路由器多运营商接入,出接口某个公网地址不通
2019-12-26提问
  • 1收藏,1053浏览
路由器由联通双链路,电信双链路接入,4个出接口全部为固定ip,由于运营商给的地址较多,所有在每个出接口下配有多个sub地址,然后四条缺省路由下一跳指到每条线路的网关地址,电信线路缺省路由优先级分别为60、61,联通线路缺省路由优先级为62、63;现在出现的情况是通过公网能ping通电信所有的出接口地址,联通1的出接口地址也能全部ping通,联通2出接口下的58.251.137.242无法ping通,但这个接口下其他的sub地址却可以ping通
4个出接口配置如下
联通1
 interface GigabitEthernet1/5/6/0
 port link-mode route description connect LianTong-01
  ip address 58.251.137.250 255.255.255.248
 ip address 58.251.137.251 255.255.255.248 sub
 ip address 58.251.137.252 255.255.255.248 sub
 ip address 58.251.137.253 255.255.255.248 sub
 ip last-hop hold
 nat outbound
联通2
 interface GigabitEthernet2/5/6/0
 port link-mode route description connect LianTong-02
 ip address 58.251.137.242 255.255.255.248
 ip address 58.251.137.243 255.255.255.248 sub
 ip address 58.251.137.244 255.255.255.248 sub
 ip address 58.251.137.245 255.255.255.248 sub
 ip last-hop hold
 nat outbound
电信1
interface GigabitEthernet1/5/6/1
 port link-mode route description to-DianXin-01
 ip address 113.106.79.2 255.255.255.240
 ip address 113.106.79.3 255.255.255.240 sub
 ip address 113.106.79.4 255.255.255.240 sub
 ip address 113.106.79.5 255.255.255.240 sub
 ip address 113.106.79.6 255.255.255.240 sub
 ip address 113.106.79.7 255.255.255.240 sub
 ip address 113.106.79.8 255.255.255.240 sub
 ip address 113.106.79.9 255.255.255.240 sub
 ip address 113.106.79.10 255.255.255.240 sub
 ip address 113.106.79.11 255.255.255.240 sub
 ip address 113.106.79.12 255.255.255.240 sub
 ip address 113.106.79.13 255.255.255.240 sub
 ip address 113.106.79.14 255.255.255.240 sub
 ip last-hop hold
电信2
 interface GigabitEthernet2/5/6/1
 port link-mode route description to-dianxin-02
 ip address 61.144.253.18 255.255.255.240
 ip address 61.144.253.19 255.255.255.240 sub
 ip address 61.144.253.20 255.255.255.240 sub
 ip address 61.144.253.21 255.255.255.240 sub
 ip address 61.144.253.22 255.255.255.240 sub
 ip address 61.144.253.23 255.255.255.240 sub
 ip address 61.144.253.24 255.255.255.240 sub
 ip address 61.144.253.25 255.255.255.240 sub
 ip address 61.144.253.26 255.255.255.240 sub
 ip address 61.144.253.27 255.255.255.240 sub
 ip address 61.144.253.28 255.255.255.240 sub
 ip address 61.144.253.29 255.255.255.240 sub
 ip address 61.144.253.30 255.255.255.240 sub
 ip last-hop hold
缺省路由
  ip route-static 0.0.0.0 0 61.144.253.17
 ip route-static 0.0.0.0 0  113.106.79.1   preference 61
 ip route-static 0.0.0.0 0 58.251.137.249  preference 62
 ip route-static 0.0.0.0 0 58.251.137.241  preference 63
粉丝:18人 关注:1人
看一下这个地址直接配在电脑上能不能ping通呢?
在电脑上是可以的,我觉得是路由的问题,我如果把联通1的出接口shutdown,那么联通2所有的地址就都能ping通,重启undo shutdown后,该地址就又不通了
无敌细心小郎君 发表时间:2019-12-26
那就不太清楚了,看看有没有其他大神
zhiliao_mlw0U 发表时间:2019-12-26
Elin 四段
粉丝:8人 关注:1人
路由器上带源58.251.137.242ping网关看通不通
粉丝:111人 关注:1人
ping的时候 dis session table ipv4 source-ip  destination-ip  看下会话的出入方向就知道了
