PLAT_7.3_E0703报错安装库文件失败,如何解决?
2020-03-12提问
  • 1收藏,823浏览
xiaoT 一段
情况说明:
宿主系统为:window  server 2016 标准版64位。
数据库为:Sql server 2014  (cn_sql_server_2014_enterprise_edition_with_service_pack_2_x64_dvd_8962407.iso的安装镜像)
IMC平台:H3C_iMC_PLAT_7.3_E0703_Standard_windows.rar 的安装包
按操配置文件要求,完成了操作系统安装,SQL server 2014安装,进行iMC PLAT平台安装的时候,最后一点进度,总是报错安装运行库文件失败。
问题报错如下图。
请教,此类问题如何解决?
李和 六段
粉丝:5人 关注:5人
按照提示路径去执行一下exe文件,或者看一下安装日志有哪些报错
xiaoT 一段
安装步骤到了一定程度后,就报错了。操作截图如下
安装日志报错如下
2020-03-12 13:56:35 [WARN ] [main] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:56:35 [WARN ] [main] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:56:35 [WARN ] [main] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:56:35 [INFO ] [main] [com.h3c.imc.deploy.InstallLauncher::checkEnv(297)] Deploy jar file not found, first installation 2020-03-12 13:56:35 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:56:58 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] start checkVm.... 2020-03-12 13:56:58 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] zip file path:C:\H3C_iMC_PLAT_7.3_E0703_Standard_windows\windows\install\.\components\common\server\commonserver_win.zip 2020-03-12 13:56:58 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] temp execute file path:C:\Users\ADMINI~1\AppData\Local\Temp\commonserver 2020-03-12 13:57:02 [WARN ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1153)] hello run command 2020-03-12 13:57:06 [WARN ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1153)] command run ok 2020-03-12 13:57:06 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] Execute [cmd, /c, anti-vm.bat, 0], return 0 STDOUT: anti-vm.exe TestKVM TestXen TestHyperV TestVMware H3CVM:VMware STDERR: 2020-03-12 13:57:06 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] get VM Type:VMware 2020-03-12 13:57:06 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] end checkVm.... 2020-03-12 13:57:13 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:57:13 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.install.wizard.AgreementPanel::getAgreementText(178)] getAgreementText 2020-03-12 13:57:13 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] agreementPanel.fileName has no custom value 2020-03-12 13:57:13 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getCustomFolderName(3062)] path:C:\H3C_iMC_PLAT_7.3_E0703_Standard_windows\windows\install\./components/common/deploy/custom 2020-03-12 13:57:14 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:57:14 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:57:14 [INFO ] [Thread-3] [com.h3c.imc.deploy.Util::checkReservedPort(1920)] InetAddress.getLocalHost():WIN-J62F9RGM90N/192.168.237.131 2020-03-12 13:57:14 [INFO ] [Thread-3] [com.h3c.imc.deploy.Util::checkReservedPort(1920)] InetAddress.getLocalHost():WIN-J62F9RGM90N/192.168.237.131 2020-03-12 13:57:14 [INFO ] [Thread-3] [com.h3c.imc.deploy.Util::checkReservedPort(1920)] InetAddress.getLocalHost():WIN-J62F9RGM90N/192.168.237.131 2020-03-12 13:57:14 [INFO ] [Thread-3] [com.h3c.imc.deploy.Util::checkReservedPort(1920)] InetAddress.getLocalHost():WIN-J62F9RGM90N/192.168.237.131 2020-03-12 13:57:14 [INFO ] [Thread-3] [com.h3c.imc.deploy.Util::checkReservedPort(1920)] InetAddress.getLocalHost():WIN-J62F9RGM90N/192.168.237.131 2020-03-12 13:57:14 [INFO ] [Thread-3] [com.h3c.imc.deploy.Util::checkReservedPort(1920)] InetAddress.getLocalHost():WIN-J62F9RGM90N/192.168.237.131 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.EnvChecker::checkDatabaseForWindows(613)] System.getProperty.db.type:null 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(361)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2000 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(380)] SOFTWARE\Microsoft\Microsoft SQL Server\80 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(393)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2000 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(412)] SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\80 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(418)] SQLServer 2000 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(438)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2005 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(455)] SOFTWARE\Microsoft\Microsoft SQL Server\90\Tools reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(471)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2005 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(488)] SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\90\Tools reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(497)] SQLServer 2005 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(517)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 10 reg not exit 2020-03-12 13:57:15 [ERROR] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(529)] com.h3c.imc.deploy.dma.win32.Win32Exception: Error retrieving registry value information 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(552)] path is blank 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(565)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 10 reg not exit 2020-03-12 13:57:15 [ERROR] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(577)] com.h3c.imc.deploy.dma.win32.Win32Exception: Error retrieving registry value information 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(600)] path is blank 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(606)] SQLServer 2008 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(626)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 11 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(664)] SOFTWARE\Microsoft\Microsoft SQL Server\110\Tools\ClientSetup reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(674)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 11 