WA4320
2019-11-18提问
  • 1收藏,1071浏览
猪头 零段
 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed!
想升级版本,为什么会这样= =
粉丝:149人 关注:3人
你需要先按3  修改下tftp or ftp的方式 地址和文件名
==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :host :WA4300-CMW520-R1509P03-FAT.bin Target File Name :target :WA4300-CMW520-R1509P03-FAT.bin Server IP Address :192.168.1.1 Local IP Address :192.168.1.253 Subnet Mask :0.0.0.0 Gateway IP Address :0.0.0.0 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading..................................................................... ............................................................................ .......................................................................... Done. 11078656 bytes downloaded! Saving file flash:/WA4300-CMW520-R1509P03-FAT.bin .......................... ............................................................................ ......................................................................Done. Set the file attribute failed!
猪头 发表时间:2019-11-18
还是失败了。。。
猪头 发表时间:2019-11-18
我这边的话,前面使用过TFTP设置成boot-loader文件也不可以,说是不支持这个设备,是不是版本有问题,这个版本原先是V7的,现在把它变成V5的胖AP,可以吗
猪头 发表时间:2019-11-18
z6Kl9 九段
粉丝:67人 关注:2人
远程给你解决,先降级boot版本
猪头 知了小白
谢谢各位的帮助,我已经解决了https://zhiliao.h3c.com/questions/dispcont/5974这篇文章给了我一些帮助,问题主要是boot需要先升级OR降级
1.如果找不到解决办法,而且没有SN码,就上知了社区看看吧,那边可能会有你的情况 2.AP升级中,BOOT芯片也要升级,有时候不支持boot芯片的话会升级失败,需要先升级 boot芯片,其实,在官方下载的bin文件中是有boot升级文件的,你需要先升级boot,具体方法 是,在boot界面中,先3(进入以太网传输)后5(TFTP传输修改)后1(升级boot芯片) 后推到menu界面 ctrl+y修改AP-mode 后ctrl+f格式化硬盘容量 然后再3 (进入以太网传输) 后3(TFTP传输修改(此时boot芯片已改,参数有变化))后2(传输文件) 传输想要的文件
猪头 发表时间:2019-11-20
