S5016P 恢复出厂设置问题
2020-03-18提问
  • 1收藏,1272浏览
序列号:219801a05fm09500088
MAC: 0023-891c-1112
<H3C>system-view
 Password:
这个地方的密码,忘记了,无法进入系统视图去恢复出厂设置,需要用MAC地址计算一个超级密码,才能进入恢复出厂设置
根据提供的MAC,超级密码计算出来是DCBFAMGN,这个密码只是用于bootrom密码忘记用的。
但是看问题描述这里是进入系统视图的密码,这个只能删配置来处理了。可以进入bootrom,删除配置文件,然后重启。
粉丝:21人 关注:0人
V5平台交换机下console口配置密码,忘记设置密码之后需要进入设备botroom菜单选择跳过配置文件启动设备
需求1:需要之前的配置文件,客户重新进入交换机后下载配置文件。
配置过程:
* Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
* Without the owner&#39;s prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
User interface aux0 is available.
Please press ENTER.
Login authentication
Password:
 %Username or password is invalid.
Password:
忘记console口用户名和密码时,重启设备进入botroom菜单。
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
*                H3C S3110-26TP-SI BootWare, Version 1.10                  *
Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Jun  5 2014 11:34:07
CPU Type            : MIPS4kec
CPU L1 Cache        : 16KB
CPU Clock Speed     : 500MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 128MB
Memory Speed        : 300MHz
BootWare Size       : 3MB
Flash Size          : 32MB
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Ctrl+B进入botroom菜单
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6   选择跳过配置文件
Flag Set Success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0  选择0重启设备
CPU Type            : MIPS4kec
CPU L1 Cache        : 16KB
Memory Size         : 128MB
BootWare Size       : 3MB
Flash Size          : 32MB
Starting to get the main application
file--flash:/S3110_26TP_SI-CMW520-R1104.bin!................................
The main application file is self-decompressing.............................
...........................................................Done!
System application is starting...
Configuration file is skipped.
Press ENTER to get started.
<H3C>
#Apr 26 12:02:07:166 2000 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console
%Apr 26 12:02:07:306 2000 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
<H3C>
<H3C>dir  ----查看设备配置文件
Directory of flash:/
   0     -rw-  12511232  Aug 08 2008 20:00:00   s3110_26tp_si-cmw520-r1104.bin
   1     drw-         -  Apr 26 2000 12:00:20   logfile
   2     -rw-      1666  Apr 26 2000 12:05:39   startup.cfg
   3     -rw-      1556  Apr 26 2000 12:05:33   _startup_bak.cfg
   4     -rw-       151  Apr 26 2000 12:05:30   system.xml
29106 KB total (16876 KB free)
给交换机和电脑配置成同网段IP地址(举例:交换机配置成192.168.100.1,电脑配置成192.168.100.2),在电脑上通过3CD软件搭建tftp服务器。
<H3C>sys
[H3C]interface Vlan-interface 1
[H3C-Vlan-interface1]ip address 192.168.100.1 24
[H3C-Vlan-interface1]quit
[H3C]ping 192.168.100.2
  PING 192.168.100.2: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.2: bytes=56 Sequence=1 ttl=128 time=7 ms
    Reply from 192.168.100.2: bytes=56 Sequence=2 ttl=128 time=2 ms
    Reply from 192.168.100.2: bytes=56 Sequence=3 ttl=128 time=2 ms
    Reply from 192.168.100.2: bytes=56 Sequence=4 ttl=128 time=2 ms
    Reply from 192.168.100.2: bytes=56 Sequence=5 ttl=128 time=2 ms
  --- 192.168.100.2 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 2/3/7 ms
[H3C]
<H3C>tftp 192.168.100.2 put startup.cfg
  File will be transferred in binary mode
  Sending file to remote TFTP server. Please wait... |
  TFTP:     1666 bytes sent in 0 second(s).
  File uploaded successfully.
<H3C>
下载成功:
可以到本地相关路径查看到相关文件。
需求2:直接恢复出厂设置,不需要之前的配置文件
操作步骤:跳过启动文件后直接保存当前配置即可。
