msr56-60接口板卡阶段性识别不到
2020-02-19提问
  • 1收藏,1292浏览
检查日志,有过板卡加载不到和恢复的信息,但最后一次没有恢复
%Feb 11 08:24:56:434 2020 Router-4 OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 172.16.200.25(GigabitEthernet2/1/22) changed from FULL to DOWN.
%Feb 11 08:25:00:169 2020 Router-4 DEV/3/BOARD_REMOVED: Board was removed from slot 2, type is SPU-200.
%Feb 11 08:25:01:920 2020 Router-4 DEV/5/BOARD_REBOOT: Board is rebooting on slot 2.
%Feb 11 08:25:05:923 2020 Router-4 DEV/5/BOARD_REBOOT: Board is rebooting on slot 2.
%Feb 11 08:25:15:658 2020 Router-4 DEV/4/BOARD_LOADING: Board in slot 2 is loading software images.
%Feb 11 08:25:22:745 2020 Router-4 DEV/5/LOAD_FINISHED: Board in slot 2 has finished loading software images. %Feb 11 08:25:44:969 2020 Router-4 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 2, type is unknown.
%Feb 11 08:25:45:194 2020 Router-4 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on slot 2, type is SPU-200. %Feb 11 08:25:58:796 2020 Router-4 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/1/21 changed to up.
%Feb 11 08:25:58:797 2020 Router-4 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/1/21 changed to up.
%Feb 11 08:25:58:964 2020 Router-4 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/1/22 changed to up.
%Feb 11 08:25:58:964 2020 Router-4 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/1/22 changed to up.
最后一次接口板识别不到,没有恢复,日志中提示,配置中接口消失
%Feb 19 04:27:54:234 2020 Router-4 DEV/4/BOARD_LOADING: Board in slot 2 is loading software images.
%Feb 19 04:28:01:321 2020 Router-4 DEV/5/LOAD_FINISHED: Board in slot 2 has finished loading software images.
%Feb 19 04:28:14:570 2020 Router-4 DEV/3/BOARD_REMOVED: Board was removed from slot 2, type is SPU-200.
串联到网络中  防火墙-路由器(msr36-60)-服务器
升级到最新版本看一下,还有问题可能是硬件问题
