S7508E-X升级其中一快主控板卡没起来
  • 1收藏,868浏览
升级的版本是S7500EX-CMW520-R6910P03
升级完成后一块主控板没起来  console控制界面失效
dis cpu 时Slot 4 出现两次   slot5消失
<H3C>dis cpu
Slot 0 CPU usage:
6% in last 5 seconds
 6% in last 1 minute
 6% in last 5 minutes
 Slot 1 CPU usage:
 6% in last 1 minute
 Slot 2 CPU usage:
 5% in last 5 seconds
 5% in last 1 minute
 5% in last 5 minutes
 Slot 3 CPU usage:
9% in last 5 seconds
 8% in last 1 minute
 8% in last 5 minutes
 Slot 3 CPU 1 CPU usage:
 1% in last 5 seconds
 1% in last 1 minute
 1% in last 5 minutes
 Slot 4 CPU usage:
 6% in last 1 minute
 Slot 4 CPU 1 CPU usage:
 1% in last 1 minute
 Slot 6 CPU usage:
 8% in last 5 seconds
8% in last 1 minute
 Slot 7 CPU usage:
 4% in last 1 minute
 4% in last 5 minutes
 Slot 10 CPU usage:
 7% in last 5 seconds
 7% in last 1 minute
 7% in last 5 minutes
 Slot 11 CPU usage:
 7% in last 1 minute
欣欣 九段
粉丝:18人 关注:7人
您可以按照如下思路排查下:
(1)观察下该单板指示灯的状态,如果是红色,证明确实有异常;
(2)确认正常主控和异常主控是否是同一个类型,如果是,请继续排查;
(3)将console插入正常主控中,display device确保正常主控及业务板已经normal;
(4)手动插拔下故障主控,然后看其能否normal,如果还起不来,将console插在该单板看输出什么信息;
(5)如果起不来收集下信息找工程师看下,感觉大概率可能是硬件故障了。
这个可能是显示的问题,记得之前有过类似的问题,可以再重启看下
欣欣 发表时间:2020-03-13
指示灯正常 0 LSQ1GP24SC Normal 0 S7500E-X-6910P03 None 1 LSQ1GT24SC Normal 0 S7500E-X-6910P03 None 2 LSQ1GT24SC Normal 0 S7500E-X-6910P03 None 3 LSQ1TGS8SC Normal 0 S7500E-X-6910P03 None 4 LSQ1SUPA Master 0 S7500E-X-6910P03 None 5 LSQ1SUPA Fault 0 NONE None 6 LSQ1GV48SC Normal 0 S7500E-X-6910P03 None 7 LSQ2FWBSC Normal 0 S7500E-X-6910P03 None 8 NONE Absent 0 NONE None 9 NONE Absent 0 NONE None 10 LSU1FAB08B Normal 0 S7500E-X-6910P03 None 11 LSU1FAB08B Normal 0 S7500E-X-6910P03 None 12 NONE Absent 0 NONE None 13 NONE Absent 0 NONE None
zhiliao_vluSv 发表时间:2020-03-13
