l2tp over ipsec 隧道建立不成功
2020-03-20提问
  • 1收藏,1209浏览
No One 零段
MSR3040 做的l2tp over ipsec
用的inode客户端
不加ipsec直接拨很快成功
加上ipsec
ike,ipsec都认证成功,就提示隧道或会话建立不成功。。。
*Mar 20 05:21:06:083 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:06:084 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:06:084 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:06:084 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:06:085 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:06:086 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:06:086 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:06:086 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:06:087 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:06:087 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:06:088 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:06:088 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:06:088 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:06:089 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:06:089 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:06:089 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:06:090 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:06:090 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:06:090 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:06:091 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 1 *Mar 20 05:21:06:091 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:06:091 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:06:092 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:06:092 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 first ctrl in send window, started ack timer *Mar 20 05:21:06:093 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 sent SCCRP to Tunnel 1 *Mar 20 05:21:06:093 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 started the Hello timer (60 seconds) *Mar 20 05:21:07:111 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:07:112 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:08:847 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:08:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:08:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:08:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:08:849 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:08:850 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:08:850 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 2 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:08:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:08:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:08:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:08:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:08:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:08:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:08:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:08:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:08:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:08:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:08:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:08:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:08:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 2 *Mar 20 05:21:08:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:08:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:08:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:08:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 first ctrl in send window, started ack timer *Mar 20 05:21:08:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 2 sent SCCRP to Tunnel 1 *Mar 20 05:21:08:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 2 started the Hello timer (60 seconds) *Mar 20 05:21:09:111 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:09:112 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:09:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:09:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:10:847 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:10:847 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:10:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:10:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:10:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:10:850 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:10:850 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 3 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:10:850 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:10:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:10:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:10:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:10:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:10:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:10:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:10:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:10:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:10:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:10:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:10:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:10:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 3 *Mar 20 05:21:10:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:10:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:10:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:10:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 first ctrl in send window, started ack timer *Mar 20 05:21:10:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 3 sent SCCRP to Tunnel 1 *Mar 20 05:21:10:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 3 started the Hello timer (60 seconds) *Mar 20 05:21:11:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:11:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:11:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:11:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:13:111 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:13:112 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:13:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:13:849 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:13:849 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:13:849 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:13:850 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:13:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:13:851 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 4 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:13:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:13:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:13:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:13:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:13:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:13:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:13:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:13:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:13:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:13:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:13:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:13:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:13:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 4 *Mar 20 