F100-C-G2图形界面或是命令行开通 l2tp over ipsec方法
2019-12-30提问
  • 1收藏,930浏览
现在这台设备可以正常上网,工作一切正常。为满足员工出差后进内网办公安全,所以想给每位出差员工一个vpn进入防火墙的权限。特别想知道这款
H3C SecPath F100-C-G2 Version 7.1.064, Release 9510P05  开通l2tp over ipsec的方法或是脚本。谢谢!
互联网接口为固定公网IP。在1/0/10口。  19.18.12.134/30
内网接口在1/0/4口。内网段,10.9.0.0/24
yuren 九段
粉丝:16人 关注:3人
#开启L2TP功能
<H3C>system-view
[H3C]l2tp enable
#创建地址池
[H3C]ip pool 1 192.168.10.2 192.168.10.200
#创建一个虚模板,指定地址池
[H3C]interface Virtual-Template1
[H3C-Virtual-Template1] ppp authentication-mode chap domain system
[H3C-Virtual-Template1]remote address pool 1
[H3C-Virtual-Template1]ip address 192.168.10.1 24
[H3C-Virtual-Template1]quit
#创建l2tp
[H3C]l2tp-group 1 mode lns
[H3C-l2tp1] allow l2tp virtual-template 1
[H3C-l2tp1]undo tunnel authentication
[H3C-l2tp1]quit
#创建本地用户
[H3C]local-user 123 class network
[H3C-luser-network-123]password simple 123456
[H3C-luser-network-123]service-type ppp
[H3C-luser-network-123]quit
#创建多个ike安全提议,采用不同的加密算法和验证算法
[H3C]ike proposal 1
[H3C-ike-proposal-1]encryption-algorithm aes-cbc-128
[H3C-ike-proposal-1]authentication-algorithm md5
[H3C-ike-proposal-1]dh group2
[H3C]ike proposal 2
[H3C-ike-proposal-2]encryption-algorithm 3des-cbc
[H3C-ike-proposal-2]authentication-algorithm md5
[H3C-ike-proposal-2]dh group2
[H3C]ike proposal 3
[H3C-ike-proposal-3]encryption-algorithm 3des-cbc
[H3C-ike-proposal-3]dh group2
[H3C]ike proposal 4
[H3C-ike-proposal-4]encryption-algorithm aes-cbc-256
[H3C-ike-proposal-4]dh group2
[H3C]ike proposal 5
[H3C-ike-proposal-5]dh group2
[H3C]ike proposal 6
[H3C-ike-proposal-6]encryption-algorithm aes-cbc-192
[H3C-ike-proposal-6]dh group2
#配置ike keychain,配置对端地址为0.0.0.0,预共享密钥为123456
[H3C]ike keychain 1
[H3C-ike-keychain-1]pre-shared-key address 0.0.0.0 0 key simple 123456
#配置ike profile,引用ike keychainike安全提议,本端公网地址为198.76.28.30
[H3C]ike profile 1
[H3C-ike-profile-1]keychain 1
[H3C-ike-profile-1]exchange-mode aggressive
[H3C-ike-profile-1]local-identity address 198.76.28.30
[H3C-ike-profile-1]match remote identity address 0.0.0.0 0.0.0.0
[H3C-ike-profile-1]proposal 1 2 3 4 5 6
#配置多个ipsec安全提议,采用不同的验证算法和加密算法
[H3C]ipsec transform-set 1
[H3C-ipsec-transform-set-1]encapsulation-mode transport
[H3C-ipsec-transform-set-1]esp encryption-algorithm aes-cbc-128
[H3C-ipsec-transform-set-1]esp authentication-algorithm sha1
[H3C]ipsec transform-set 2
[H3C-ipsec-transform-set-2]encapsulation-mode transport
[H3C-ipsec-transform-set-2]esp encryption-algorithm aes-cbc-256
[H3C-ipsec-transform-set-2]esp authentication-algorithm sha1
[H3C]ipsec transform-set 3
[H3C-ipsec-transform-set-3]encapsulation-mode transport
[H3C-ipsec-transform-set-3]esp encryption-algorithm 3des-cbc
[H3C-ipsec-transform-set-3]esp authentication-algorithm sha1
[H3C]ipsec transform-set 4
[H3C-ipsec-transform-set-4]encapsulation-mode transport
[H3C-ipsec-transform-set-4]esp encryption-algorithm des-cbc
[H3C-ipsec-transform-set-4]esp authentication-algorithm sha1
[H3C]ipsec transform-set 5
[H3C-ipsec-transform-set-5]encapsulation-mode transport
[H3C-ipsec-transform-set-5]esp encryption-algorithm aes-cbc-192
[H3C-ipsec-transform-set-5]esp authentication-algorithm sha1
[H3C]ipsec transform-set 6
[H3C-ipsec-transform-set-6]encapsulation-mode transport
#配置一个名字为1,序号为1的安全策略模板,引用ike profileipsec安全提议
[H3C]ipsec policy-template 1 1
[H3C-ipsec-policy-template-1-1]
[H3C-ipsec-policy-template-1-1]transform-set 1 2 3 4 5 6
[H3C-ipsec-policy-template-1-1]ike-profile 1
#引用ipsec安全策略模板,创建ipsec安全策略
[H3C]ipsec policy 1 1 isakmp template 1
#在公网口调用ipsec安全策略
[H3C]interface GigabitEthernet 0/0
[H3C-GigabitEthernet0/0]ipsec apply policy 1
zhiliao_FP841 知了小白
按照上述配置,win10配置好连接也正常。可是怎么无法与内/外网通讯呢?
