配置端口为TRUCK提示this port is a truck port! 配置命令也不能不全,是交换机模式问题吗,如何解决
S5560接S5048E,光口对接
(0)
1、根据 This port is not a TRUNK port! 说明这个接口还不是trunk ,如果配置是空的,可尝试如下命令进行配置:
int gi 0/46
port link-mode bridge
port link-type trunk
port trunk permit vlan all
2、如果还是不行,可尝试其他接口再次配置试下。
(0)
写错了吧 是trunk。
意思就是你当前的端口就是trunk口了,重复配置了,可以再接口视图下 dis thi,确认
(0)
[H3C-GigabitEthernet0/46]dis this # interface GigabitEthernet0/46 # return [H3C-GigabitEthernet0/46]por [H3C-GigabitEthernet0/46]port t [H3C-GigabitEthernet0/46]port trunk pe [H3C-GigabitEthernet0/46]port trunk permit v [H3C-GigabitEthernet0/46]port trunk permit vlan ^ % Incomplete command found at '^' position. [H3C-GigabitEthernet0/46]port trunk permit vlan 2 3 5 6 This port is not a TRUNK port! [H3C-GigabitEthernet0/46]port trunk permit vlan all This port is not a TRUNK port! [H3C-GigabitEthernet0/46]q [H3C]dis this # sysname H3C # hardware-failure-detection board warning # # # # return [H3C]
(0)
先敲port link-type trunk
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