05:21:13:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:13:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:13:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:13:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 first ctrl in send window, started ack timer *Mar 20 05:21:13:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 4 sent SCCRP to Tunnel 1 *Mar 20 05:21:13:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 4 started the Hello timer (60 seconds) *Mar 20 05:21:13:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:13:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:14:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:14:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:15:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:15:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:16:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:16:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:16:852 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:16:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:16:853 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:16:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:16:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 5 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:16:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:16:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:16:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:16:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:16:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:16:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:16:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:16:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:16:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:16:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:16:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:16:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:16:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 5 *Mar 20 05:21:16:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:16:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:16:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:16:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 first ctrl in send window, started ack timer *Mar 20 05:21:16:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 5 sent SCCRP to Tunnel 1 *Mar 20 05:21:16:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 5 started the Hello timer (60 seconds) *Mar 20 05:21:16:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:16:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:17:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:17:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:17:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:17:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:19:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:19:854 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:19:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:19:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:19:855 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:19:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:19:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 6 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:19:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:19:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:19:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:19:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:19:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:19:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:19:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:19:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:19:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:19:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:19:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:19:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:19:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 6 *Mar 20 05:21:19:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:19:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:19:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:19:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 first ctrl in send window, started ack timer *Mar 20 05:21:19:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 6 sent SCCRP to Tunnel 1 *Mar 20 05:21:19:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 6 started the Hello timer (60 seconds) *Mar 20 05:21:19:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:19:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:20:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:20:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:20:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:20:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:21:111 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:21:112 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:22:856 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:22:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:22:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:22:857 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:22:858 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:22:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:22:859 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 7 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:22:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:22:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:22:860 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:22:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:22:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:22:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:22:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:22:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:22:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:22:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:22:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:22:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:22:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 7 *Mar 20 05:21:22:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:22:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:22:863 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:22:863 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 first ctrl in send window, started ack timer *Mar 20 05:21:22:863 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 7 sent SCCRP to Tunnel 1 *Mar 20 05:21:22:863 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 7 started the Hello timer (60 seconds) *Mar 20 05:21:22:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:22:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:23:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:23:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:23:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:23:913 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:23:913 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:23:913 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:25:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:25:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:25:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:25:863 