f100-a账户密码忘了怎么找回,详细步骤需要
2019-11-15提问
  • 1收藏,772浏览
f100-a账户密码忘了怎么找回,需要详细步骤,console可以登进去
f100-a账户密码忘了怎么找回,详细步骤console可以登入
粉丝:12人 关注:4人
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 8
Clear Image Password Success!
z6Kl9 九段
粉丝:66人 关注:2人
console没有密码的话,那就很简单了,重新创建一个账号密码,如下:
 web界面开启:
sy
te se e //开启telnet服务
ip http enable //开启http服务
ip https enable //开启https服务
local-user xxbadmin c m //创建用户名
 service-type https http telnet terminal //服务类型
 p s chushi@123 //创建密码
user-interface vty 0 4 //远程登录
 authentication-mode scheme //启用3a认证
sa f //强制保存
