7503交换机
2020-01-06提问
  • 1收藏,971浏览
console 用户名密码忘了怎么进入命令行
粉丝:1人 关注:3人
在设备启动的时候按Ctrl + B ,进入bootware菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing.......Done.
*                H3C SecPath F1060 BootWare, Version 1.05                  *
Compiled Date       : Oct 27 2014
CPU Type            : xlp208
CPU Clock Speed     : 1600MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 8192MB
Memory Speed        : 1332MHz
BootWare Size       : 768KB
Flash Size          : 8MB
CPLDA Version       : 2.0
CPLDB Version       : 2.0
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.   //表示密码恢复功能开启的
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 8
Clear Image Password Success!
|<1> Boot System                                                          |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 1
等设备启动起来后,进入命令行后将console口登录认证改成不认证或者重置console密码
Console设置为不认证:
<H3C>system-view
[H3C]line console 0
[H3C-line-console0]authentication-mode none
[H3C-line-console0]quit
[H3C]save     //保存配置
[H3C]quit
<H3C>reboot   //重启设备
lumm 九段
粉丝:20人 关注:5人
从bootrom的扩展菜单,跳过密码。可以在知了里面搜一搜,有很多案例
