求助,连接1/0/36口无法ping通路由
2018-01-29提问
  • 1收藏,2125浏览
路由IP为192.168.31.14,连接端口1/0/36,设置IP为192.168.27.226/24,网关192.168.27.225,DNS114。无法ping通,但是1/0/14端口可以通。
# version 5.20, Release 2202 # sysname H3C # irf mac-address persistent timer irf auto-update enable undo irf link-delay # domain default enable system # telnet server enable # undo ip ttl-expires # vlan 1 # vlan 2 # vlan 11 description to 101 # vlan 12 #Apr 27 06:04:48:670 2000 H3C DEV/1/FAN STATE CHANGES TO FAILURE: Trap 1.3.6.1.4.1.25506.8.35.12.1.6<hh3cfanfailure>: fan ID is 1 %Apr 27 06:04:48:863 2000 H3C DEV/4/FAN FAILED: Fan 1 failed. description to 102 # vlan 13 description to 201 # vlan 14 description to 202 # vlan 15 description to 203 # vlan 16 description to 205 # vlan 17 description to 206 # vlan 18 description to 208 # vlan 19 description to 210 # vlan 20 description to 211 # vlan 21 description to 212 # vlan 22 description to 301 # vlan 23 description to 302 # vlan 24 description to 303 # vlan 25 description to 305 # vlan 26 description to 306 # vlan 27 description to 307 # vlan 28 description to 308 # vlan 29 description to 310 # vlan 30 description to 311 # vlan 31 description to 312 # vlan 32 description to 315 # vlan 33 description to 316 # vlan 34 description to 317 # vlan 35 description to 318 # vlan 36 description to 319 # vlan 37 description to 320 # vlan 38 description to 401 # vlan 39 description to 402 # vlan 40 description to 403 # vlan 41 description to 405 # vlan 42 description to 406 # vlan 43 description to 408 # vlan 44 description to 410 # vlan 45 description to 411 # vlan 46 description to 412 # vlan 47 description to 415 # vlan 48 description to 416 # vlan 49 description to 417 # vlan 50 description to 418 # vlan 51 description to 419 # vlan 52 description to 420 # vlan 53 description to 501 # vlan 54 description to 502 # vlan 55 description to 503 # vlan 56 description to 505 # vlan 57 description to 506 # vlan 58 description to 507 # vlan 59 description to 508 # vlan 60 description to 509 # vlan 61 description to 510 # vlan 62 description to 601 # vlan 63 description to 602 # vlan 64 description to 603 # vlan 65 description to 606 # vlan 66 description t0 608 # vlan 67 description to 207 # vlan 68 description to 407 # vlan 69 description to 321 # vlan 70 description to 421 # vlan 71 description to 511 # vlan 72 description to 521 # vlan 73 description to 604 # vlan 74 description to 103-menwei # vlan 75 description to 213 # vlan 76 description to shitangerlou # vlan 77 # radius scheme system server-type extended primary authentication 127.0.0.1 1645 primary accounting 127.0.0.1 1646 user-name-format without-domain # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system # interface NULL0 # interface Vlan-interface2 ip address 192.168.31.13 255.255.255.252 # interface Vlan-interface11 ip address 192.168.27.1 255.255.255.248 # interface Vlan-interface12 ip address 192.168.27.9 255.255.255.248 # interface Vlan-interface13 ip address 192.168.27.17 255.255.255.248 # interface Vlan-interface14 ip address 192.168.27.25 255.255.255.248 # interface Vlan-interface15 ip address 192.168.27.33 255.255.255.248 # interface Vlan-interface16 ip address 192.168.27.41 255.255.255.248 # interface Vlan-interface17 ip address 192.168.27.49 255.255.255.248 # interface Vlan-interface18 ip address 192.168.27.57 255.255.255.248 # interface Vlan-interface19 ip address 192.168.27.65 255.255.255.248 # interface Vlan-interface20 ip address 192.168.27.73 255.255.255.248 # interface Vlan-interface21 ip address 192.168.27.81 255.255.255.248 # interface Vlan-interface22 