求助,交换机多VLAN静态路由设置
2018-01-29提问
  • 1收藏,3661浏览
网络拓扑,5500一台,5130三台,多VLAN。
用台式可以联通外网,但是切交换机后,在VLAN下不行。
在交换机上可以PING通公网dns地址。
#interface GigabitEthernet1/0/47
 port link-mode bridge
 port access vlan 99
#Vlan-interface99
 ip address 192.168.28.178 255.255.255.248
# route-static 0.0.0.0 0 192.168.28.177
 version 7.1.070, ESS 1110P05
 sysname H3C-1
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 3
 dhcp enable
 lldp global enable
 password-recovery enable
vlan 1
 description yunwei
vlan 10
 description HuaBeiPeiXun
vlan 11
 description kefanggongwang
vlan 43
 description kefangneiwang
vlan 44
 description bangongneiwang
vlan 99
 description WAN
vlan 100
 description hbpxbg
vlan 101
 description qiantai
 stp global enable
dhcp server ip-pool 10.52.43.0
 gateway-list 10.52.43.1
 network 10.52.43.0 mask 255.255.255.0
 dns-list 223.5.5.5 223.6.6.6 114.114.114.114
 expired day 2
dhcp server ip-pool 10.52.44.0
 gateway-list 10.52.44.1
 network 10.52.44.0 mask 255.255.255.0
 expired day 30
dhcp server ip-pool 192.168.0.0
 gateway-list 192.168.0.1
 network 192.168.0.0 mask 255.255.255.0
 expired day 0 hour 8
dhcp server ip-pool 192.168.1.0
 gateway-list 192.168.1.1
 network 192.168.1.0 mask 255.255.255.0
dhcp server ip-pool 192.168.10.0
 gateway-list 192.168.10.1
 network 192.168.10.0 mask 255.255.255.0
 expired day 7
dhcp server ip-pool 192.168.100.0
 gateway-list 192.168.100.1
 network 192.168.100.0 mask 255.255.255.0
 expired day 100
dhcp server ip-pool 192.168.11.0
 gateway-list 192.168.11.1
 network 192.168.11.0 mask 255.255.255.0
 expired day 30
interface NULL0
interface Vlan-interface1
 ip address 192.168.100.101 255.255.255.0
interface Vlan-interface10
 ip address 192.168.0.1 255.255.255.0
interface Vlan-interface43
 ip address 10.52.43.1 255.255.255.0
interface Vlan-interface44
 ip address 10.52.44.1 255.255.255.0
interface Vlan-interface99
interface Vlan-interface100
 ip address 192.168.10.1 255.255.255.0
interface Vlan-interface101
 ip address 192.168.11.1 255.255.255.0
interface FortyGigE1/0/53
interface FortyGigE1/0/54
省略
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
 port link-type trunk
 port trunk permit vlan 1 to 1000
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
 port access vlan 99
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface M-GigabitEthernet0/0/0
 undo dhcp select server
interface Ten-GigabitEthernet1/0/51
interface Ten-GigabitEthernet1/0/52
 scheduler logfile size 16
line class aux
 user-role network-admin
line class vty
 user-role network-operator
line aux 0
line vty 0 63
 ip route-static 0.0.0.0 0 192.168.28.177
radius scheme system
 user-name-format without-domain
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
省略
role name level-14
 description Predefined level-14 role
user-group system
local-user hbpx class manage
 password hash $h$6$A0boum1NPO7VhAT/$ThJVWfnk2DNdfp50hHT5Qo2tibVcBIm5v7z5QaQT5DVI2CbqO9q+zOMvBjKMPyO4Y4dv0SXX8ZYYr/UKcLZHaA==
 service-type http
 ip http enable
 ip https enable
return
li 四段
粉丝:2人 关注:0人
能简要描述下互联情况,拓扑吗?配置有些眼花缭乱,
简单的说,就是我用电脑可以上网,中间加上了交换机就不行了
zhiliao_tqKww 发表时间:2018-01-29
目的就是三层交换机划分多vlan后通过路由器上网 ,
回复zhiliao_tqKww:
这个简单,交换机连接路由器接口模式配置为access ,起int vlan 接口做为三层互联使用,交换机接下行接入或者PC,如果是接接入交换机,接入交换机有划VLAN,则三层交换机配置为trunk模式,起int vlan 接口,并配置默认路由指向路由器,路由器写明细路由到交换机下行的三个网段,类似于单臂路由
li 发表时间:2018-01-29
zhiliao_2Fq1d 知了小白
太阳城娱乐网站***.***/index.html