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:25:863 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:25:864 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:25:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 8 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:25:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:25:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:25:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:25:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:25:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:25:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:25:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:25:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:25:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:25:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:25:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:25:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:25:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 8 *Mar 20 05:21:25:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:25:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:25:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:25:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 first ctrl in send window, started ack timer *Mar 20 05:21:25:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 8 sent SCCRP to Tunnel 1 *Mar 20 05:21:25:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 8 started the Hello timer (60 seconds) *Mar 20 05:21:25:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:25:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:25:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:25:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:26:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:26:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:26:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:26:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:28:861 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:28:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:28:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:28:862 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:28:863 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:28:864 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:28:864 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 9 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:28:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:28:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:28:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:28:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:28:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:28:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:28:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:28:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:28:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:28:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:28:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:28:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:28:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 9 *Mar 20 05:21:28:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:28:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:28:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:28:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 first ctrl in send window, started ack timer *Mar 20 05:21:28:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 9 sent SCCRP to Tunnel 1 *Mar 20 05:21:28:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 9 started the Hello timer (60 seconds) *Mar 20 05:21:28:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:28:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:28:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:28:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:29:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:29:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:29:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:29:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:31:864 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:31:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:31:865 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:31:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:31:866 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:31:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:31:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 10 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:31:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:31:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:31:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:31:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:31:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:31:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:31:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:31:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:31:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:31:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:31:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:31:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:31:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 10 *Mar 20 05:21:31:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:31:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:31:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:31:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 first ctrl in send window, started ack timer *Mar 20 05:21:31:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 10 sent SCCRP to Tunnel 1 *Mar 20 05:21:31:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 10 started the Hello timer (60 seconds) *Mar 20 05:21:31:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:31:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:31:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:31:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:32:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:32:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:32:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:32:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:34:111 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:34:112 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 1 cleared because 1 *Mar 20 05:21:34:112 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 sent StopCCN to Tunnel 1 *Mar 20 05:21:34:112 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:34:113 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 1 *Mar 20 05:21:34:113 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:34:113 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:34:114 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:1 *Mar 20 05:21:34:867 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 79 *Mar 20 05:21:34:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:34:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:34:868 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 05:21:34:869 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 79 *Mar 20 05:21:34:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 79 *Mar 20 05:21:34:870 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 