ip address 192.168.27.89 255.255.255.248 # interface Vlan-interface23 ip address 192.168.27.97 255.255.255.248 # interface Vlan-interface24 ip address 192.168.27.105 255.255.255.248 # interface Vlan-interface25 ip address 192.168.27.113 255.255.255.248 # interface Vlan-interface26 ip address 192.168.27.121 255.255.255.248 # interface Vlan-interface27 ip address 192.168.27.129 255.255.255.248 # interface Vlan-interface28 ip address 192.168.27.137 255.255.255.248 # interface Vlan-interface29 ip address 192.168.27.145 255.255.255.248 # interface Vlan-interface30 ip address 192.168.27.153 255.255.255.248 # interface Vlan-interface31 ip address 192.168.27.161 255.255.255.248 # interface Vlan-interface32 ip address 192.168.27.169 255.255.255.248 # interface Vlan-interface33 ip address 192.168.27.177 255.255.255.248 # interface Vlan-interface34 ip address 192.168.27.185 255.255.255.248 # interface Vlan-interface35 ip address 192.168.27.193 255.255.255.248 # interface Vlan-interface36 ip address 192.168.27.201 255.255.255.248 # interface Vlan-interface37 ip address 192.168.27.209 255.255.255.248 # interface Vlan-interface38 ip address 192.168.27.217 255.255.255.248 # interface Vlan-interface39 ip address 192.168.27.225 255.255.255.248 # interface Vlan-interface40 ip address 192.168.27.233 255.255.255.248 # interface Vlan-interface41 ip address 192.168.27.241 255.255.255.248 # interface Vlan-interface42 ip address 192.168.27.249 255.255.255.248 # interface Vlan-interface43 ip address 192.168.28.1 255.255.255.248 # interface Vlan-interface44 ip address 192.168.28.9 255.255.255.248 # interface Vlan-interface45 ip address 192.168.28.17 255.255.255.248 # interface Vlan-interface46 ip address 192.168.28.25 255.255.255.248 # interface Vlan-interface47 ip address 192.168.28.33 255.255.255.248 # interface Vlan-interface48 ip address 192.168.28.41 255.255.255.248 # interface Vlan-interface49 # interface Vlan-interface50 # interface Vlan-interface51 ip address 192.168.28.66 255.255.255.248 # interface Vlan-interface52 ip address 192.168.28.73 255.255.255.248 # interface Vlan-interface53 ip address 192.168.28.81 255.255.255.248 # interface Vlan-interface54 ip address 192.168.28.89 255.255.255.248 # #Apr 27 06:06:09:478 2000 H3C DEV/1/FAN STATE CHANGES TO FAILURE: Trap 1.3.6.1.4.1.25506.8.35.12.1.6<hh3cfanfailure>: fan ID is 1 %Apr 27 06:06:09:671 2000 H3C DEV/4/FAN FAILED: Fan 1 failed. interface Vlan-interface55 ip address 192.168.28.97 255.255.255.248 # interface Vlan-interface56 ip address 192.168.28.105 255.255.255.248 # interface Vlan-interface57 ip address 192.168.28.113 255.255.255.248 # interface Vlan-interface58 ip address 192.168.28.121 255.255.255.248 # interface Vlan-interface59 ip address 192.168.28.129 255.255.255.248 # interface Vlan-interface60 ip address 192.168.28.137 255.255.255.248 # interface Vlan-interface61 # interface Vlan-interface62 ip address 192.168.28.153 255.255.255.248 # interface Vlan-interface63 ip address 192.168.28.161 255.255.255.248 # interface Vlan-interface64 ip address 192.168.30.129 255.255.255.224 # interface Vlan-interface65 ip address 192.168.28.177 255.255.255.248 # interface Vlan-interface66 ip address 192.168.28.185 255.255.255.248 # interface Vlan-interface67 ip address 192.168.28.193 255.255.255.248 # interface Vlan-interface68 ip address 192.168.28.201 255.255.255.248 # interface Vlan-interface69 ip address 192.168.28.209 255.255.255.248 # interface Vlan-interface70 ip address 192.168.28.217 255.255.255.248 # interface Vlan-interface71 ip address 192.168.30.1 255.255.255.128 # interface