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(712)] SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\110\Tools\ClientSetup reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(715)] SQLServer 2012 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2014Installed(732)] SQLServer 2014 is Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(361)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2000 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(380)] SOFTWARE\Microsoft\Microsoft SQL Server\80 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(393)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2000 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(412)] SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\80 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2000Installed(418)] SQLServer 2000 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(438)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2005 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(455)] SOFTWARE\Microsoft\Microsoft SQL Server\90\Tools reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(471)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 2005 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(488)] SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\90\Tools reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2005Installed(497)] SQLServer 2005 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(517)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 10 reg not exit 2020-03-12 13:57:15 [ERROR] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(529)] com.h3c.imc.deploy.dma.win32.Win32Exception: Error retrieving registry value information 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(552)] path is blank 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(565)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 10 reg not exit 2020-03-12 13:57:15 [ERROR] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(577)] com.h3c.imc.deploy.dma.win32.Win32Exception: Error retrieving registry value information 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(600)] path is blank 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2008Installed(606)] SQLServer 2008 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(626)] SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 11 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(664)] SOFTWARE\Microsoft\Microsoft SQL Server\110\Tools\ClientSetup reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(674)] SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server 11 reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(712)] SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\110\Tools\ClientSetup reg not exit 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2012Installed(715)] SQLServer 2012 is not Installed 2020-03-12 13:57:15 [INFO ] [Thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor::isSQLServer2014Installed(732)] SQLServer 2014 is Installed 2020-03-12 13:57:15 [WARN ] [Thread-3] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:01 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::isPortAvailable(4667)] isPortAvailable: 8080 2020-03-12 13:58:01 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::isPortAvailable(4667)] isPortAvailable: 8443 2020-03-12 13:58:01 [INFO ] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2182)] className:com.microsoft.sqlserver.jdbc.SQLServerDriver 2020-03-12 13:58:01 [INFO ] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2185)] URL: jdbc:sqlserver://127.0.0.1:1433;databaseName=master 2020-03-12 13:58:01 [INFO ] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2189)] password = {PROTECTED} 2020-03-12 13:58:01 [INFO ] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2191)] user = sa 2020-03-12 13:58:02 [INFO ] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2214)] Parent: com.h3c.imc.deploy.EnvChecker$DBPasswordCheckDialog 2020-03-12 13:58:03 [INFO ] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doConntest(2382)] Execute [C:\Users\Administrator\AppData\Local\Temp\1583992683124\common\lib\conntest.exe, -User=sa, -Password={PROTECTED}, -Server=127.0.0.1, -Port=1433, -DBName=master, -Lang=zh, -Type=SQLServer], return 0 STDOUT: 测试数据库服务成功! STDERR: 2020-03-12 13:58:04 [INFO ] [Thread-3] [com.h3c.imc.deploy.EnvChecker$7::run(461)] dhcp及eventlog服务重启成功了 2020-03-12 13:58:05 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1512)] InstallFolderChoosePanelDescriptor doWork start ,progress 10 2020-03-12 13:58:06 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.dm 2020-03-12 13:58:06 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.dm.description 2020-03-12 13:58:07 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.icc 2020-03-12 13:58:07 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.icc.description 2020-03-12 13:58:07 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.netasset 2020-03-12 13:58:07 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.netasset.description 2020-03-12 13:58:07 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.nme.fault 2020-03-12 13:58:07 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.nme.fault.description 2020-03-12 13:58:08 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.nme.perf 2020-03-12 13:58:08 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.nme.perf.description 2020-03-12 13:58:08 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.plat 2020-03-12 13:58:08 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.plat.description 2020-03-12 13:58:08 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.report.plat 2020-03-12 13:58:08 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.report.plat.description 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.syslog 