H3C MSR 36-10怎么恢复出厂设置
2019-12-07提问
  • 1收藏,1142浏览
粉丝:9人 关注:4人
<H3C>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
<H3C>reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
粉丝:0人 关注:6人
6、恢复出厂状态,手动重启生效
restore factory-default
也试试这个,有的设备不一定支持这个命令。楼上重启不保存配置也可以。
