S5130S-28P-EI-6113做DHCP部分地址池获取不到地址
2018-02-23提问
  • 1收藏,1792浏览
MrH 零段
目前G1/0/24口连接下联交换机G1/0/24,下联交换机自还能获取到196网段的IP,195和197网段无法获取到IP地址
S5130S配置如下:
<H3C>dis cu
<H3C>dis current-configuration
 version 7.1.070, Release 6113
 sysname H3C
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 dhcp enable
 dhcp server forbidden-ip 192.168.195.1 192.168.195.5
 dhcp server forbidden-ip 192.168.195.9
 dhcp server forbidden-ip 192.168.195.251 192.168.195.254
 dhcp server forbidden-ip 192.168.196.1
 dhcp server forbidden-ip 192.168.196.1 192.168.196.20
 dhcp server forbidden-ip 192.168.196.251 192.168.196.254
 dhcp server forbidden-ip 192.168.197.1 192.168.197.5
 dhcp server forbidden-ip 192.168.197.9
 dhcp server forbidden-ip 192.168.197.251 192.168.197.254
 lldp global enable
 password-recovery enable
vlan 1
vlan 195 to 197
dhcp server ip-pool vlan195
 gateway-list 192.168.195.9
 network 192.168.195.0 mask 255.255.255.0
 dns-list 192.168.0.133 192.168.18.180
dhcp server ip-pool vlan196
 gateway-list 192.168.196.9
 network 192.168.196.0 mask 255.255.255.0
dhcp server ip-pool vlan197
 gateway-list 192.168.197.9
 network 192.168.197.0 mask 255.255.255.0
interface NULL0
interface Vlan-interface195
 ip address 192.168.195.9 255.255.255.0
interface Vlan-interface196
 ip address 192.168.196.9 255.255.255.0
interface Vlan-interface197
 ip address 192.168.197.9 255.255.255.0
 port access vlan 196
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
 port access vlan 197
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
 port access vlan 195
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 port link-type trunk
 port trunk permit vlan 1 195 to 197
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
 scheduler logfile size 16
line class aux
 user-role network-admin
line class vty
 user-role network-operator
line aux 0
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 192.168.196.1
 snmp-agent
 snmp-agent local-engineid 800063A280307BAC4F162800000001
 snmp-agent community read public
 snmp-agent sys-info version all
radius scheme system
 user-name-format without-domain
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$mkYUHGOSWdsBiNfN$yeglSc0h2s9pCxUouB6XxgUpXo57XKnWSBHH/O3U1l8VefiYM3RDpGCzgX9PWoxuAR2f3Si4HeBMV1pLfd9sXw==
 service-type telnet http https
 authorization-attribute user-role level-15
 ip http enable
return
 下联交换机配置如下:S3100V3-28TP-EI
<H3C>dis cu
 sysname H3C
 undo irf link-delay
 dhcp snooping enable
 lldp global enable
vlan 1
vlan 195 to 197
interface NULL0
 ip address 192.168.196.10 255.255.255.0
interface Ethernet1/0/1
interface Ethernet1/0/2
interface Ethernet1/0/3
interface Ethernet1/0/4
interface Ethernet1/0/5
interface Ethernet1/0/6
interface Ethernet1/0/7
interface Ethernet1/0/8
interface Ethernet1/0/9
interface Ethernet1/0/10
interface Ethernet1/0/11
interface Ethernet1/0/12
interface Ethernet1/0/13
interface Ethernet1/0/14
interface Ethernet1/0/15
interface Ethernet1/0/16
line class aux
line class vty
line aux 0
line vty 0 63
 snmp-agent
 snmp-agent local-engineid 800063A28038AD8E5D842A00000001
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
 password hash $h$6$jjFXlJ+il5O3apqQ$BEC8crnfZre4ZZYkQ+64KHd2QMAIf+QR2oywZVvfstntbm6sqOXl2BdC+DIvxJNLDilMD0jTHSlg2bUK1MNTVQ==
 ip http enable
return
 S5130---S3100V3-28TP-EI
寂东 九段
粉丝:225人 关注:3人
那个网段获取不到地址,获取不到地址的终端,连接在哪台交换机的哪个端口下,该交换机和端口配置贴一下,还有,是整个网段都获取不到地址,还是个别终端获取不到地址 ?
195和197网段都获取不到地址,接口接在对应的vlan下面,vlan196可以正常获取,195和197网段全部的终端都无法获取到,配置上面都有了。
MrH 发表时间:2018-02-23
回复MrH:
配置上没看出设么问题,在获取不到地址的终端下,执行如下命令试试,ipconfig/release ; ipconfig/renew
寂东 发表时间:2018-02-23
粉丝:3人 关注:0人
看配置,196网段是手工配置的吧?195和197接口并没有配置ip address dhcp-alloc,肯定无法自动获取地址
196网段也没配置ip address dhcp-alloc,没有手工配置,也是自动获取的,这个命令的作用是什么呢?
MrH 发表时间:2018-02-23
回复MrH:
不应该,这个命令就是用来配置自动获取地址的。 1.4.5 ip address dhcp-alloc ip address dhcp-alloc命令用来配置接口通过DHCP协议获取IP地址。 undo ip address dhcp-alloc命令用来取消接口通过DHCP协议获取IP地址。 【命令】 ip address dhcp-alloc undo ip address dhcp-alloc 【缺省情况】 接口不通过DHCP协议获取IP地址。
爱吃糖的抑郁小逗比 发表时间:2018-02-23
回复MrH:
196网段配置了ip address 192.168.196.10 255.255.255.0,如果是自动获取的地址,是不会在配置中出现的
zhiliao_susuqtt 发表时间:2018-02-23
