0.0.255.255
ipsec transform-set ipsec1
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec policy-template ipsec1 65535
 security acl 3000
 ike-profile ipsec1
 sa duration time-based 3600
 sa duration traffic-based 1843200
ipsec policy ipsec1 65535 isakmp template ipsec1
 ike identity fqdn zongbu
ike profile ipsec1
 keychain ipsec1
 exchange-mode aggressive
 local-identity fqdn zongbu
 match remote identity fqdn RTA
 proposal 65535
ike proposal 65535
ike keychain ipsec1
 pre-shared-key hostname RTA key simple 123456
///////////////////////以下是分支机构配置//////////////////////////////
vlan 1
dhcp server ip-pool lan1
 gateway-list 172.169.1.1
 network 172.169.1.0 mask 255.255.255.0
 address range 172.169.1.2 172.169.1.254
 dns-list 172.169.1.1
###有多个分支机构,分别是172.169.x.y
apn-profile profile69
 apn static 3gnet
controller Cellular0/0
controller Cellular1/0
 description Single_Line1-UNICOM
 eth-channel 0
interface Vlan-interface1
 ip address 172.169.1.1 255.255.255.0
###有多个分支机构,分别是172.169.x.1####
interface Eth-channel1/0:0
 dialer circular enable
 dialer-group 89
 dialer timer autodial 5
 dialer number *99# autodial
 ip address cellular-alloc
 apn-profile apply profile69
 ipsec apply policy RTA
 ip route-static 0.0.0.0 0 Eth-channel1/0:0
acl advanced 3000
 rule 0 permit ip source 172.169.0.0 0.0.255.255 destination 172.168.0.0 0.0.255.255
ipsec transform-set 1
ipsec policy RTA 1 isakmp
 transform-set 1
 security acl 3000
 remote-address 123.123.123.123
 ike-profile RTA
 ike identity fqdn RTA
ike profile RTA
 keychain RTA
 local-identity fqdn RTA
 match remote identity fqdn zongbu
 proposal 1
ike proposal 1
ike keychain RTA
 pre-shared-key address 123.123.123.123 255.255.255.255 key simple 123456
粉丝:6人 关注:0人
你有多个分支,应该创建多个ipsec  sa吧,你所有的分支都用这一个?
怎么修改呢?我尝试match remote identity fqdn RTA1,match remote identity fqdn RTA2,match remote identity fqdn RTA3.pre-shared-key hostname RTA1 pre-shared-key hostname RTA2,pre-shared-key hostname RTA 3.问题依旧.
zhiliao_5XnQJ 发表时间:2019-11-04
每个创建一个新的ipsec sa
小白白 发表时间:2019-11-04
zhiliao_5XnQJ 知了小白
这个问题 最后找到原因了
是acl 的掩码 问题