recv SCCRQ when in state 1 from 192.168.10.148 *Mar 20 05:21:34:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 05:21:34:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 05:21:34:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: vpnuser *Mar 20 05:21:34:872 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 05:21:34:872 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Vendor name, value: HuaWei *Mar 20 05:21:34:872 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 1 *Mar 20 05:21:34:873 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 1 *Mar 20 05:21:34:873 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 128 *Mar 20 05:21:34:873 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 05:21:34:874 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 05:21:34:874 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 05:21:34:874 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 05:21:34:875 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 1 *Mar 20 05:21:34:875 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 05:21:34:876 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 128 *Mar 20 05:21:34:876 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 05:21:34:876 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 first ctrl in send window, started ack timer *Mar 20 05:21:34:877 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 sent SCCRP to Tunnel 1 *Mar 20 05:21:34:877 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 started the Hello timer (60 seconds) *Mar 20 05:21:34:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:34:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:34:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:34:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:35:086 2020 3040_BJ IKE/7/DEBUG: network receive message: receive keep alive message from 219.150.64.162 *Mar 20 05:21:35:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:35:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 05:21:35:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:35:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:36:911 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:36:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 2 cleared because 1 *Mar 20 05:21:36:912 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 2 sent StopCCN to Tunnel 1 *Mar 20 05:21:36:913 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:36:913 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 2 *Mar 20 05:21:36:913 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:36:914 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 2 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:36:914 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:2 *Mar 20 05:21:37:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 38 *Mar 20 05:21:37:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 4 *Mar 20 05:21:37:871 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 05:21:37:872 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 4 *Mar 20 05:21:37:872 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 4 Length = 38 *Mar 20 05:21:37:873 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=4, len = 38 *Mar 20 05:21:37:930 2020 3040_BJ IKE/7/DEBUG: received message: *Mar 20 05:21:37:930 2020 3040_BJ IKE/7/DEBUG: ICOOKIE: 0x5ac1d3e2294ce91b *Mar 20 05:21:37:931 2020 3040_BJ IKE/7/DEBUG: RCOOKIE: 0x2fdb44e09f9c6f7d *Mar 20 05:21:37:931 2020 3040_BJ IKE/7/DEBUG: NEXT_PAYLOAD: HASH *Mar 20 05:21:37:932 2020 3040_BJ IKE/7/DEBUG: VERSION: 16 *Mar 20 05:21:37:932 2020 3040_BJ IKE/7/DEBUG: EXCH_TYPE: INFO *Mar 20 05:21:37:932 2020 3040_BJ IKE/7/DEBUG: FLAGS: [ ENC ] *Mar 20 05:21:37:933 2020 3040_BJ IKE/7/DEBUG: MESSAGE_ID: 0x0b13a374 *Mar 20 05:21:37:933 2020 3040_BJ IKE/7/DEBUG: LENGTH: 68 *Mar 20 05:21:37:933 2020 3040_BJ IKE/7/DEBUG: initialized IV: *Mar 20 05:21:37:934 2020 3040_BJ IKE/7/DEBUG: a47a574c 63b61ebb *Mar 20 05:21:37:934 2020 3040_BJ IKE/7/DEBUG: DO decrypt: before decryption: *Mar 20 05:21:37:934 2020 3040_BJ IKE/7/DEBUG: b9c03500 90e75e7f 53bfc189 35302333 *Mar 20 05:21:37:935 2020 3040_BJ IKE/7/DEBUG: 765ab11c 9a38ade3 4f4b0055 cc4f8acc *Mar 20 05:21:37:935 2020 3040_BJ IKE/7/DEBUG: 1ca6974c a29b8ad3 *Mar 20 05:21:37:935 2020 3040_BJ IKE/7/DEBUG: CryptoEngine_BlockEncrypt: op type = 0x00001006. *Mar 20 05:21:37:936 2020 3040_BJ IKE/7/DEBUG: enc_key: *Mar 20 05:21:37:936 2020 3040_BJ IKE/7/DEBUG: 460ec2b9 20196b38 01916d0e a78c75cd *Mar 20 05:21:37:936 2020 3040_BJ IKE/7/DEBUG: efba985b 98025bc4 *Mar 20 05:21:37:937 2020 3040_BJ IKE/7/DEBUG: iv: *Mar 20 05:21:37:937 2020 3040_BJ IKE/7/DEBUG: a47a574c 63b61ebb *Mar 20 05:21:37:937 2020 3040_BJ IKE/7/DEBUG: DO decrypt: after decryption: *Mar 20 05:21:37:938 2020 3040_BJ IKE/7/DEBUG: 0c000014 ee943224 db4de853 88b06d3f *Mar 20 05:21:37:938 2020 3040_BJ IKE/7/DEBUG: dec7f869 00000010 00000001 03040001 *Mar 20 05:21:37:938 2020 3040_BJ IKE/7/DEBUG: ee26a478 00000000 *Mar 20 05:21:37:939 2020 3040_BJ IKE/7/DEBUG: parse payloads: payload HASH *Mar 20 05:21:37:939 2020 3040_BJ IKE/7/DEBUG: parse payloads: payload DELETE *Mar 20 05:21:37:939 2020 3040_BJ IKE/7/DEBUG: validate payload HASH *Mar 20 05:21:37:940 2020 3040_BJ IKE/7/DEBUG: validate payload DELETE *Mar 20 05:21:37:940 2020 3040_BJ IKE/7/DEBUG: DOI: IPSEC *Mar 20 05:21:37:940 2020 3040_BJ IKE/7/DEBUG: PROTO: IPSEC_ESP *Mar 20 05:21:37:941 2020 3040_BJ IKE/7/DEBUG: SPI_SZ: 4 *Mar 20 05:21:37:941 2020 3040_BJ IKE/7/DEBUG: NSPIS: 1 *Mar 20 05:21:37:955 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:37:955 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 05:21:37:955 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:37:956 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:37:956 2020 3040_BJ IKE/7/DEBUG: updated IV: *Mar 20 05:21:37:956 2020 3040_BJ IKE/7/DEBUG: 1ca6974c a29b8ad3 *Mar 20 05:21:37:959 2020 3040_BJ IKE/7/DEBUG: received message: *Mar 20 05:21:37:959 2020 3040_BJ IKE/7/DEBUG: ICOOKIE: 0x5ac1d3e2294ce91b *Mar 20 05:21:37:959 2020 3040_BJ IKE/7/DEBUG: RCOOKIE: 0x2fdb44e09f9c6f7d *Mar 20 05:21:37:960 2020 3040_BJ IKE/7/DEBUG: NEXT_PAYLOAD: HASH *Mar 20 05:21:37:960 2020 3040_BJ IKE/7/DEBUG: VERSION: 16 *Mar 20 05:21:37:960 2020 3040_BJ IKE/7/DEBUG: EXCH_TYPE: INFO *Mar 20 05:21:37:961 2020 3040_BJ IKE/7/DEBUG: FLAGS: [ ENC ] *Mar 20 05:21:37:961 2020 3040_BJ IKE/7/DEBUG: MESSAGE_ID: 0x3a57b366 *Mar 20 05:21:37:962 2020 3040_BJ IKE/7/DEBUG: LENGTH: 76 *Mar 20 05:21:37:962 2020 3040_BJ IKE/7/DEBUG: initialized IV: *Mar 20 05:21:37:962 2020 3040_BJ IKE/7/DEBUG: 562fb86e a39bfdea *Mar 20 05:21:37:963 2020 3040_BJ IKE/7/DEBUG: DO decrypt: before decryption: *Mar 20 05:21:37:963 2020 3040_BJ IKE/7/DEBUG: 5a44dae2 1de4c45a 81aa2372 c3417b9b *Mar 20 05:21:37:963 2020 3040_BJ IKE/7/DEBUG: 94b05e4f 0e93df74 a2891fe4 5bbd3ccb *Mar 20 05:21:37:964 2020 3040_BJ IKE/7/DEBUG: ec8fe2ab 30570e43 ab422f4f 27c2982b *Mar 20 05:21:37:964 2020 3040_BJ IKE/7/DEBUG: CryptoEngine_BlockEncrypt: op type = 0x00001006. *Mar 20 05:21:37:964 2020 3040_BJ IKE/7/DEBUG: enc_key: *Mar 20 05:21:37:965 2020 3040_BJ IKE/7/DEBUG: 460ec2b9 20196b38 01916d0e a78c75cd *Mar 20 05:21:37:965 2020 3040_BJ IKE/7/DEBUG: efba985b 98025bc4 *Mar 20 05:21:37:965 2020 3040_BJ IKE/7/DEBUG: iv: *Mar 20 05:21:37:966 2020 3040_BJ IKE/7/DEBUG: 562fb86e a39bfdea *Mar 20 05:21:37:966 2020 