vlan设置问题
2019-12-28提问
  • 1收藏,1168浏览
S5560(1台)+S5130(3台),目前问题网管IP(192.168.1.1~192.168.1.4,)相互不能通讯,尽可能不动原来的业务,使网管IP通讯。
客户S5560原VLAN 设置 , 6 7 8 口下联 S5130 28口
# vlan 1
# vlan 10
# vlan 20
# vlan 30
# vlan 40
# vlan 50
# interface Vlan-interface1 ip address 192.168.1.1 255.255.0.0
# interface Vlan-interface10 ip address 192.168.10.2 255.255.255.0
# interface Vlan-interface20 ip address 192.168.20.2 255.255.255.0
# interface Vlan-interface30 ip address 192.168.30.2 255.255.255.0
# interface Vlan-interface40 ip address 192.168.40.2 255.255.255.0
# interface Vlan-interface50 ip address 192.168.50.2 255.255.255.0
# interface GigabitEthernet1/0/1
 port link-mode bridge
 port access vlan 10
# interface GigabitEthernet1/0/4
 port access vlan 10
# interface GigabitEthernet1/0/5
 port access vlan 20
# interface GigabitEthernet1/0/6
 port access vlan 30
# interface GigabitEthernet1/0/7
 port access vlan 40
# interface GigabitEthernet1/0/8
 port access vlan 40
# interface GigabitEthernet1/0/9
 port access vlan 50
# interface GigabitEthernet1/0/20
 port link-type trunk
 port trunk permit vlan all
 combo enable copper
# interface GigabitEthernet1/0/21
 combo enable copper
dis vlan b
Brief information about all VLANs: Supported Minimum VLAN ID: 1 Supported Maximum VLAN ID: 4094 Default VLAN ID: 1
VLAN    ID     Name     Port
1 VLAN 0001 GE1/0/20 GE1/0/21 GE1/0/22 GE1/0/23 GE1/0/24
10 VLAN 0010 GE1/0/1 GE1/0/4 GE1/0/20 GE1/0/21 GE1/0/22
20 VLAN 0020 GE1/0/5 GE1/0/20 GE1/0/21 GE1/0/22
30 VLAN 0030 GE1/0/6 GE1/0/20 GE1/0/21 GE1/0/22
40 VLAN 0040 GE1/0/7 GE1/0/8 GE1/0/20 GE1/0/21 GE1/0/22
50 VLAN 0050 GE1/0/9 GE1/0/20 GE1/0/21 GE1/0/22
S5130原VLAN 设置 (192.168.1.2~4设置相同) 28口 上联
 # vlan 1 #
# interface Vlan-interface1 ip address 192.168.1.2 255.255.255.0
 poe enable
 poe enable
# interface GigabitEthernet1/0/28
 combo enable fiber
dis vlan brief
VLAN ID Name Port
1 VLAN 0001 GE1/0/1 GE1/0/2  GE1/0/28
粉丝:13人 关注:0人
 port access vlan 30
 port access vlan 40
 port access vlan 40
四台的管理地址都是在vlan1的,那这个时候要都在vlan1才能通信,如果要划分vlan,交换机之间的互联接口都改成trunk,放行对应的业务vlan,然后pvid用vlan1就可以了。
zhiliao_FW1tgw 知了小白
现在分支交换机的业务和管理都在VLAN1 里面。业务数据VLAN不能动。可以改管理VLAN。
如何让S5130的管理VLAN,进入S5560上VLAN1里面?