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.InstallationComponentInfo::resolveResource(437)] 开始获取%iMC.syslog.description 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(73)] 安装盘上的组件信息 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-DM 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-ICC 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-NETASSET 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-NME-FAULT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-NME-PERF 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-PLAT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-REPORT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(75)] compId:iMC-SYSLOG 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(76)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.ProductInstallingInfo::collectComponentsInfo(77)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1520)] 收集安装盘上的组件信息 ,progress 50 2020-03-12 13:58:09 [WARN ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1526)] 收集已安装的组件信息 ,progress 70 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1528)] 获取 ID 和名称的映射关系,供依赖不满足时显示使用 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1530)] installedInfo 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1535)] installingInfo 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-DM name=智能管理平台 - 网元管理 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-ICC name=智能管理平台 - 智能配置中心 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-NETASSET name=智能管理平台 - 网络资产管理 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-NME-FAULT name=智能管理平台 - 告警管理 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-NME-PERF name=智能管理平台 - 性能管理 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-PLAT name=智能管理平台 - 资源管理 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-REPORT name=智能管理平台 - 报表管理 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1537)] id=iMC-SYSLOG name=智能管理平台 - Syslog管理 version=7.3-E0703 innerVersion=V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$ComponentsCheckingWorkingDialog::doWork(1543)] 检查哪些组件需要安装 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(518)] 待安装的组件列表 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-DM 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-ICC 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-NETASSET 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-NME-FAULT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-NME-PERF 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-PLAT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-REPORT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(520)] compId:iMC-SYSLOG 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(521)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(522)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(530)] 获取已经安装的组件的最新版本 2020-03-12 13:58:09 [WARN ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::filterWithDeployManager(793)] deploy/conf/component-deploy.xml not exit. 初始安装 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(537)] 过滤已经安装的组件列表 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(544)] 检查已安装组件中是否有与平台不再同一个大版本的组件 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsHaveSameBigVersion(433)] 定义支持的大版本版本升级规则,key为准备升级的大版本版本,value为现环境中已安装的组件必须具备有大版本。 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsHaveSameBigVersion(439)] {7.1=7.0, 7.2=7.1, 7.3=7.2} 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsHaveSameBigVersion(441)] installedCompOnents==null||installedComponents.length==0 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(549)] 如果曾经安装过,需要判断组件是否需要重新安装 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(554)] 正在安装的组件 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-DM 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-ICC 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-NETASSET 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-NME-FAULT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-NME-PERF 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-PLAT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-REPORT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(556)] compId:iMC-SYSLOG 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(557)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(558)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(560)] ------------- 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(561)] 已经安装的组件。 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(567)] ------------- 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(568)] 不需要安装的组件列表 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(574)] ------------- 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(583)] 增加数据库的检查,对于升级版本,不需要检查,不可能再切换数据库了。只需要检查未安装过的组件 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(585)] 需要检查的组件 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-DM 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-ICC 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-NETASSET 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-NME-FAULT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-NME-PERF 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-PLAT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-REPORT 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(587)] compId:iMC-SYSLOG 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(588)] version:7.3-E0703 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(589)] innerVer:V700R001B06D026 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(591)] ------------- 2020-03-12 13:58:09 [WARN ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor::checkComponentsShouldBeInstall(698)] 逐个判断组件的依赖性,如果依赖性不满足要求,则不允许安装 2020-03-12 13:58:09 [WARN ] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:09 