3040_BJ IKE/7/DEBUG: DO decrypt: after decryption: *Mar 20 05:21:37:966 2020 3040_BJ IKE/7/DEBUG: 0c000014 58bebe1f ea8c4bbb 90562476 *Mar 20 05:21:37:967 2020 3040_BJ IKE/7/DEBUG: 0738a9e4 0000001c 00000001 01100001 *Mar 20 05:21:37:967 2020 3040_BJ IKE/7/DEBUG: 5ac1d3e2 294ce91b 2fdb44e0 9f9c6f7d *Mar 20 05:21:37:967 2020 3040_BJ IKE/7/DEBUG: parse payloads: payload HASH *Mar 20 05:21:37:968 2020 3040_BJ IKE/7/DEBUG: parse payloads: payload DELETE *Mar 20 05:21:37:968 2020 3040_BJ IKE/7/DEBUG: validate payload HASH *Mar 20 05:21:37:968 2020 3040_BJ IKE/7/DEBUG: validate payload DELETE *Mar 20 05:21:37:969 2020 3040_BJ IKE/7/DEBUG: DOI: IPSEC *Mar 20 05:21:37:969 2020 3040_BJ IKE/7/DEBUG: PROTO: ISAKMP *Mar 20 05:21:37:969 2020 3040_BJ IKE/7/DEBUG: SPI_SZ: 16 *Mar 20 05:21:37:970 2020 3040_BJ IKE/7/DEBUG: NSPIS: 1 *Mar 20 05:21:37:970 2020 3040_BJ IKE/7/DEBUG: updated IV: *Mar 20 05:21:37:970 2020 3040_BJ IKE/7/DEBUG: ab422f4f 27c2982b *Mar 20 05:21:38:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:38:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:38:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:38:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 3 cleared because 1 *Mar 20 05:21:38:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 3 sent StopCCN to Tunnel 1 *Mar 20 05:21:38:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:38:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 3 *Mar 20 05:21:38:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:38:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 3 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:38:925 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:3 *Mar 20 05:21:40:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:40:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:41:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:41:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 05:21:41:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:41:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 4 cleared because 1 *Mar 20 05:21:41:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 4 sent StopCCN to Tunnel 1 *Mar 20 05:21:41:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:41:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 4 *Mar 20 05:21:41:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:41:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 4 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:41:925 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:4 *Mar 20 05:21:43:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:43:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:44:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:44:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 5 cleared because 1 *Mar 20 05:21:44:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 5 sent StopCCN to Tunnel 1 *Mar 20 05:21:44:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:44:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 5 *Mar 20 05:21:44:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:44:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 5 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:44:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:5 *Mar 20 05:21:46:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:46:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:47:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:47:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 6 cleared because 1 *Mar 20 05:21:47:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 6 sent StopCCN to Tunnel 1 *Mar 20 05:21:47:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:47:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 6 *Mar 20 05:21:47:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:47:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 6 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:47:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:6 *Mar 20 05:21:49:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:49:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 05:21:50:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:50:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 7 cleared because 1 *Mar 20 05:21:50:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 7 sent StopCCN to Tunnel 1 *Mar 20 05:21:50:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:50:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 7 *Mar 20 05:21:50:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:50:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 7 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:50:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:7 *Mar 20 05:21:53:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:53:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 8 cleared because 1 *Mar 20 05:21:53:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 8 sent StopCCN to Tunnel 1 *Mar 20 05:21:53:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:53:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 8 *Mar 20 05:21:53:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:53:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 8 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:53:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:8 *Mar 20 05:21:56:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:56:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 9 cleared because 1 *Mar 20 05:21:56:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 9 sent StopCCN to Tunnel 1 *Mar 20 05:21:56:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:56:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 9 *Mar 20 05:21:56:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:56:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 9 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:56:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:9 *Mar 20 05:21:59:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:21:59:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 10 cleared because 1 *Mar 20 05:21:59:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 10 sent StopCCN to Tunnel 1 *Mar 20 05:21:59:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:21:59:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 10 *Mar 20 05:21:59:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:21:59:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 10 sent control (SendUp & RcvLow): Ns (1) Nr (1) *Mar 20 05:21:59:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:1, local ID:10 *Mar 20 05:22:02:921 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 05:22:02:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 1 cleared because 1 *Mar 20 05:22:02:922 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 sent StopCCN to Tunnel 1 *Mar 20 05:22:02:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 05:22:02:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 1 *Mar 20 05:22:02:923 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 05:22:02:924 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 sent control (SendUp & RcvLow): Ns (1) N
粉丝:24人 关注:13人
*Mar 20 05:21:10:848 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer  //对端是什么设备呢?本端有回复SCCRP,没有下面的交互了,疑似收到了对端的STOPCCN,
No One 知了小白
对端是windows10  安装的inode客户端
