iLO5怎么安装中文语言包?
2019-12-03提问
  • 4收藏,3675浏览
粉丝:12人 关注:4人
iLO5怎么安装中文语言包?
粉丝:13人 关注:3人
首先我们去https://support.hpe.com/hpesc/public/home   惠普官方网站去找iLO5中文语言包
如图我们找到对应的版本,下载解压
打开iLO5,在flash firmware界面选择 .lpk 文件进行更新
安装中
安装成功,重新启动
我们可以看到多出了一个选项,地球形状,那个就是来选择语言的选项
接下来我们把它切换到中文,成功。
创作不易,希望采纳点赞哦。
ilo webInstall the language pack using one of these options:
  • Run the Component on the host to be updated.  The component will update the iLO 5 language pack.
  • Extract the language pack from the component.  This will place the language image file, lang_zh_yyy.lpk (where yyy represents the language pack version) in the target directory.  You now have these options:
    • Login to iLO 5, navigate to the Update Firmware page, and update the firmware from there.
    • Use the HPE Lights-Out Configuration Utility, CPQLOCFG, and RIBCL/XML scripts to update iLO 5 across the network.
    • Use the HPE Online Lights-Out Configuration utility, HPONCFG, and RIBCL/XML scripts to update iLO 5 from the supported host OS.