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:09 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:09 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.Util::getInstallInfo(868)] Can not find instInfoFile - C:\Windows\iMC-Reserved\instinfo.txt 2020-03-12 13:58:09 [WARN ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.DeployManager::getInstance(72)] Can not find install info file 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-5] [com.h3c.imc.deploy.install.wizard.InstallFolderChoosePanelDescriptor$InitPlatInfoWorkingDialog::doWork(1641)] copy instfile 2 conf res:true 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-5] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] config info persisted:{support=false} 2020-03-12 13:58:09 [INFO ] [SwingWorker-pool-1-thread-5] [com.h3c.imc.deploy.InstallPhysicalInfoVerification::printlnMsg(1147)] Please close the current command line window 2020-03-12 13:58:10 [INFO ] [Thread-6] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$WorkingThread::run(152)] current deploy.jar file not exist, install common components is required. 2020-03-12 13:58:48 [INFO ] [SwingWorker-pool-1-thread-7] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker::doInBackground(566)] evs is null,no need to install earlierversion 2020-03-12 13:59:10 [INFO ] [SwingWorker-pool-1-thread-7] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(232)] registerNewComponent 2020-03-12 13:59:10 [INFO ] [SwingWorker-pool-1-thread-7] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(236)] compOnentId= iMC-DM 2020-03-12 13:59:10 [INFO ] [SwingWorker-pool-1-thread-7] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(246)] 没有找到对应的组件,增加一个新的 2020-03-12 13:59:10 [INFO ] [SwingWorker-pool-1-thread-7] [com.h3c.imc.deploy.dma.DeployManager::saveAllComponentDeployInfo(756)] Save Component Deploy Info OK 2020-03-12 13:59:10 [INFO ] [SwingWorker-pool-1-thread-8] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker::doInBackground(566)] evs is null,no need to install earlierversion 2020-03-12 13:59:14 [INFO ] [SwingWorker-pool-1-thread-8] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(232)] registerNewComponent 2020-03-12 13:59:14 [INFO ] [SwingWorker-pool-1-thread-8] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(236)] compOnentId= iMC-ICC 2020-03-12 13:59:14 [INFO ] [SwingWorker-pool-1-thread-8] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(246)] 没有找到对应的组件,增加一个新的 2020-03-12 13:59:14 [INFO ] [SwingWorker-pool-1-thread-8] [com.h3c.imc.deploy.dma.DeployManager::saveAllComponentDeployInfo(756)] Save Component Deploy Info OK 2020-03-12 13:59:14 [INFO ] [SwingWorker-pool-1-thread-9] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker::doInBackground(566)] evs is null,no need to install earlierversion 2020-03-12 13:59:15 [INFO ] [SwingWorker-pool-1-thread-9] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(232)] registerNewComponent 2020-03-12 13:59:15 [INFO ] [SwingWorker-pool-1-thread-9] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(236)] compOnentId= iMC-NETASSET 2020-03-12 13:59:15 [INFO ] [SwingWorker-pool-1-thread-9] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(246)] 没有找到对应的组件,增加一个新的 2020-03-12 13:59:15 [INFO ] [SwingWorker-pool-1-thread-9] [com.h3c.imc.deploy.dma.DeployManager::saveAllComponentDeployInfo(756)] Save Component Deploy Info OK 2020-03-12 13:59:15 [INFO ] [SwingWorker-pool-1-thread-10] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker::doInBackground(566)] evs is null,no need to install earlierversion 2020-03-12 13:59:18 [INFO ] [SwingWorker-pool-1-thread-10] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(232)] registerNewComponent 2020-03-12 13:59:18 [INFO ] [SwingWorker-pool-1-thread-10] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(236)] compOnentId= iMC-NME-FAULT 2020-03-12 13:59:18 [INFO ] [SwingWorker-pool-1-thread-10] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(246)] 没有找到对应的组件,增加一个新的 2020-03-12 13:59:18 [INFO ] [SwingWorker-pool-1-thread-10] [com.h3c.imc.deploy.dma.DeployManager::saveAllComponentDeployInfo(756)] Save Component Deploy Info OK 2020-03-12 13:59:18 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker::doInBackground(566)] evs is null,no need to install earlierversion 2020-03-12 13:59:23 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(232)] registerNewComponent 2020-03-12 13:59:23 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(236)] compOnentId= iMC-NME-PERF 2020-03-12 13:59:23 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.dma.DeployManager::registerNewComponent(246)] 没有找到对应的组件,增加一个新的 2020-03-12 13:59:23 [INFO ] [SwingWorker-pool-1-thread-1] [com.h3c.imc.deploy.dma.DeployManager::saveAllComponentDeployInfo(756)] Save Component Deploy Info OK 2020-03-12 13:59:23 [INFO ] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker::doInBackground(566)] evs is null,no need to install earlierversion 2020-03-12 14:00:37 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomShortCutIcon(3073)] path:C:\IMC_palt\iMC/deploy/components/common/deploy/custom/images/shortcut.ico 2020-03-12 14:00:37 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.CommonComponentInstaller$InstallCommonCompWorkingDialog::executeWindowsTasks(899)] 不存在定制shortcut图片信息 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(296)] SYSTEM\\ControlSet001\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(304)] SYSTEM\\ControlSet002\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(312)] SYSTEM\\ControlSet003\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(320)] SYSTEM\\ControlSet003\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(296)] SYSTEM\\ControlSet001\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(304)] SYSTEM\\ControlSet002\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(312)] SYSTEM\\ControlSet003\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:46 