求教路由命令
  • 1收藏,686浏览
求教命令
想针对交换机的某一个端口或者几个端口进行路由限制访问
只能访问
10.0.0.0段到10.100.0.0段
172.22.72.0段
除了以上的IP段其它网段都不可以访问 尤其是不能访问互联网
比如说下面交换机配置的1口  只能访问10.0.0.0段到10.100.0.0段 172.22.72.0段 掩码是255.255.255.0 其他口没限制
<4haolou-2F-5120-24-2>disp cu
 version 5.20, Release 2220P02
 sysname 4haolou-2F-5120-24-2
 domain default enable system
 telnet server enable
 management-vlan 1000
 dot1x
 dot1x authentication-method eap
 undo ip http enable
 password-recovery enable
vlan 1
vlan 105 to 112
vlan 201 to 203
vlan 401 to 402
vlan 501 to 502
vlan 1000
radius scheme 2000
 primary authentication 10.10.2.50
 primary accounting 10.10.2.50
 key authentication cipher $c$3$lSSr2PnHmtq+rXw/jISZ6zypR7KCv7548A==
 key accounting cipher $c$3$fubUnklnvsm5SrOKZ0a3SasiM7bgd3ZKWQ==
 user-name-format without-domain
domain system
 authentication lan-access radius-scheme 2000 none
 authorization lan-access radius-scheme 2000 none
 accounting lan-access radius-scheme 2000 none
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user 8888
 password cipher $c$3$Gu4faoECzoj5pLanQwyi5VfKAg3diX+4dB0QTg==
 authorization-attribute level 3
 service-type telnet
interface NULL0
interface Vlan-interface1000
 ip address 10.11.1.6 255.255.255.0
 port access vlan 401
 dot1x
粉丝:24人 关注:0人
流量入口配置包过滤,过滤的acl 先放通允许访问的目的网段,最后deny any
# acl number 3501
 rule 10 permit ip source 10.0.0.0 0.255.255.255 destination 10.100.0.0 0.0.255.255   //放通
 rule 20 permit ip source 10.0.0.0 0.255.255.255 destination 172.22.72.0 0.0.0.255    //放通
 rule 100 deny ip  //最后阻断所有
interface GigabitEthernet1/0/12   //流量入口inbound方向调用
 packet-filter 3501 inbound
