Jan 8 2020 12:12:47+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[0]:Slot=2;A parity check error occurs on the board. Jan 8 2020 02:02:40+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[1]:Slot=2;A parity check error occurs on the board. Jan 7 2020 15:52:34+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[2]:Slot=2;A parity check error occurs on the board. Jan 7 2020 05:42:27+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[3]:Slot=2;A parity check error occurs on the board. Jan 6 2020 19:32:20+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[4]:Slot=2;A parity check error occurs on the board. Jan 6 2020 09:22:14+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[5]:Slot=2;A parity check error occurs on the board. Jan 5 2020 23:12:06+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[6]:Slot=2;A parity check error occurs on the board. Jan 5 2020 13:02:00+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[7]:Slot=2;A parity check error occurs on the board. Jan 5 2020 02:51:53+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[8]:Slot=2;A parity check error occurs on the board. Jan 4 2020 16:41:46+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[9]:Slot=2;A parity check error occurs on the board. Jan 4 2020 14:18:26+08:00 HK-XinDaLou-HJ %%01MSTP/4/EDGE_PORT(l)[10]:Edged-port GigabitEthernet2/0/15 received BPDU packet, then the active state of the edged-port will be disabled! Jan 4 2020 14:18:26+08:00 HK-XinDaLou-HJ %%01MSTP/4/EDGE_PORT(l)[11]:Edged-port GigabitEthernet2/0/12 received BPDU packet, then the active state of the edged-port will be disabled! Jan 4 2020 14:18:26+08:00 HK-XinDaLou-HJ %%01MSTP/4/EDGE_PORT(l)[12]:Edged-port GigabitEthernet2/0/13 received BPDU packet, then the active state of the edged-port will be disabled! Jan 4 2020 14:18:25+08:00 HK-XinDaLou-HJ %%01MSTP/4/EDGE_PORT(l)[13]:Edged-port GigabitEthernet2/0/11 received BPDU packet, then the active state of the edged-port will be disabled! Jan 4 2020 14:18:25+08:00 HK-XinDaLou-HJ %%01MSTP/4/EDGE_PORT(l)[14]:Edged-port GigabitEthernet2/0/14 received BPDU packet, then the active state of the edged-port will be disabled! Jan 4 2020 14:18:06+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[15]:Interface GigabitEthernet2/0/15 has turned into UP state. Jan 4 2020 14:18:06+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[16]:Interface GigabitEthernet2/0/12 has turned into UP state. Jan 4 2020 14:18:06+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[17]:Interface GigabitEthernet2/0/11 has turned into UP state. Jan 4 2020 14:18:06+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[18]:Interface GigabitEthernet2/0/14 has turned into UP state. Jan 4 2020 14:18:06+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[19]:Interface GigabitEthernet2/0/13 has turned into UP state. Jan 4 2020 14:06:26+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[20]:Interface GigabitEthernet2/0/14 has turned into DOWN state. Jan 4 2020 14:06:26+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[21]:Interface GigabitEthernet2/0/12 has turned into DOWN state. Jan 4 2020 14:06:26+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[22]:Interface GigabitEthernet2/0/13 has turned into DOWN state. Jan 4 2020 14:06:26+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[23]:Interface GigabitEthernet2/0/15 has turned into DOWN state. Jan 4 2020 14:06:26+08:00 HK-XinDaLou-HJ %%01IFPDT/4/IF_STATE(l)[24]:Interface GigabitEthernet2/0/11 has turned into DOWN state. Jan 4 2020 06:31:40+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[25]:Slot=2;A parity check error occurs on the board. Jan 4 2020 04:55:48+08:00 HK-XinDaLou-HJ %%01INFO/4/SUPPRESS_LOG(l)[26]:Last message repeated 2 times.(InfoID=1082212355, ModuleName=SNMP, InfoAlias=SNMP_FAIL) Jan 4 2020 04:54:58+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_FAIL(s)[27]:Failed to login through SNMP. (Ip=XX.XX.XX.XX, Times=6, Reason=the version was incorrect, VPN= ) Jan 4 2020 04:54:41+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_IPUNLOCK(s)[28]:The source IP was unlocked.(SourceIP=XX.XX.XX.XX, VPN= ) Jan 4 2020 04:54:23+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_IPLOCK(s)[29]:The source IP was locked because of the failure of login through SNMP.(SourceIP=XX.XX.XX.XX, VPN= ) Jan 4 2020 04:54:23+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_FAIL(s)[30]:Failed to login through SNMP. (Ip=XX.XX.XX.XX, Times=5, Reason=the community was incorrect, VPN= ) Jan 4 2020 04:54:09+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_IPUNLOCK(s)[31]:The source IP was unlocked.(SourceIP=XX.XX.XX.XX, VPN= ) Jan 4 2020 04:53:59+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_IPLOCK(s)[32]:The source IP was locked because of the failure of login through SNMP.(SourceIP=XX.XX.XX.XX, VPN= ) Jan 4 2020 04:53:59+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_FAIL(s)[33]:Failed to login through SNMP. (Ip=XX.XX.XX.XX, Times=4, Reason=the community was incorrect, VPN= ) Jan 4 2020 04:53:59+08:00 HK-XinDaLou-HJ %%01INFO/4/SUPPRESS_LOG(l)[34]:Last message repeated 5 times.