WA5320X-E 升级到FAT版本无法启动系统
2019-11-25提问
  • 1收藏,1203浏览
xry 一段
设备升级到FAT版本无法启动,一直反复加载系统文件。提示信息如下:
**************************************************************************** * * * H3C WA5320X-E BootWare, Version 7.10 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Sep 25 2017 CPU Type : ARM CPU L1 Cache : 32KB CPU L2 Cache : 256KB CPU Clock Speed : 710MHz Memory Type : DDR3 SDRAM Memory Size : 512MB Memory Speed : 667MHz Flash Size : 128MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main image files... Loading file flash:/wa5300-fat-system.bin.................................. Done. Loading file flash:/wa5300-fat-boot.bin.........Done. Image file flash:/wa5300-fat-boot.bin is self-decompressing................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ .Done. System image is starting... System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ...Done. **************************************************************************** * * * H3C WA5320X-E BootWare, Version 7.10 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Sep 25 2017 CPU Type : ARM CPU L1 Cache : 32KB CPU L2 Cache : 256KB CPU Clock Speed : 710MHz Memory Type : DDR3 SDRAM Memory Size : 512MB Memory Speed : 667MHz Flash Size : 128MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main image files... Loading file flash:/wa5300-fat-system.bin.................................. Done. Loading file flash:/wa5300-fat-boot.bin.........Done. Image file flash:/wa5300-fat-boot.bin is self-decompressing................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ .Done. System image is starting... System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extended BootWare The Extended BootWare is self-decompressing................................. ...Done. **************************************************************************** * * * H3C WA5320X-E BootWare, Version 7.10 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Sep 25 2017 CPU Type : ARM CPU L1 Cache : 32KB CPU L2 Cache : 256KB CPU Clock Speed : 710MHz Memory Type : DDR3 SDRAM Memory Size : 512MB Memory Speed : 667MHz Flash Size : 128MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main image files... Loading file flash:/wa5300-fat-system.bin.................................. Done. Loading file flash:/wa5300-fat-boot.bin.........Done.
粉丝:1人 关注:2人
当出现“Press Ctrl+B to access EXTENDED-BOOTWARE MENU...”时,键入<Ctrl+B>,系统进入BootWare主菜单:
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9):
该菜单含义请参见错误!未找到引用源。
BootWare主菜单下键入< Ctrl+Y>,可以进入AP模式切换菜单,系统显示如下:
Please select the new mode
Current mode is Fit
|NO.  Mode        |
|1    Fat Mode                                                             |
|2    Fit Mode                                                             |
|0    Exit        |
Enter your choice(0-2):
AP模式切换菜单下键入<1>,切换AP的工作模式为FAT模式。
Enter your choice(0-2):1
Changed to fat mode successfully!
切换成功后,需要加载FAT AP版本启动,请通过BootWare下载版本。
也这样操作过,还是反复加载文件,看到上面发的启动日志了吧,反复重启反复加载文件
xry 发表时间:2019-11-25
怀疑硬件问题,内存不好。固件不能解压
纳兰枫少 发表时间:2019-11-25
4 个回答
粉丝:13人 关注:11人
fat的版本和型号匹配吗?
版本完全匹配
xry 发表时间:2019-11-25
WA5300-CMW710-R2409-FAT.ipe 使用这个版本
xry 发表时间:2019-11-25
那ctrl f 格式化下,重新灌版本试试。
颠倒梦想 发表时间:2019-11-25
SMSAMA 八段
粉丝:15人 关注:8人
格式化,重新导入版本试试。
格式化也是不行,我感觉是软件问题。有原厂人回复下。
xry 发表时间:2019-11-25
粉丝:24人 关注:3人
BootWare里面FTP重新传上去,升级前先ctrl+f格式化下flash
如有帮助,麻烦采纳
xry 发表时间:2019-11-25
xry 一段
格式化也是不行,多台AP都是无法正常刷成功,我感觉是软件问题。有原厂人回复下。
