S10508 STP报文
2019-11-19提问
  • 1收藏,1621浏览
粉丝:1人 关注:1人
%Nov 19 21:42:38:065 2019 HeXing-S10508 DHCPS/5/DHCPS_ALLOCATE_IP: -MDC=1; Server IP = 172.16.108.254, DHCP client IP = 172.16.108.178, DHCP client hardware address = a057-e373-110b, DHCP client lease = 86400 seconds. %Nov 19 21:42:39:210 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/25 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:42:42:652 2019 HeXing-S10508 DHCPS/5/DHCPS_EXTEND_IP: -MDC=1; Server IP = 172.16.108.254, DHCP client IP = 172.16.108.178, DHCP client hardware address = a057-e373-110b, DHCP client lease = 86400 seconds. %Nov 19 21:42:43:597 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/27 was notified a topology change. %Nov 19 21:42:43:561 2019 HeXing-S10508 DHCPS/5/DHCPS_ALLOCATE_IP: -MDC=1; Server IP = 172.16.130.254, DHCP client IP = 172.16.130.1, DHCP client hardware address = 5cc9-9933-cb2a, DHCP client lease = 86400 seconds. %Nov 19 21:42:44:696 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/27 was notified a topology change. %Nov 19 21:42:46:229 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/47 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:42:48:269 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/31 was notified a topology change. %Nov 19 21:42:48:619 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/28 (PVID 1205), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:42:50:106 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=7; Instance 0's port Ten-GigabitEthernet7/0/10 was notified a topology change. %Nov 19 21:42:50:274 2019 HeXing-S10508 OSPF/6/OSPF_DUP_RTRID_NBR: -MDC=1; OSPF 2400 Duplicate router ID 10.0.0.9 on interface Route-Aggregation111, sourced from IP address 10.0.0.9. %Nov 19 21:42:52:214 2019 HeXing-S10508 DHCPS/5/DHCPS_EXTEND_IP: -MDC=1; Server IP = 172.16.108.254, DHCP client IP = 172.16.108.178, DHCP client hardware address = a057-e373-110b, DHCP client lease = 86400 seconds. %Nov 19 21:42:56:655 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/30 (PVID 1207), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:42:57:957 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/27 was notified a topology change. %Nov 19 21:42:58:572 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/45 (PVID 1300), with H3C Ten-GigabitEthernet1/0/49 (PVID 1). %Nov 19 21:42:58:820 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/27 was notified a topology change. %Nov 19 21:43:05:046 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=7; Instance 0's port Ten-GigabitEthernet7/0/4 was notified a topology change. %Nov 19 21:43:05:777 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/29 (PVID 1206), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:09:207 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/25 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:09:891 2019 HeXing-S10508 DHCPS/5/DHCPS_EXTEND_IP: -MDC=1; Server IP = 10.3.3.254, DHCP client IP = 10.3.1.102, DHCP client hardware address = 80e4-553c-dbc0, DHCP client lease = 86400 seconds. %Nov 19 21:43:11:066 2019 HeXing-S10508 DHCPS/5/DHCPS_RECLAIM_IP: -MDC=1; Server IP = 172.16.130.254, DHCP client IP = 172.16.130.1, DHCP client hardware address = 5cc9-9933-cb2a, DHCP client lease = 86400 seconds. %Nov 19 21:43:15:493 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=7; Instance 0's port Ten-GigabitEthernet7/0/11 was notified a topology change. %Nov 19 21:43:16:224 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/47 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:18:618 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/28 (PVID 1205), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:26:658 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/30 (PVID 1207), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:28:569 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/45 (PVID 1300), with H3C Ten-GigabitEthernet1/0/49 (PVID 1). %Nov 19 21:43:31:855 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=7; Instance 0's port Ten-GigabitEthernet7/0/10 was notified a topology change. %Nov 19 21:43:35:772 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/29 (PVID 1206), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:39:208 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/25 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:44:599 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/27 was notified a topology change. %Nov 19 21:43:45:309 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/27 was notified a topology change. %Nov 19 21:43:46:221 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/47 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:48:639 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/28 (PVID 1205), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:48:769 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/31 was notified a topology change. %Nov 19 21:43:49:807 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/39 was notified a topology change. %Nov 19 21:43:49:374 2019 HeXing-S10508 DHCPS/5/DHCPS_ALLOCATE_IP: -MDC=1; Server IP = 172.16.130.254, DHCP client IP = 172.16.130.1, DHCP client hardware address = 5cc9-9933-cb2a, DHCP client lease = 86400 seconds. %Nov 19 21:43:56:694 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/30 (PVID 1207), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:43:56:709 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/27 was notified a topology change. %Nov 19 21:43:58:566 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/45 (PVID 1300), with H3C Ten-GigabitEthernet1/0/49 (PVID 1). %Nov 19 21:44:05:027 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=7; Instance 0's port Ten-GigabitEthernet7/0/4 was notified a topology change. %Nov 19 21:44:05:772 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/29 (PVID 1206), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:44:09:224 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/25 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:44:16:221 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/47 (PVID 500), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:44:16:933 2019 HeXing-S10508 DHCPS/5/DHCPS_RECLAIM_IP: -MDC=1; Server IP = 172.16.130.254, DHCP client IP = 172.16.130.1, DHCP client hardware address = 5cc9-9933-cb2a, DHCP client lease = 86400 seconds. %Nov 19 21:44:18:660 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/28 (PVID 1205), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:44:24:073 2019 HeXing-S10508 STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=7; Instance 0's port Ten-GigabitEthernet7/0/11 was notified a topology change. %Nov 19 21:44:26:695 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on GigabitEthernet2/0/30 (PVID 1207), with H3C GigabitEthernet1/0/25 (PVID 1). %Nov 19 21:44:28:567 2019 HeXing-S10508 LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1-Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/45 (PVID 1300), with H3C Ten-GigabitEthernet1/0/49 (PVID 1).
粉丝:10人 关注:0人
看起来是有拓扑变化和两个端口pvid不一致
怎么解决
zhiliao_imYdy 发表时间:2019-11-19
回复zhiliao_imYdy:
看两端接口的pvid以及设备的拓扑变化情况
在这狂混 发表时间:2019-11-19
粉丝:6人 关注:3人
PVID不一样导致的拓扑变化
怎么处理
