H3C S5500-52C-EI acl 不支持
2018-01-25提问
  • 1收藏,1702浏览
我的设备是H3C S5500-52C-EI
之前acl 是这样的,一直是没问题的,后来加了几条就报错 Reason: Not supported by hardware.  acl总条数有限制吗。我的有50多条了,
acl number 3001
 rule 0 permit tcp destination 192.168.3.200 0 destination-port eq 22
 rule 5 permit tcp destination 192.168.7.20 0 destination-port eq 22
 rule 10 permit tcp destination 192.168.4.243 0 destination-port eq 22
rule 15 permit tcp destination 192.168.4.242 0 destination-port eq 22
 rule 20 permit tcp destination 192.168.7.112 0 destination-port eq 22
rule 25 permit tcp destination 192.168.7.113 0 destination-port eq 22
 rule 30 permit tcp destination 192.168.8.134 0 destination-port eq 22
rule 35 permit tcp destination 192.168.9.166 0 destination-port eq 22
acl number 3002
 rule 0 deny tcp destination 192.168.9.0 0.0.0.255 destination-port eq 22
 rule 5 deny tcp destination 192.168.8.0 0.0.0.255 destination-port eq 22
 rule 10 deny tcp destination 192.168.7.0 0.0.0.255 destination-port eq 22
rule 15 deny tcp destination 192.168.10.0 0.0.0.255 destination-port eq 22
 rule 20 deny tcp destination 192.168.4.0 0.0.0.255 destination
修改成如下后就不行了,
acl number 3001
 rule 40 permit tcp destination 192.168.8.0 0.0.0.255 destination-port eq 443
 rule 45 permit tcp destination 192.168.8.0 0.0.0.255 destination-port eq 80
 rule 50 permit tcp destination 192.168.9.0 0.0.0.255 destination-port eq 443
 rule 55 permit tcp destination 192.168.9.0 0.0.0.255 destination-port eq 80
 rule 60 permit tcp destination 192.168.10.0 0.0.0.255 destination-port eq 443
 rule 65 permit tcp destination 192.168.10.0 0.0.0.255 destination-port eq 80
 rule 70 permit tcp destination 192.168.4.0 0.0.0.255 destination-port eq 443
 rule 75 permit tcp destination 192.168.4.0 0.0.0.255 destination-port eq 80
 rule 80 permit tcp destination 192.168.7.0 0.0.0.255 destination-port eq 443
 rule 85 permit tcp destination 192.168.7.0 0.0.0.255 destination-port eq 80
 acl number 3002
 rule 25 deny tcp destination 192.168.4.0 0.0.0.255 destination-port lt 8000
 rule 30 deny tcp destination 192.168.7.0 0.0.0.255 destination-port lt 8000
 rule 35 deny tcp destination 192.168.8.0 0.0.0.255 destination-port lt 8000
rule 40 deny tcp destination 192.168.9.0 0.0.0.255 destination-port lt 8000
rule 45 deny tcp destination 192.168.10.0 0.0.0.255 destination-port lt 8000
三层核心交换,控制不能访问vlan 4,7,8,9 的800以下的端口,只允许访问80和443端口和几条机器的22端口,如何修改。
粉丝:3人 关注:0人
应该是操作符lt不支持
zhiliao_64667 知了小白
那如何改下,rang 1-8000 这样也可以吗?
可以试试
zhiliao_susuqtt 发表时间:2018-01-25