Vlan-interface72 ip address 192.168.28.233 255.255.255.248 # interface Vlan-interface73 ip address 192.168.30.161 255.255.255.224 # interface Vlan-interface74 ip address 192.168.28.249 255.255.255.248 # interface Vlan-interface75 ip address 192.168.28.241 255.255.255.248 # interface Vlan-interface76 ip address 192.168.30.193 255.255.255.192 # interface Vlan-interface77 ip address 192.168.28.49 255.255.255.240 # interface GigabitEthernet1/0/1 port access vlan 12 # interface GigabitEthernet1/0/2 port access vlan 12 # interface GigabitEthernet1/0/3 port access vlan 11 # interface GigabitEthernet1/0/4 port access vlan 11 # interface GigabitEthernet1/0/5 port access vlan 21 # interface GigabitEthernet1/0/6 port access vlan 20 # interface GigabitEthernet1/0/7 port access vlan 19 # interface GigabitEthernet1/0/8 port access vlan 67 # interface GigabitEthernet1/0/9 port access vlan 16 # interface GigabitEthernet1/0/10 port access vlan 15 # interface GigabitEthernet1/0/11 port access vlan 18 # interface GigabitEthernet1/0/12 port access vlan 17 # interface GigabitEthernet1/0/13 port access vlan 13 # interface GigabitEthernet1/0/14 port access vlan 14 # interface GigabitEthernet1/0/15 port access vlan 75 # interface GigabitEthernet1/0/16 port access vlan 31 # interface GigabitEthernet1/0/17 port access vlan 27 # interface GigabitEthernet1/0/18 port access vlan 25 # interface GigabitEthernet1/0/19 port access vlan 30 # interface GigabitEthernet1/0/20 port access vlan 29 # interface GigabitEthernet1/0/21 port access vlan 24 # interface GigabitEthernet1/0/22 port access vlan 22 # interface GigabitEthernet1/0/23 port access vlan 28 # interface GigabitEthernet1/0/24 port access vlan 26 # interface GigabitEthernet1/0/25 port access vlan 23 # interface GigabitEthernet1/0/26 port access vlan 69 # interface GigabitEthernet1/0/27 port access vlan 46 # interface GigabitEthernet1/0/28 port access vlan 68 # interface GigabitEthernet1/0/29 port access vlan 41 # interface GigabitEthernet1/0/30 port access vlan 45 # interface GigabitEthernet1/0/31 port access vlan 44 # interface GigabitEthernet1/0/32 port access vlan 40 # interface GigabitEthernet1/0/33 port access vlan 43 # interface GigabitEthernet1/0/34 port access vlan 38 # interface GigabitEthernet1/0/35 port access vlan 42 # interface GigabitEthernet1/0/36 port access vlan 39 # interface GigabitEthernet1/0/37 port access vlan 70 # interface GigabitEthernet1/0/38 port access vlan 71 # interface GigabitEthernet1/0/39 port access vlan 60 # interface GigabitEthernet1/0/40 port access vlan 58 # interface GigabitEthernet1/0/41 port access vlan 56 # interface GigabitEthernet1/0/42 port access vlan 59 # interface GigabitEthernet1/0/43 port access vlan 59 # interface GigabitEthernet1/0/44 port access vlan 53 # interface GigabitEthernet1/0/45 shutdown # interface GigabitEthernet1/0/46 shutdown # interface GigabitEthernet1/0/47 shutdown # interface GigabitEthernet1/0/48 shutdown # interface GigabitEthernet1/0/49 port access vlan 77 # interface GigabitEthernet1/0/50 port access vlan 76 # interface GigabitEthernet1/0/51 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/52 port access vlan 2 # ip route-static 0.0.0.0 0.0.0.0 192.168.31.14 # user-interface aux 0 8 user-interface vty 0 4 user privilege level 3 set authentication password cipher 14D,H\!5YM2P6K8O-&0`4!!! # return
墨峰 九段
粉丝:51人 关注:6人
排查一下是否有arp? 包是的有发出来? 做一下流统确认丢包位置。
没有ARP,是配置的问题。
zhiliao_tqKww 发表时间:2018-01-29
回复zhiliao_tqKww:
这个配置占出来太多了 可以精简下必要的配置。
墨峰 发表时间:2018-01-29
jlubao 五段
粉丝:5人 关注:3人
接一台PC机测试一下
zhiliao_2Fq1d 知了小白
太阳城娱乐平台***.***/index.html
