s5110-28p-pwr光口与光模块设置
2019-12-24提问
  • 1收藏,964浏览
光模块插上之后不能被识别是光口没打开还是光模块的问题,应该怎么设置?
Xcheng 九段
粉丝:121人 关注:3人
根据提示应该是使用了非原装模块或者不适配得模块。
非原装模块或者非支持得模块接上无法保证能正常工作,建议使用原装模块支持得模块来保障稳定可靠。
或者新买得模块的话 建议联系供应商沟通协商解决。
粉丝:0人 关注:6人
不认,换原装的吧
<JK-AS02-S5110>dis int g1/0/25 GigabitEthernet1/0/25 current state: DOWN IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 74ea-c85b-171a Description: GigabitEthernet1/0/25 Interface Loopback is not set Media type is optical fiber, Port hardware type is UNKNOWN_SFP Unknown-speed mode, unknown-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 9600 Broadcast MAX-ratio: 100% Unicast MAX-ratio: 100% Multicast MAX-ratio: 100% PVID: 1 Port link-type: trunk VLAN passing : 1(default vlan), 40, 255 VLAN permitted: 1(default vlan), 40, 255 Trunk port encapsulation: IEEE 802.1q Port priority: 0 Last clearing of counters: Never Peak value of input: 0 bytes/sec, at 00-00-00 00:00:00 Peak value of output: 0 bytes/sec, at 00-00-00 00:00:00 Last 300 seconds input: 0 packets/sec 0 bytes/sec -% Last 300 seconds output: 0 packets/sec 0 bytes/sec -% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input: 0 input errors, 0 runts, - giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, - late collisions - lost carrier, - no carrier 查看第25个端口显示down,现在能确定是光模块的问题还是光口没打开
zhiliao_eE4At4 发表时间:2019-12-24
