现在有一个WA2620i-Agn FAT AP 想接交换机单独使用,但无法通网,请问是什么原因,请看配置命令,不知道哪里出错,恢复出厂后能正常的,就是一配上命令就上不了网,救教
sysname WA2620i-AGN
domain default enable system
telnet server enable
undo wlan-client-isolation enable
port-security enable
password-recovery enable
vlan 1
vlan 100
description server-lan
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
dhcp server ip-pool 100
network 192.168.100.0 mask 255.255.255.0
gateway-list 192.168.100.1
dns-list 8.8.8.8 114.114.114.114
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$6tSpAMAe2g2eYEx7+4oOmeYQlR2bO6u1cJH9qY0=
authorization-attribute level 3
service-type telnet
wlan rrm
dot11a mandatory-rate 6 12 24
dot11a supported-rate 9 18 36 48 54
dot11b mandatory-rate 1 2
dot11b supported-rate 5.5 11
dot11g mandatory-rate 1 2 5.5 11
dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 11 crypto
ssid HILLW
cipher-suite tkip
security-ie rsn
service-template enable
cwmp
undo cwmp enable
interface NULL0
interface Vlan-interface1
ip address 192.168.0.50 255.255.255.0
interface Vlan-interface100
ip address 192.168.100.1 255.255.255.0
description vlan 1
port link-type trunk
port trunk permit vlan all
interface WLAN-BSS11
port access vlan 100
port-security port-mode psk
port-security tx-key-type 11key
port-security preshared-key pass-phrase cipher $c$3$AuF7b+i09ifHBB6uQtGc14f1CI8A+7rN2SMygk+s0w==
interface WLAN-Radio1/0/1
service-template 11 interface wlan-bss 11
interface WLAN-Radio1/0/2
ip route-static 0.0.0.0 0.0.0.0 192.168.10.1
ip route-static 0.0.0.0 0.0.0.0 192.168.0.1
dhcp server forbidden-ip 192.168.100.1
dhcp enable
arp-snooping enable
load xml-configuration
(0)
看你指定了静态路由,192.168.0.1地址是在上层设备?你在胖ap上直接带源:192.168.0.50可以ping通外网不吗。单看无线侧配置没什么问题,应该还是有线路径问题
(0)
上层获取的是,192.168.10.1 网段的
192。168。0。1是默认的,没删除
PING 192。168。100网段和,192.168.0.50都能通,就是上级的,192。168。10。1不通
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
