网络电话能打不能接
2019-12-21提问
  • 1收藏,1261浏览
icg3000
网络电话能打不能接
粉丝:113人 关注:0人
如果是使用中出现问题,那就不是配置问题。如果是新做的,得检测下配置是否完整。
新配置,怎么检测
zhiliao_5xsG1 发表时间:2019-12-21
这个不好看了,只能对着配置一点点检查了,
知了知了 发表时间:2019-12-21
回复知了知了:
post实体与voip实体同事存在没有问题吧
这个真没有测试过
回复知了知了:
# version 5.20, Release 2514P12 # sysname H3C # domain default enable system # telnet server enable # dar p2p signature-file flash:/p2p_default.mtd # port-security enable # undo ip http enable # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$40gC1cxf/wIJNa1ufFPJsjKAof+QP5aV authorization-attribute level 3 service-type telnet local-user yangguang2016 password cipher $c$3$xuxOmd8ZmnhLpxVgPkatqBcDgbqmWGdB authorization-attribute level 3 service-type telnet # cwmp undo cwmp enable # interface Aux0 async mode flow link-protocol ppp # interface Cellular0/0 async mode protocol link-protocol ppp # interface Ethernet0/0 port link-mode route ip address 10.178.243.251 255.255.255.0 # interface Ethernet0/1 port link-mode route # interface NULL0 # # voice-setup # sip # sip-server # call-rule-set # call-route # dial-program # entity 1001 voip address ip 10.66.13.103 match-template [0.1.2.3.4.5.6.7.8.9].T # entity 1821 pots line 3/3 match-template 1821 # entity 3869 pots line 3/7 match-template 3869 # entity 3898 pots line 3/9 match-template 3898 # entity 5092 pots line 3/13 match-template 5092 # entity 5124 pots line 3/11 match-template 5124 # entity 5125 pots line 3/6 match-template 5125 # entity 5197 pots line 3/0 match-template 5197 # entity 5775 pots line 3/14 match-template 5775 # entity 5828 pots line 3/8 match-template 5828 # entity 6094 pots line 3/5 match-template 6094 # entity 6188 pots line 3/1 match-template 6188 # entity 6382 pots line 3/12 match-template 6382 # entity 6656 pots line 3/2 match-template 6656 # entity 6657 pots line 3/15 match-template 6657 # entity 6658 pots line 3/4 match-template 6658 # entity 7869 pots line 3/
zhiliao_5xsG1 发表时间:2019-12-23
回复zhiliao_5xsG1:
match-template 7869 # entity 20240 voip address ras match-template 0240 # entity 20241 voip address ras match-template 0241 # entity 20242 voip address ras match-template 0242 # entity 20244 voip address ras match-template 0244 # entity 20248 voip address ras match-template 0248 # entity 20249 voip address ras match-template 0249 # entity 20250 voip address ras match-template 0250 # entity 20251 voip address ras match-template 0251 # entity 24358 voip address ras match-template 4358 # entity 25932 voip address ras match-template 5932 # entity 25941 voip address ras match-template 5941 # entity 27044 voip address ras match-template 7044 # aaa-client # gk-client gk-id gkserver gk-addr 10.66.13.104 1719 gw-address 10.178.243.251 gw-id yangguang2016 # subscriber-line3/0 # subscriber-line3/1 # subscriber-line3/2 # subscriber-line3/3 # subscriber-line3/4 # subscriber-line3/5 # subscriber-line3/6
这个配置都乱了,电话应用没有测试过,不好意思,你的情况无无法判别
知了知了 发表时间:2019-12-23