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::uninstallService(320)] SYSTEM\\ControlSet003\\Services\\Intelligent Management Server reg not exit. 2020-03-12 14:00:47 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteRegistry(261)] SYSTEM\CurrentControlSet\Services\EventLog\Application\JavaService delete flag is true 2020-03-12 14:00:47 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteRegistry(264)] SYSTEM\CurrentControlSet\Services\EventLog\Application\H3C iMC Server reg not exit. 2020-03-12 14:00:47 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteRegistry(264)] SYSTEM\CurrentControlSet\Services\EventLog\Application\HP iMC Server reg not exit. 2020-03-12 14:00:47 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteRegistry(261)] SYSTEM\CurrentControlSet\Services\EventLog\Application\Intelligent Management Server delete flag is true 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] shortcut.folder has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.CommonComponentInstaller$InstallCommonCompWorkingDialog::executeWindowsTasks(1053)] -cp deploy.jar -splash:splash.jpg -Djava.io.tmpdir="C:\IMC_palt\iMC\tmp" com.h3c.imc.deploy.DMALauncher 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] shortcut.dma.name has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] shortcut.dma.description has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::createShortcutLink(182)] LinkFile [folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\H3C 智能管理中心, name=H3C 部署监控代理, description=启动 H3C 部署监控代理程序,监控 H3C 智能管理中心运行情况,或部署新的组件。, path=C:\IMC_palt\iMC\deploy\jdk\bin\javaw.exe, workingDirectory=C:\IMC_palt\iMC\deploy, arguments=-cp deploy.jar -splash:splash.jpg -Djava.io.tmpdir="C:\IMC_palt\iMC\tmp" com.h3c.imc.deploy.DMALauncher, icOnLocation=C:\IMC_palt\iMC\deploy\shortcut.ico, icOnIndex=0] 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] shortcut.uninstall.name has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] shortcut.uninstall.description has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::createShortcutLink(182)] LinkFile [folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\H3C 智能管理中心, name=卸载 H3C 智能管理中心, description=卸载 H3C 智能管理中心。, path=C:\IMC_palt\iMC\deploy\jdk\bin\javaw.exe, workingDirectory=C:\IMC_palt\iMC\deploy, arguments=-cp deploy.jar -Djava.io.tmpdir="C:\IMC_palt\iMC\tmp" com.h3c.imc.deploy.UninstallLauncher, icOnLocation=C:\IMC_palt\iMC\deploy\install.ico, icOnIndex=0] 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] removeItem.name has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] removeItem.comments has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] removeItem.company.url has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] removeItem.company has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] removeItem.company.url has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] removeItem.company.updateUrl has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.Util::getCustomStringWithOemInfo(3028)] removeItem.name has no custom value 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(246)] delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\H3C 智能管理中心 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(251)] not exists HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\H3C 智能管理中心 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(246)] delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\HP Intelligent Management Center 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(251)] not exists HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\HP Intelligent Management Center 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(246)] delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\H3C 智能管理中心 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(251)] not exists HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\H3C 智能管理中心 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(246)] delete HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\惠普智能管理中心 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.WindowsToolkitCustomRoxesImpl::deleteWow6432AddRemoveProgramItem(251)] not exists HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\惠普智能管理中心 2020-03-12 14:00:59 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.CommonComponentInstaller$InstallCommonCompWorkingDialog::executeWindowsTasks(1247)] Start instal vcredist.exe... 2020-03-12 14:02:31 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.CommonComponentInstaller$InstallCommonCompWorkingDialog::executeWindowsTasks(1253)] vcredist.exe is installed in 91486 ms, return 1603 2020-03-12 14:02:31 [ERROR] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.CommonComponentInstaller$InstallCommonCompWorkingDialog::executeWindowsTasks(1256)] return code of vcredist is not 0 or 3010 2020-03-12 14:04:11 [ERROR] [SwingWorker-pool-1-thread-2] [com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker::doInBackground(621)] Executing installation task error java.lang.Exception: Install deploy component failed at com.h3c.imc.deploy.plat.InstallPlatform.afterCopyFiles(InstallPlatform.java:50) at com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker.doInBackground(InstallingPanelDescriptor.java:603) at com.h3c.imc.deploy.install.wizard.InstallingPanelDescriptor$ComponentInstallWorker.doInBackground(InstallingPanelDescriptor.java:523) at java.desktop/javax.swing.SwingWorker$1.call(SwingWorker.java:304) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at java.desktop/javax.swing.SwingWorker.run(SwingWorker.java:343) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) at java.base/java.lang.Thread.run(Thread.java:834)
