单向访问控制
2019-12-05提问
  • 1收藏,1046浏览
粉丝:0人 关注:2人
三层交换机上两个VLAN,VLAN10和VLAN20,怎么配置能做到VLAN10可以访问VLAN20,VLAN20不能访问VLAN10
粉丝:124人 关注:6人
可使用acl来实现,举例如下:
假设有vlan 10:192.168.10.0/24和vlan 20:192.168.20.0/24,允许vlan 10访问vlan 20,vlan20不能访问vlan 10,配置如下:
acl number 3000
rule 0 permit ip source 192.168.10.0 0.0.0.255 destination 192.168.20.0 0.0.0.255
acl number 3001
rule 1 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
vlan 10
int vlan 10
ip address 192.168.10.1 24
packet-filter 3000 inbound
vlan 20
ip address 192.168.20.1 24
packet-filter 3001 inbound
测试了,无法ping通,两边都只能ping通到网关
zhiliao_FxxCR 发表时间:2019-12-05
回复zhiliao_FxxCR:
两个网关都是在同一台交换机上吗?
得闲饮茶013 发表时间:2019-12-05
对啊
参考下我修改的策略看下?
还是不行
回复zhiliao_FxxCR:
把acl配置过程导出来看看?另外dis acl all查看匹配的情况。
interface Vlan-interface10 ip address 192.168.10.254 255.255.255.0 packet-filter 3000 inbound # interface Vlan-interface20 ip address 192.168.20.254 255.255.255.0 packet-filter 3001 inbound interface GigabitEthernet1/0/1 port link-mode bridge port access vlan 10 interface GigabitEthernet1/0/2 port link-mode bridge port access vlan 20 combo enable fiber acl advanced 3000 rule 0 permit ip source 192.168.10.0 0.0.0.255 destination 192.168.20.0 0.0.0.255 # acl advanced 3001 rule 0 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
所有配置,太多了,不太好看
回复zhiliao_FxxCR:
dis acl all看一下匹配的情况
[H3C]dis acl all Advanced IPv4 ACL 3000, 1 rule, ACL's step is 5 rule 0 permit ip source 192.168.10.0 0.0.0.255 destination 192.168.20.0 0.0.0.255 (11 times matched) Advanced IPv4 ACL 3001, 1 rule, ACL's step is 5 rule 0 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255 (20 times matched)
