%Feb 6 14:58:47:779 2018 JX-B-XF-HeXin STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/42 was notified a topology change.
%Feb 6 14:58:49:107 2018 JX-B-XF-HeXin STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/37 was notified a topology change.
%Feb 6 14:58:49:655 2018 JX-B-XF-HeXin STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/42 was notified a topology change.
%Feb 6 14:59:03:441 2018 JX-B-XF-HeXin STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/40 was notified a topology change.
%Feb 6 14:59:06:257 2018 JX-B-XF-HeXin STP/6/STP_NOTIFIED_TC: -MDC=1-Slot=2; Instance 0's port GigabitEthernet2/0/38 was notified a topology change.
(4)
。阿里嘎多(。・ω・。)ノ♡ヾ(°ー°ヾ)^?啊咧阿里嘎多(。・ω・。)ノ♡?。ヾ(°ー°ヾ)^?啊咧?阿啊嘎多(。・ω・。)ノ♡。。。。二分五天。。。。
(2)
undo terminal monitor
(9)
优秀
优秀,眼不见心不烦
优秀
秀
如果这些端口确认都是接的终端的话,可以开启边缘端口和bpdu保护。
(14)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
开边缘端口有吗?我开了,还是满屏的,拓扑改变信息,
我遇到几次组网都是这个样子,也开启的边缘端口,还是很多,不是全网没开全吗?这个是解决方案吗?
我的也是,开了,还是满屏的,拓扑改变信息
