wap722E改FAT模式加载启动报错
2020-02-11提问
  • 1收藏,955浏览
 <H3C>dir
Directory of flash:
 0 -rw- 137 Oct 18 2019 23:07:23 ifindex.dat
 1 -rw- 760 Oct 18 2019 23:07:23 startup.cfg
 2 -rw- 27029 Oct 18 2019 23:07:23 startup.mdb
 3 -rw- 2599936 Jan 01 2014 00:01:48 wa4300-boot.bin
 4 -rw- 15030272 Jan 01 2014 00:03:00 wa4300-system.bin
 5 -rw- 10963968 Oct 18 2019 23:02:03 wa4300_fat.bin 131072 KB total (101816 KB free)
 <H3C>boot-loader file flash:/wa4300_fat.bin main
This command will set the main startup software images. Continue? [Y/N]:y
 flash:/wa4300_fat.bin is not supported by the device.
粉丝:7人 关注:1人
V7 AP在没有AC的情况下需要降级到V5才能导入胖版本。
1    实验需求
V7AP在没有AC的情况下需要降级到V5才能导入胖版本
2    操作步骤
==============<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9):
//此时选择Ctrl+F格式化
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 3
====================<EnterEthernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Update Backup Application File                                        |
|<4> Update Secure Application File                                        |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5
========= =====<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :tftp
Load File Name        :0
                     :wa2600a_fat.bin
Target File Name       :0
                     :wa2600a_fat.bin
Server IP Address      :192.168.1.1
Local IP Address       :192.168.1.253
Gateway IP Address    :0.0.0.0
=====================<Enter Ethernet SubMenu>==========================
Enter your choice(0-5): 1       //先把BOOT底层降成V5
Loading.....................................................................
...................................Done.
9090048 bytes downloaded!
The image is self-decompressing.............................................
.................................................Done.
Extended BootWare Version is not equal,updating? [Y/N]
Updating Extended BootWare.............Done.
Basic BootWare Version is not equal,updating? [Y/N]
Updating Basic BootWare.............Done.
BootWare updated,System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare....
The Extend BootWare is self-decompressing.........................Done!
*                 H3C WA2620-AGN BootWare, Version 3.03                    *
Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Sep  1 2014
CPU Type            : AR9350
CPU L1 Cache        : 32KB
CPU Clock Speed     : 560MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 480MHz
BootWare Size       : 512KB
Flash Size          : 32MB
CPLD Version        : 004
PCB Version         : Ver.E
Read net params from bootrom failed, use the default value
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BootWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
//再次Ctrl+F格式化
Format success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
==========================<Enter Ethernet SubMenu>==========================
=========<ETHERNET PARAMETER SET>==========================
|          Ctrl+D = Quit.                                                  |
Load File Name         :0
                       :wa2600a_fat.bin
Target File Name       :0
                       :wa2600a_fat.bin
Enter your choice(0-5): 2      //更新主应用文件,即下次启动加载胖版本
...................................Done!
Updating File flash:/wa2600a_fat.bin........................................
Enter your choice(0-5): 0
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 4    //进入文件管理
=====================<File CONTROL>===============================
|<1> Display All File(s)                                                   |
|<2> Set Application File type                                             |
|<3> Delete File                                                           |
Enter your choice(0-3): 1     //查看当前的所有文件
Display all file(s) in flash:
 'M' = MAIN      'B' = BACKUP      'S' = SECURE      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   9090048   Aug/08/2008 20:00:00 M      wa2600a_fat.bin                 |
//说明上传成功
|<3> Delete File                                                           |
Enter your choice(0-3): 0
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
CPU Type            : AR9350
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 128MB
Flash Size          : 32MB
CPLD Version        : 004
PCB Version         : Ver.E
Starting to get the main application file--flash:/wa2600a_fat.bin!..........
The main application file is self-decompressing.............................
.................................................................Done!
System application is starting...
Startup configuration file does not exist.
User interface con0 is available.
Press ENTER to get started.
<WA2620-AGN>dir
Directory of flash:/
   0     -rw-   9090048  Aug 08 2008 20:00:00   wa2600a_fat.bin
30177 KB total (21297 KB free)
<WA2620-AGN>dis version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 1308P11
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C WA2620-AGN uptime is 0 week, 0 day, 0 hour, 0 minute
 CPU type: ATHEROS AR9350
 128M bytes DDR2 SDRAM Memory
 32M bytes Flash Memory
 Pcb             Version:  Ver.E
 CPLD            Version:  004
 Basic  BootROM  Version:  3.03
 Extend BootROM  Version:  3.03
 [SLOT  1]CON           (Hardware)Ver.E,        (Driver)1.0,    (Cpld)4.0
 [SLOT  1]GE1/0/1       (Hardware)Ver.E,        (Driver)1.0,    (Cpld)4.0
 [SLOT  1]RADIO1/0/1    (Hardware)Ver.E,        (Driver)1.0,    (Cpld)4.0
 [SLOT  1]RADIO1/0/2    (Hardware)Ver.E,        (Driver)1.0,    (Cpld)4.0
3   注意事项
1)        V7V5有风险,尽量减少此类操作
2)        上传版本时文件名必须与官网文件名一致,否则上传成功后无法加载。另需注意有时候电脑会隐藏文件扩展名,在上传时软件版本重命名为wa4300s_fat.bin,其实这里的.bin实际上也是文件名而不是扩展名,真正的文件名为:wa4300s_fat.bin.bin,这是微软系统的设置,具体微软系统可百度查询如何关闭隐藏文件扩展名。
3)        上传版本完成后,有任何报错都是不行的,如下报错Set the file attribute failed 设置文件属性失败,此时可考虑AP是否为V5
..Done.
11293696 bytes downloaded!
Saving file flash:/wa4300s_fat.bin .........................................
...........................................................Done.
Set the file attribute failed!