(InfoID=1082212355, ModuleName=SNMP, InfoAlias=SNMP_FAIL) Jan 4 2020 04:53:58+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_FAIL(s)[35]:Failed to login through SNMP. (Ip=XX.XX.XX.XX, Times=4, Reason=the version was incorrect, VPN= ) Jan 4 2020 04:44:29+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_IPUNLOCK(s)[36]:The source IP was unlocked.(SourceIP=XX.XX.XX.XX, VPN= ) Jan 4 2020 04:44:19+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_IPLOCK(s)[37]:The source IP was locked because of the failure of login through SNMP.(SourceIP=XX.XX.XX.XX, VPN= ) Jan 4 2020 04:44:19+08:00 HK-XinDaLou-HJ %%01SNMP/4/SNMP_FAIL(s)[38]:Failed to login through SNMP. (Ip=XX.XX.XX.XX, Times=3, Reason=the community was incorrect, VPN= ) Jan 3 2020 20:21:33+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[39]:Slot=2;A parity check error occurs on the board. Jan 3 2020 10:11:26+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[40]:Slot=2;A parity check error occurs on the board. Jan 3 2020 00:01:19+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[41]:Slot=2;A parity check error occurs on the board. Jan 2 2020 13:51:13+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[42]:Slot=2;A parity check error occurs on the board. Jan 2 2020 03:41:06+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[43]:Slot=2;A parity check error occurs on the board. Jan 1 2020 17:30:59+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[44]:Slot=2;A parity check error occurs on the board. Jan 1 2020 07:20:53+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[45]:Slot=2;A parity check error occurs on the board. Dec 31 2019 21:10:46+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[46]:Slot=2;A parity check error occurs on the board. Dec 31 2019 11:00:39+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[47]:Slot=2;A parity check error occurs on the board. Dec 31 2019 00:50:32+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[48]:Slot=2;A parity check error occurs on the board. Dec 30 2019 14:40:26+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[49]:Slot=2;A parity check error occurs on the board. Dec 30 2019 04:30:19+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[50]:Slot=2;A parity check error occurs on the board. Dec 29 2019 18:20:12+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[51]:Slot=2;A parity check error occurs on the board. Dec 29 2019 08:10:05+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[52]:Slot=2;A parity check error occurs on the board. Dec 28 2019 21:59:59+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[53]:Slot=2;A parity check error occurs on the board. Dec 28 2019 11:49:52+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[54]:Slot=2;A parity check error occurs on the board. Dec 28 2019 01:39:45+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[55]:Slot=2;A parity check error occurs on the board. Dec 27 2019 15:29:38+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[56]:Slot=2;A parity check error occurs on the board. Dec 27 2019 05:19:32+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[57]:Slot=2;A parity check error occurs on the board. Dec 26 2019 19:09:25+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[58]:Slot=2;A parity check error occurs on the board. Dec 26 2019 08:59:18+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[59]:Slot=2;A parity check error occurs on the board. Dec 25 2019 22:49:11+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[60]:Slot=2;A parity check error occurs on the board. Dec 25 2019 12:39:05+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[61]:Slot=2;A parity check error occurs on the board. Dec 25 2019 02:28:58+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[62]:Slot=2;A parity check error occurs on the board. Dec 24 2019 16:18:51+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[63]:Slot=2;A parity check error occurs on the board. Dec 24 2019 06:08:44+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[64]:Slot=2;A parity check error occurs on the board. Dec 23 2019 19:58:38+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[65]:Slot=2;A parity check error occurs on the board. Dec 23 2019 09:48:31+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[66]:Slot=2;A parity check error occurs on the board. Dec 22 2019 23:38:24+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[67]:Slot=2;A parity check error occurs on the board. Dec 22 2019 13:28:17+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[68]:Slot=2;A parity check error occurs on the board. Dec 22 2019 03:18:11+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[69]:Slot=2;A parity check error occurs on the board. Dec 21 2019 17:08:04+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[70]:Slot=2;A parity check error occurs on the board. Dec 21 2019 06:57:57+08:00 HK-XinDaLou-HJ %%01PARITY/3/PARITY_ERROR(l)[71]:Slot=2;A parity check error occurs on the board.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
不是板卡出问题吗?
