交换机端口随机updown,导致终端随机性网络中断
2019-12-11提问
  • 1收藏,2530浏览
随机掉线用户,IMC用户认证明细显示host careiy,怀疑网络存在问题。
查看交换机发现设备有从上联口收到tc报文,但设备配置了边缘端口和BPDU保护,查看mac漂移无记录。物理线路质量无问题。
%Dec 10 18:11:24:988 2019 ZH-WH-CS-F7DN-JR03 DOT1X/6/DOT1X_LOGIN_SUCC: -IfName=GigabitEthernet1/0/22-MACAddr=6c4b-9092-d772-VLANId=203-UserName=yxyc_guojianfei; The user passed 802.1X authentication and got online successfully. %Dec 10 18:11:18:785 2019 ZH-WH-CS-F7DN-JR03 SHELL/6/SHELL_CMD: -Line=aux0-IPAddr=**-User=**; Command is dis int brief %Dec 10 18:11:17:097 2019 ZH-WH-CS-F7DN-JR03 CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=3-CommandSource=snmp-COnfigSource=startup-COnfigDestination=running; Configuration is changed. %Dec 10 18:10:46:894 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:46:844 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:46:757 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:46:728 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:39:587 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:39:552 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:39:517 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:39:490 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:10:14:639 2019 ZH-WH-CS-F7DN-JR03 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is 6c4b-9092-d772, Port ID is 6c4b-9092-d772. %Dec 10 18:09:58:858 2019 ZH-WH-CS-F7DN-JR03 IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is up. %Dec 10 18:09:58:848 2019 ZH-WH-CS-F7DN-JR03 IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is up. %Dec 10 18:09:55:551 2019 ZH-WH-CS-F7DN-JR03 IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is down. %Dec 10 18:09:55:547 2019 ZH-WH-CS-F7DN-JR03 IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is down. %Dec 10 18:09:41:429 2019 ZH-WH-CS-F7DN-JR03 IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is up. %Dec 10 18:09:41:416 2019 ZH-WH-CS-F7DN-JR03 IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is up. %Dec 10 18:09:38:927 2019 ZH-WH-CS-F7DN-JR03 IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is down. %Dec 10 18:09:38:900 2019 ZH-WH-CS-F7DN-JR03 IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is down. %Dec 10 18:07:04:063 2019 ZH-WH-CS-F7DN-JR03 IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is up. %Dec 10 18:07:04:045 2019 ZH-WH-CS-F7DN-JR03 IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is up. %Dec 10 18:07:01:375 2019 ZH-WH-CS-F7DN-JR03 IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is down. %Dec 10 18:07:01:371 2019 ZH-WH-CS-F7DN-JR03 IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is down. %Dec 10 18:06:40:075 2019 ZH-WH-CS-F7DN-JR03 DOT1X/6/DOT1X_LOGOFF: -IfName=GigabitEthernet1/0/22-MACAddr=6c4b-9092-d772-VLANId=203-UserName=yxyc_guojianfei-ErrCode=1; Session of the 802.1X user was terminated.
粉丝:32人 关注:5人
1/0/22口在up/down,替换看下是否为网线问题。有客户端的1x,一般不会重重置网卡。
所有端口都这样,可以考虑关闭握手undo dot1x handshake
